Toymods » Tech & Conversions » Detonation Problem
Karl_skewes
New Zealand
Detonation Problem Mon, 01 July 2002 09:01 Go to next message
Alright, some sort of crazy stuff is going down with my 2TGEU in my KE35. Being quite a few 2TG gurus on here, so I thought I'd ask.
Engine detonates above 2400rpm.
Example:
Changed to cleaned injectors, turned on car, drove down the road. no problem. Smelt petrol, turned off car, all hoses were on sweet, probably just fuel dropped from when changing injectors. Turned back on car, and then it pinged again.
I can't see any loose wires around the fuel hose area.
Things I've tried:
Different AFM, computer, injectors, coil, changing base timing - +12 -> -5 deg.
I'm guessing it must be something in the wiring which is gonna take a long time to diagnose, so I'm thinking of taking the car to an auto electrician this week.
Any thoughts? Freak
Karl
SUPRAGTE
North Sydney
Re: Detonation Problem Wed, 03 July 2002 10:14 Go to previous messageGo to next message
I take it it is the same tank of fuel as before it started pinging? If not i'd drop the tank and get some fresh fuel to eliminate that first.
Secondly it sounds like you changed or cleaned the injectors.
This is most like your prob. One of the injectors isn't opening and is giving a very lean(lean = very detonation friendly) mixture in the cylinder.
Put your finger on each injector and you should be able to feel them clicking. If not then this should be your prob injector,
give it a go.
Let me know, i'm interested.
Karl_skewes
New Zealand
Re: Detonation Problem Thu, 04 July 2002 12:59 Go to previous messageGo to next message
Okay, turns out it was just a rattle.
but, fwiw:
I have drained fuel tank.
Injectors were ultrasonically (i think) cleaned and flow tested between 205-220cc.
Karl
TE72_Turbo
Re: Detonation Problem Fri, 05 July 2002 11:26 Go to previous messageGo to next message
ha! i've had exactly the same problem, but in my g/f's pulsar. it appeared to be detonating from 3500rpm, but it was the lid of the airbox rattling with the intake resonance!
Phil
SUPRAGTE
North Sydney
Re: Detonation Problem Mon, 08 July 2002 10:04 Go to previous message
I love hearing about fixes like those. Instead of being some massive expensive mechanical issues. Takes alot of stress out!
Previous Topic:Air/Fuel ratio
Next Topic:The GT-Four is undergoing surgery...
Current Time: Mon Oct 26 13:46:57 UTC 2026
Total time taken to generate the page: 0.054749011993408 seconds
