Toymods » Tech & Conversions » 18R-G Spark plugs
RA40Celica
Hobart
  chris_rg@jabber.org
18R-G Spark plugs Tue, 24 June 2003 09:56 Go to next message
i did a bit of a search couldn't find anything much,
Just wondering what spark plugs i can run in my 18R-G (9.7:1), are they the same as the 18RC ones?, or different heat?
Chris
celicaboy
Re: 18R-G Spark plugs Tue, 24 June 2003 10:07 Go to previous messageGo to next message
bpr5ey 2 they use they are different to 18rc ones
CelicaRA45
nth ringwood, Victoria
Re: 18R-G Spark plugs Tue, 24 June 2003 10:34 Go to previous messageGo to next message
or w20exu denso
Blaze
Re: 18R-G Spark plugs Tue, 24 June 2003 23:40 Go to previous messageGo to next message
Most places don't have listings for this engine. But I went to a place called autobarn up here in Brisbane and they had a book that listed 4 different types of plugs for the different 18rg's. I'm using BPR5EY-11 but they do list for performance you use a lower heat rating the should be "6".
stradlater
Arthurs Creek, Victoria
Re: 18R-G Spark plugs Wed, 25 June 2003 01:30 Go to previous messageGo to next message
you kidding? you guys have a shop called autobarn up there? that's some crazy stuff.. Never heard of that shop down here.
Wink
sbyder
Ipswich QLD
Re: 18R-G Spark plugs Wed, 25 June 2003 02:59 Go to previous messageGo to next message
NGK B6ES!!!
they are top stuff for that motor. make sure its the non-protrusive tip, it helps to stop detonation.
RA40Celica
Hobart
  chris_rg@jabber.org
Re: 18R-G Spark plugs Wed, 25 June 2003 12:07 Go to previous messageGo to next message
Thanks for your replies
the haynes manual lists bpr6ez or w20exr for 18rg. the bpr6ez wasn't listed at autobarn and Apparently the 'z' is for special?????... so i got the v design at the same heat, bpr6ey (which was the cross reference for the denso w20exr anyway)
Chris
Steve M
Re: 18R-G Spark plugs Wed, 25 June 2003 14:05 Go to previous messageGo to next message
The toyota celica owners manual suggests:
Nippondenso W20EXR
NGK BPR5EZ (I couldn't find these at Sprint Auto Parts, not on the NGK listings they had)
RA28midge
Adelaide and Queenstown T...
Re: 18R-G Spark plugs Thu, 26 June 2003 00:55 Go to previous messageGo to next message
What Ignition Leads does an 18R-G use... anyone. is there another car that uses the same leads? What about the RA40 GT???
I am getting good at this hijacking. Razz
[Updated on: Thu, 26 June 2003 05:23]
Steve M
Re: 18R-G Spark plugs Fri, 27 June 2003 14:29 Go to previous message
For the leads, I've heard these recommended
NGK cables –RC-TE94
Top Gun – HD4446
Sprint Auto Parts can get them made up you, as they just did for us, with the use of your originals for samples.
This took just over a week.
They are Eagle ones and come with a two year, 40000km warranty.
On you could buy any leads with the following lengths.
1 @ 70cm
1 @ 80cm
1 @ 90cm
1 @ 100cm
this works with one 90degree end and one straight end.
Previous Topic:What is the max boost for 1G-GTE
Next Topic:87 soarer questions
Current Time: Thu Nov 19 10:24:22 UTC 2026
Total time taken to generate the page: 0.0079398155212402 seconds
