Toymods » Tech & Conversions » silicone elbows:: where from, and alternatives ??
ed_ma61
Lost in the K hole
icon4.gif  silicone elbows:: where from, and alternatives ?? Mon, 30 June 2003 06:37 Go to next message
im after some 3" ID 90deg and 45deg elbows. anyone know who/where i might be able to get some silicone ones from, and how much im looking at?
alternatively - this isnt a boosted application, and silicone is probably way overkill, so does anyone have any ideas as to another way of joining 3" induction pipe? like i said - in 90deg and 45deg angles?
ed
Re: silicone elbows:: where from, and alternatives ?? Mon, 30 June 2003 06:46 Go to previous messageGo to next message
I brought mine from GCG turbo they carry nearly ever elbow possible, but very expensive.. Over $60 for most of them and up to $100 from memory.
I found truck places (Truckline is one of them), carry lots of this kind of stuff also for 1/4 of the price. The guy I was talking to said most trucks all use mandrel bends and stuff and they have access to it all.
Joel
Laurie D
Re: silicone elbows:: where from, and alternatives ?? Mon, 30 June 2003 06:50 Go to previous messageGo to next message
AVO in Melbourne. 03 95834499. They have them but they won't be cheap. They probably have an agent in Sydney somewhere. Have you thought of using a steel bend from an exhaaust shop with straight rubber or silicon connectors? You'd need them to swage the ends for you.
Laurie D
ed_ma61
Lost in the K hole
Re: silicone elbows:: where from, and alternatives ?? Mon, 30 June 2003 06:56 Go to previous messageGo to next message
laurie,
thats alterntive #1 : simply using mandrel bends, and making the joins along the straights. however, i thought that having the flexible bits at the corners might give me more installation flexibility, and also, would allow more degrees of freedom in engine movement (ie intake can flex in more planes).
truckline sounds like it might be a goer - i really dont thnk i need silicone, just some regular intake bends...
ed
[edit: i used google Laughing ]
[Updated on: Mon, 30 June 2003 06:57]
Re: silicone elbows:: where from, and alternatives ?? Mon, 30 June 2003 07:01 Go to previous messageGo to next message
i just bought some ilicone tubing from AVO, and they posted up (by Aus Air express.... i can't stand them....)
anyway, it was red 2" diameter and cost $6 per inch
the brand on the tube is SAMCO SPORT, which i think it a british mob, they have listings of all available sizes on their site (below) and AVO should be able to get them in, or have them in stock..
http://www.samcosport.com/
standard hose can take 170 deg C, but there is a high temp hose that can take 250 deg C.
when i rang around sydney places, they all said they got their kits straight from AVO (and then add their little bit on top)
10sec_rx7
Syndey
Re: silicone elbows:: where from, and alternatives ?? Tue, 01 July 2003 03:36 Go to previous messageGo to next message
motor sport connections at seven hills behind hungry jacks has them all in stock, they have every connector you could ever want
ed_ma61
Lost in the K hole
Re: silicone elbows:: where from, and alternatives ?? Tue, 01 July 2003 04:09 Go to previous messageGo to next message
10sec_rx7 wrote on Tue, 01 July 2003 13:36
now that sounds like a goer - close by too. thanks
10sec_rx7
Syndey
Re: silicone elbows:: where from, and alternatives ?? Tue, 01 July 2003 04:12 Go to previous messageGo to next message
yep you can go nuts in that shop, every speedflow fitting ever made and braided lines as far as you can see, definatly boner material!!
ed_ma61
Lost in the K hole
Re: silicone elbows:: where from, and alternatives ?? Tue, 01 July 2003 04:19 Go to previous messageGo to next message
any idea if theyd have non-silicone elbows by any chance? ie: like simple black rubber oem elbows and intake connectors??
in 3" ID
ed
10sec_rx7
Syndey
Re: silicone elbows:: where from, and alternatives ?? Tue, 01 July 2003 04:21 Go to previous messageGo to next message
no not that im aware of, we can do you one in aliminium or stainless if you wish, will be a lot cheaper the stainless will be around the $45 mark and the alloy about $65
Dale
ed_ma61
Lost in the K hole
Re: silicone elbows:: where from, and alternatives ?? Tue, 01 July 2003 04:30 Go to previous messageGo to next message
thanks a lot for the offer...
ill have to figure out exactly what im going to do now. but i suspect a fully welded assembly may be the go with a single straight flexible connector.
ill let you know, and thanks agin.
ed
10sec_rx7
Syndey
Re: silicone elbows:: where from, and alternatives ?? Tue, 01 July 2003 04:40 Go to previous messageGo to next message
no worries mate, if you want one done just shoot me a PM
Dale
crostek
Oyster bay NSW
Re: silicone elbows:: where from, and alternatives ?? Tue, 01 July 2003 04:56 Go to previous messageGo to next message
Try Donaldson they make the bends for trucks in rubber.
MS-75
Re: silicone elbows:: where from, and alternatives ?? Tue, 01 July 2003 05:23 Go to previous message
You can get 3 inch, 4 inch etc rubber elbows from truck exhaust/intake places usually. I just bought 3 3 inch 90 deg truck elbows, and at $17 dollars, as compared to 100+ for silicon the choice was easy (can get 45 deg too). Especially when you are doing it for non-turbo applications.
Here in adelaide the place to go is Diesel Exhaust Systems, and I'm sure there are comparable joints all major cities. Just look up truck ehaust systems in the yellow pages and start ringing around.
Take it easy
Sean
Previous Topic:Simple Ae86 wheels size question...
Next Topic:Cam restrictions on EFI?
Current Time: Wed Oct 21 02:55:42 UTC 2026
Total time taken to generate the page: 0.0057330131530762 seconds
