Toymods » Tech & Conversions » 1jzgte turbo
Msta
1jzgte turbo Thu, 26 June 2003 03:21 Go to next message
what turbo's bolt straight on with little modification to the 1jzgte manifold ? any help would be appriciated
Re: 1jzgte turbo Thu, 26 June 2003 07:04 Go to previous messageGo to next message
none that I'm aware of
that's why most people try and get the most out of their stock turbos (with boost, rebuilds, etc), or just go straight for big aftermarket with custom manifold
Celia-Sue
Re: 1jzgte turbo Thu, 26 June 2003 07:38 Go to previous messageGo to next message
From the Cypher Industries (WA) web page:
www.cypherindustries.com.au/
Toyota Soarer JZZ30 with 1JZ-GTE 2.5L Twin Turbo Engine High Flow Turbos (pair). Replacing of Ceramic Turbines with Steel Units and Larger Compressor Wheels. Comp Wheel Inducer 2mm Larger, Exducer 4mm Larger. $2,530.00
That's about the cheapest power-up you're going to get without having manifolds fabricated, going to the big single, etc.
Msta
Re: 1jzgte turbo Fri, 27 June 2003 00:41 Go to previous messageGo to next message
what about the 2jz turbo's will they fit ?
Chris Davey
sunny coast, qld
Re: 1jzgte turbo Fri, 27 June 2003 02:49 Go to previous messageGo to next message
not with the 1jz standard manifold.
Msta
Re: 1jzgte turbo Fri, 27 June 2003 03:13 Go to previous messageGo to next message
will the 2jz manifold fit ?
E30-323ti
Re: 1jzgte turbo Fri, 27 June 2003 03:27 Go to previous messageGo to next message
Jap Spec 2JZ turbos still have ceramic turbines.
They would fit if you machined the 1JZ turbine housings to suit as they bolt on stock.
I heard a rumour that some turbo surfs have CT12B's with steel turbines, they fit into 1JZ CT12A comp & turbine housings once they are machined to fit the bigger wheels.
Can anyone confirm this??
Re: 1jzgte turbo Sat, 28 June 2003 07:59 Go to previous messageGo to next message
2JZ manifolds will not fit on a 1JZ head.
thunderbird1
Sydney Australia
Re: 1jzgte turbo Sat, 28 June 2003 16:57 Go to previous messageGo to next message
will a 2J head bolt on a 1J block hehehe...???
i know a 1J head will fit a 2J block Smile
Re: 1jzgte turbo Sun, 29 June 2003 05:03 Go to previous message
Yes it will, but I can't see the point! Might as well swap in a whole 2JZ if you're going to all that trouble.
Previous Topic:Need pretty urgent help!
Next Topic:Att: All sprinter owners
Current Time: Tue Oct 27 07:58:04 UTC 2026
Total time taken to generate the page: 0.0044689178466797 seconds
