Toymods » Tech & Conversions » Throttle Position Sensor Help Needed
djshady
Throttle Position Sensor Help Needed Thu, 26 June 2003 11:50 Go to next message
THROTTLE POSITION SENSOR
Part # 89452-12040
Denso Part# 198500-0330
I believe these are fitted to MR2 Turbo's and Celica GT4's aswell as a few other Toyota cars.
Does anyone have a workshop manual with
diagrams/electrical specs/info for these TPS's ???
Any help greatly appreciated. Very Happy
Drift pig
Re: Throttle Position Sensor Help Needed Fri, 27 June 2003 00:37 Go to previous messageGo to next message
That part number fits heaps of cars, early camrys, st185 celica st164 celica, corolla, mr2 and early tarago. what do you need to know, tell me and will see if i can find out
djshady
Re: Throttle Position Sensor Help Needed Fri, 27 June 2003 11:40 Go to previous messageGo to next message
I am after some info like this:
http://homepages.ihug.com.au/~djshady/Pix/tps.JPG
This is TPS Denso Part #198500-0310
Daihatsu Part #89452-87703 (I think, close enough)
I think there is a Toyota one with exact same specs and perhaps slightly different harness connector. This is what I am trying to work out
djshady
Re: Throttle Position Sensor Help Needed Sun, 29 June 2003 21:34 Go to previous messageGo to next message
Can anyone post info up like this for the Toyota TPS???
Part # 89452-12040
Re: Throttle Position Sensor Help Needed Mon, 30 June 2003 07:05 Go to previous messageGo to next message
Shady_GTti wrote on Mon, 30 June 2003 07:34
Part # 89452-12040
i have a 22RE TPS, but i think it is 89452-12010 or 12020. i will get readings from it tonight.
does anyone have one of those EFI books that have specs for heaps of cars? would probably be in there.....
djshady
Re: Throttle Position Sensor Help Needed Mon, 30 June 2003 11:18 Go to previous messageGo to next message
I was hoping someone would have a Toyota workshop manual applicable to one of these cars with the info like above pic.
Drift pig
Re: Throttle Position Sensor Help Needed Mon, 30 June 2003 11:42 Go to previous messageGo to next message
I will check the workshop manuals at work tomorow and get the info you need. Smile
djshady
Re: Throttle Position Sensor Help Needed Mon, 30 June 2003 12:12 Go to previous messageGo to next message
Sweet! That would be excellent.
What I am trying to do is replace the Daihatsu one I have with a commonly available one here. I need it to fit the throttle body and the Toyota part number I have listed is almost identical but I dont know the specs! I guess any Toyota TPS with same design/mounting and specs as the Daihatsu one would do.
I'm running a factory ECU at the moment till I can afford an E6K,M4, SMC or SM2 ECU.
djshady
icon9.gif  Re: Throttle Position Sensor Help Needed Mon, 07 July 2003 15:07 Go to previous messageGo to next message
*BUMP*
Anybody??? Crying or Very Sad
Re: Throttle Position Sensor Help Needed Tue, 08 July 2003 03:45 Go to previous messageGo to next message
22RE
denso number: 89452-28030
1-4: 7.15k ohms
1-2: 15-35 ohms depends on TPS alignment
3-4 closed: 7k ohms
3-4 WOT: 1.55kohms
it looks visually identical to the pic above, and deosn't have a D-shaft connection...
does this help??
Re: Throttle Position Sensor Help Needed Tue, 08 July 2003 03:48 Go to previous messageGo to next message
oh, and the ND number is : 198500-0200
also says Throttle Sensor, P125 Toyota, and made in Japan....
no other identifiers, and the locking screws are 50mm apart
djshady
Re: Throttle Position Sensor Help Needed Tue, 08 July 2003 08:20 Go to previous message
Thanks very much Stewart! Very Happy Very Happy Very Happy
Now if someone has info in this baby:
Part # 89452-12040
I think this unit is indentical to mine except I think connector is reversed.
Previous Topic:1ZZFE or 2ZZGE in RWD config
Next Topic:Sump damage
Current Time: Mon Nov 2 10:53:46 UTC 2026
Total time taken to generate the page: 0.15412402153015 seconds
