Toymods » Tech & Conversions » Before engineer's certificate
SupraPete
Before engineer's certificate Tue, 24 June 2003 04:13 Go to next message
I'm getting my engineer to gimme a certificate tomorrow morning.
Is there anything last minute I should be doing?
I got my car detailed last weekend (birthday present Smile ) so it looks good, and most grease/oil is gone.
Last night I mounted my computer under the dash (instead of inside glove box)
I'll make sure the car is warm before he gets there (home delivered engineer's certificate!) so it doesn't idle rough.
Does my wiring need to be better?? (hasn't changed since dubbo)
I've got a weight certificate ready, and I've also done an emissions test (I don't know what to make of the numbers though).
Engineer is Phill Scott, who did my brothers 3T KE20.
SupraPete
Re: Before engineer's certificate Tue, 24 June 2003 07:06 Go to previous messageGo to next message
bump.
anyone know? anyone got a certificate knocked back for something specific?
SUPRAGTE
North Sydney
Re: Before engineer's certificate Tue, 24 June 2003 07:11 Go to previous messageGo to next message
There's plenty of things Pete.
Non standard ECU would be the first, just don't let him see it.
What were the CO mixtures in the emissions test?
Its basically a rego check too, battery bracket?
BlackSupra
Re: Before engineer's certificate Tue, 24 June 2003 07:47 Go to previous messageGo to next message
Engine mounts
Gearbox standard or not
Exhaust system
Exhaust volume at a defined rpm level may be checked
If the car is emissions complient
what u want is a low CO and HC levels
Whether or not anything structural has been hacked.
Brakes
They want to be asured that the car with extra power can handle the stopping as well.
Re: Before engineer's certificate Tue, 24 June 2003 09:41 Go to previous messageGo to next message
ya should be fine petey!
It's not like the car has much more power than the old 7M, so things like brakes etc shouldn't be an issue (no turbos!).
As for the wiring - make sure there are no bare connections, i remember seeing one or two... so wrap those up with leccy tape, and cover the birds nest ffs! it's dirty! Razz
Should be all good dude!
SupraPete
Re: Before engineer's certificate Tue, 24 June 2003 13:30 Go to previous messageGo to next message
Thanks guys. I've tried to do everything properly with regards to engine mounts etc.
Gearbox as I've told him has been changed from auto to manual, but was done in Japan before coming here, and is using a gearbox that came out standard in the car. He said that was fine.
Emissions test, I've no idea what these mean, but I know the CO level is bullshit low.
THC 1.95
NOx 2.81
CO 8.8 (didn't register on the scale)
CO2 290.4
Brakes havn't been changed. And weight is now lighter!
Will wait and see.
Karl, I'll see what I can do with the birdsnest.
speakafreaka
Re: Before engineer's certificate Tue, 24 June 2003 13:45 Go to previous messageGo to next message
what were you quoted?
ive asked one place and they wanted $660 for the 1jz MX83 conversion.. anyone know of anywhere cheaper?
do you still have to pay even if they fail you?
Grega
melbourne.victoria.austra...
Re: Before engineer's certificate Tue, 24 June 2003 20:53 Go to previous messageGo to next message
if they fail you, you fix whats wrong, then go back and they give you a report.
SupraPete
Re: Before engineer's certificate Wed, 25 June 2003 23:33 Go to previous messageGo to next message
Very Happy Very Happy
I havn't got the report as yet, as it takes a while to do research on what it all should be (like tyre track, engine emissions etc.) but I'm pretty sure I've passed.
The engineer was excellent. He was the nicest automotive guy I've met to date. He told me exactly what was needed, told me the reasons why, and could see that I had done it. He also does a lot of dealings with court issues and insurance stuff, so he makes sure he checks everything because if something like my engine falls out tomorrow he can be liable. So now I feel safe driving my car (and will do drags next toyonats!)
Things that were standard, he didn't have to check, like my radiator, Power steering.
Brakes he checked and they were fine.
Noise test has to be under 90 dB. My car was 89.7dB!! phew. Apparently V8s come up more on the noise test because they're a lower tone and vibrate things more.
Emissions passed as well. (Paul, I'll tell you more about this at dyno day)
Engineer was Phil Scott 66477558, 0412339242. He actually came to me, and did the looking at my place.
SupraPete
Re: Before engineer's certificate Wed, 25 June 2003 23:37 Go to previous messageGo to next message
Price was $495. BUT price will vary with how many things have changed, and how much they've changed. He does do quotes over the phone though, so go and ask him.
Also he also said my wheels needed to be put on the engineer certificate because they were an inch taller than standard, and the car didn't come out with that size as an option. Please don't debate this here. That is simply what the engineer said.
Ooh, and my pod filter and intake got passed as the extra noise it made didn't go over the limit, and it had passed the emissions test.
Grega
Re: Before engineer's certificate Fri, 27 June 2003 00:24 Go to previous messageGo to next message
hkspete that sounds really good. pod filter and all.
make sure you keep a copy of the cert (laminate it) in the glovebox at all times in case the police stop you.
speakafreaka
Re: Before engineer's certificate Fri, 27 June 2003 09:53 Go to previous messageGo to next message
i wonder if ill pass with my exhaust...
i was quoted $660 from one guy for the cressida, i didnt think that was right.. i need to call some other places
Celica_John
Re: Before engineer's certificate Tue, 18 May 2004 08:57 Go to previous messageGo to next message
will my sr20t with a 3 inch turbo back exhaust pass the exhaust loudness test you think?
from what i hear it needs to be less than 90dB at 4000rpms
EvilJack
Sutho/Hills NSW
Re: Before engineer's certificate Tue, 18 May 2004 22:51 Go to previous messageGo to next message
what year model car?
96db for pre 86 i think
Chris Davey
sunny coast, qld
Re: Before engineer's certificate Tue, 18 May 2004 23:36 Go to previous messageGo to next message
damn that is expensive! I am in qld, and my mod plate for all my mods cost me $170. QUEENSLANDER! Razz
Jag7799
Re: Before engineer's certificate Tue, 18 May 2004 23:47 Go to previous message
120 here Razz
Previous Topic:why 13b turbo illegal in ta22(QLD)
Next Topic:why wont it fire? (4k + dcoe webers)
Current Time: Sat Oct 31 16:23:21 UTC 2026
Total time taken to generate the page: 0.067136764526367 seconds
