Toymods » Tech & Conversions » Headlights problem
Chris-008
Headlights problem Sun, 29 June 2003 05:19 Go to next message
headlights on my sprinter, right is brighter than the left, like theres only half the power going through the left. What could it be, bulbs are brand new.
thnks
Chris
pedroenglish
Re: Headlights problem Sun, 29 June 2003 05:35 Go to previous messageGo to next message
You would need to check volts at each lamp socket before you can say where the fault is. If voltage is the same the problem is the lamp. Most likely the voltage is different and the faullt is a bad connection eg Lamp connector, earth or interconnect to power.
If you suspect the lamp, swap them; the fault will follow the bad 'un.
Pedro
BansheeBuzz
Gold Coast
Re: Headlights problem Sun, 29 June 2003 08:18 Go to previous messageGo to next message
this is a common symptom of when a fuse blows on a toyota. Check your fuses and garanteed the fuse for the left side is blown
Chris-008
Re: Headlights problem Sun, 29 June 2003 09:03 Go to previous messageGo to next message
wow cool... everything fixed
thanks for the prompt reply
Re: Headlights problem Sun, 29 June 2003 09:07 Go to previous messageGo to next message
What was the problem?
Les
so what was the prob dude ? fuse ? Rolling Eyes
Previous Topic:3T-GTE head gasket
Next Topic:help diff ratios
Current Time: Fri Nov 20 23:12:19 UTC 2026
Total time taken to generate the page: 0.0070810317993164 seconds
