Toymods » Tech & Conversions » 2JZGE piston comparison (with pics)
2JZGE piston comparison (with pics) Thu, 26 June 2003 05:01 Go to next message
I suspect I'm talking to myself but anyway.....
As some of you may know, the 2JZGE VVTi motor has 10.5:1 CR versus the non VVTi motor at only 10:1. How did it achieve this?
I bought a VVTi piston from Toyota and checked.
Here are the crowns (VVTi piston on the right):
http://members.optusnet.com.au/gianttomato/JZX23/2JZGE%20piston%20comparison%20crowns.jpg
and here are the skirts (VVTi on the right):
http://members.optusnet.com.au/gianttomato/JZX23/2JZGE%20piston%20comparison%20skirts.jpg
As you can see the dish is slightly deeper in the VVTi piston, but the valve reliefs are much shallower, in particular the exhaust valve flycuts. The VVTi motors run about 2mm less lift than the non VVTi motors.
The side view shows that they share the same compression height and gudgeon pin diameter (22mm). The ring lands are about 1.5 mm higher up on the VVTi motor, but the most interesting thing is the much shorter skirt on the VVTi motor and significantly lighter weight (358 vs 384 grams).
I'll be popping one into a test block I have and will see if the valves clash with the pistons.
Hope this is handy info for someone.
Cheers Dave.
[Updated on: Thu, 26 June 2003 05:02]
rob_RA40
c'town, NSW
Re: 2JZGE piston comparison (with pics) Thu, 26 June 2003 05:21 Go to previous messageGo to next message
Dave im thinking Ed will want this on his website.. Razz
Re: 2JZGE piston comparison (with pics) Thu, 26 June 2003 05:39 Go to previous messageGo to next message
Hehehe....yep it's being written as we speak. I have some more pics too.
I wanted the other 5 pistons but get this, the Lexus boys told me Holden have been buying them for some 'special project'!
http://board.performanceforums.com/forums/images/smilies/wtf.gif
rob_RA40
c'town, NSW
Re: 2JZGE piston comparison (with pics) Thu, 26 June 2003 06:17 Go to previous messageGo to next message
well thats certainly interesting.. are we talking holden holden, or just holden enthusiasts?
and what holden engine has bore near/same as 86mm?
Re: 2JZGE piston comparison (with pics) Thu, 26 June 2003 07:45 Go to previous messageGo to next message
They were saying Holden as in GMH! I looked thru the ACL catalogue and the only thing that's close is the RB30 and the Astra/Vectra motors, but they're a lot shorter in the compression height.
So I am stumped.
hydro
Re: 2JZGE piston comparison (with pics) Thu, 26 June 2003 10:23 Go to previous messageGo to next message
Holden's new V6 is due for series 2 VY Commodore. Ok, before you read this, make sure you're sitting down.
It will be a 4 valve quad cam all alloy motor. Wow, Holden will finally be using technology from the second half of last century. I'm sure some things will stay the same though, and like all Holden 6 cylinders it'll come with factory fitted oil leaks. (Holden - leading the world in oil-less engine technology)
But seriously, it's supposed to be built in versions from 2.8 litres to 3.8 litres. Just a guess but maybe it has something to do with that motor?
ed_ma61
Lost in the K hole
Re: 2JZGE piston comparison (with pics) Thu, 26 June 2003 10:30 Go to previous messageGo to next message
rob_RA40 wrote on Thu, 26 June 2003 15:21
smartass...
but youre right Very Happy
Very Happy
dave, ill be down again from the 15th july to the 20th
would be really good to catch up and sink some vino
ed
Re: 2JZGE piston comparison (with pics) Thu, 26 June 2003 10:39 Go to previous messageGo to next message
hydro wrote on Thu, 26 June 2003 20:23
I should have sat on the ground! Good stuff.
Dave, it might be possible that's what they are doing, but you'd think they'd have nutted that out by now!
Ed, no probs dude. Go out for nosh or something.
Soarer
Wollongong
Re: 2JZGE piston comparison (with pics) Thu, 26 June 2003 11:14 Go to previous messageGo to next message
Does anyone recall the document on the laptop at Garrett labelled "Holden 3.2L Turbo.doc" ?
I think there's something to think about...
Re: 2JZGE piston comparison (with pics) Fri, 27 June 2003 00:53 Go to previous messageGo to next message
The new engine for the Commodore is going to be pretty awesome. Its already being used in one spec for the current Rodeo, and it was used in some Isuzu concept car, and that was quick!
They are tipping a 200kW output for the Executive...now that would be different! Especially if they can keep the weight advantage over the Falcon...although they could REALLY do with some decent suspension.
ed_ma61
Lost in the K hole
Re: 2JZGE piston comparison (with pics) Fri, 27 June 2003 01:12 Go to previous messageGo to next message
gianttomato wrote on Thu, 26 June 2003 15:01
... the valve reliefs are much shallower... (but)they share the same compression height..
hmmm...insalled with - decked head, long duration big lift cam, me smells problems Sad
ed
E30-323ti
Re: 2JZGE piston comparison (with pics) Fri, 27 June 2003 03:34 Go to previous messageGo to next message
Does the VVTi piston have just as much meat in the top of the piston as the non-VVTi one??
If so could you enlarge the flycuts with out comprimising the piston???
Re: 2JZGE piston comparison (with pics) Fri, 27 June 2003 03:40 Go to previous messageGo to next message
Yep not wrong, I expect there to a clashing of metal.
I also have to measure my combustion chamber volume - I know the VVTi CCV is 41.6 mL. I found this great site that had this data in pdf files (only certain motors though)!
http://grandamerican.com/grandamcup/rules_pdf/
E30, I hope I can. Am taking the piston to some piston guys to see if it is possible.
[Updated on: Fri, 27 June 2003 03:41]
E30-323ti
Re: 2JZGE piston comparison (with pics) Fri, 27 June 2003 03:51 Go to previous messageGo to next message
Good luck.
Is that a KBW version of what the Mayor of Hiroshima said!!
hydro
Re: 2JZGE piston comparison (with pics) Fri, 27 June 2003 05:31 Go to previous messageGo to next message
BTW GT, how did things work out with you're 2JZGE?
ed_ma61
Lost in the K hole
Re: 2JZGE piston comparison (with pics) Fri, 27 June 2003 06:41 Go to previous message
gianttomato wrote on Fri, 27 June 2003 13:40
dave, you have any idea what kind of piston/valve/head clearances you can run with the 2jz?
ive been told (confidently) 0.035" on the 7M, but are the 2j rods any better?
ed
Previous Topic:front brake upgrade 4 corona st141
Next Topic:5S-FE Gearboxes
Current Time: Thu Nov 19 06:20:09 UTC 2026
Total time taken to generate the page: 0.0066127777099609 seconds
