Toymods » Tech & Conversions » 2t and 2tgeu radiator hose
BOGking
icon5.gif  2t and 2tgeu radiator hose Wed, 25 June 2003 02:43 Go to next message
can the stock 2t radiator hose be MADE to fit the 2tgeu water pump?
could i just go into any shop to find a similar hose and bolt that on? any particular shop i can go to?
thanks.
Mazda626
Perth WA
Re: 2t and 2tgeu radiator hose Wed, 25 June 2003 03:06 Go to previous messageGo to next message
all thats differnt between the 2tg and the 2tgeu is the head larger valves and the comp ratio i shouldnt see why the hose shouldnt fit.
inferno
Re: 2t and 2tgeu radiator hose Wed, 25 June 2003 12:43 Go to previous message
The bottom radiator hoses are the same, but the 2T hose curves when the 2TG hose is straightish.
If your using the 2T thermo housing on your 2TG, which faces towards the intake (or exhaust- depends which way u bolt it on), you could possibly shorten and use the original 2T hose and bend it over the rocker cover. The problem with this is that you have to drain your radiator fluid everytime u want to take the rockercover off!
The other option is to use the genuine 2TG thermo housing which faces forward, and buy a slightly bent hose from a car store (eg repco). Its best to get the slightly bent hose as a straight hose needs to be slightly kinked.
Previous Topic:White/Grey smoke
Next Topic:RA-60 HELP
Current Time: Sun Oct 18 01:24:34 UTC 2026
Total time taken to generate the page: 0.0041630268096924 seconds
