Toymods » Tech & Conversions » 18rg pistons in 18rc
munki
Gold Coast
18rg pistons in 18rc Sun, 29 June 2003 08:30 Go to next message
Tomorrow my engine is getting a semi rebuild, well the beginnings of one anyway and im going to check the bottom end out if i pull the pistond out i was wondering if any of the higher compression pistons fit without any valve clearence issues. Do they even fit on at all? are they the samt sized piston? fit on the same connecting rod?
Daniel.
munki
Gold Coast
Re: 18rg pistons in 18rc Sun, 29 June 2003 09:13 Go to previous messageGo to next message
cmon! i dont wanna go buy some to see if they fit whats the point of that Razz
TA22-3SGTE
MACKAY
Re: 18rg pistons in 18rc Sun, 29 June 2003 09:21 Go to previous messageGo to next message
No they won't fit as the 18rg pistons have a tall crown compared to the 18r which is a flat top.
Trevor
munki
Gold Coast
Re: 18rg pistons in 18rc Sun, 29 June 2003 09:38 Go to previous messageGo to next message
arent there pistons with slight domes from an 18rg im sure ive seen them somewhere. they would raise the compression. or am i missing the point.
_____________________
1 1
- standard 18rc
__________________
/__________________\
1 1
- 18rg high comp (with recesses
for valves no fitting)
__slight dome__
1 1
will these fit?
munki
Gold Coast
damnit stupid text thing.
TA22-3SGTE
MACKAY
Re: 18rg pistons in 18rc Sun, 29 June 2003 10:02 Go to previous messageGo to next message
The 18rg has a hemi head , the piston crown sticks out of the top of the block and up into the combustion chamber , The head on the 18r has not got the hemi style combustion chamber and if the piston sticks out the bore any more than about .035" it will hit the head .
Trevor
earlyrolla
Re: 18rg pistons in 18rc Sun, 29 June 2003 13:01 Go to previous messageGo to next message
The dome would need to mirror the shape of the combustion chamber. For example have a look at a set of hi-kickers for a chev or ford motor.
Never seen any off-the-shelf ones for an 18R motor though. They would probably have to be custom made. Waste of time, might as well just get an 18RG.
If you want to raise compression, see how far you can safely shave the head Very Happy
Re: 18rg pistons in 18rc Sun, 29 June 2003 13:18 Go to previous messageGo to next message
yup, spot on earlyrolla!
easier to shave 18R head (while watching out for valve-clearance issues) or bolt a turbo on it and grind out the head to lower compression (like i did).
you could also deck the block but once the piston crown starts to show, you run into the same valve-clearance problem.
If you go (potentially expensive) non standard pistons, make sure addesss any issues about gudgeon pins and balance if the custom jobs are different in weight to the std jobs.
the turbo's also an expensive route as you have to make lost of custom stuff. The RG's a cheaper route and it also has opportunities for hi-comp or turbo.
best-o-luck,
thechuckster.
munki
Gold Coast
Re: 18rg pistons in 18rc Mon, 30 June 2003 01:30 Go to previous message
hmmm no pistons for me then. does anyone know the maximum permissable lift on the stock valves?
Daniel
Previous Topic:Engineering cert
Next Topic:Help me obi-wan, your my only hope
Current Time: Sat Nov 21 02:48:44 UTC 2026
Total time taken to generate the page: 0.0094699859619141 seconds
