Toymods » Tech & Conversions » 1JZ inlet manifold removal
HedgehogSandwich
UK
1JZ inlet manifold removal Mon, 30 June 2003 21:24 Go to next message
Hi all
Ive been busy polishing my pipes and cam covers, but the only thing left is the inlet manifold.
How big a job is it to remove the inlet manifold and replace? Im okay with a spanner but im no mechanic (ive replaced the turbos before though).
Is it an easy task to take on? As you can see it doesnt quite match the polished bits Very Happy
http://toyotaimportsforum.co.uk/forum/attachment.php?s=&postid=13233
adi
[Updated on: Mon, 30 June 2003 21:24]
Re: 1JZ inlet manifold removal Tue, 01 July 2003 02:05 Go to previous messageGo to next message
Wow! That is shiny. Basically what I was told is that you can remove it, but you have to make sure it is replaced with the correct torque settings and in the correct order....so I haven't done it Razz
By the way, that was for a 1GGTE, but the principle would be the same.
[Updated on: Tue, 01 July 2003 02:05]
HedgehogSandwich
UK
Re: 1JZ inlet manifold removal Wed, 02 July 2003 11:07 Go to previous messageGo to next message
Cheers Frank..
Anybody else? Someone must have done this somewhere..
wastegate
Gold Coast
Re: 1JZ inlet manifold removal Fri, 04 July 2003 05:19 Go to previous messageGo to next message
It's ALOT harder than a 2JZ but not as hard as a 7M. Very Happy
Basicaly the bolts that bolt it to the lower runners are hard to see with the engine in the car. Once you have disconnected all the vac lines it's fairly straight forward. I took off the throttle body first as well.
Once you have done that everything going ok you should have something that looks like this
http://www.jzgte.com/~nickc/albums/polishedpipes/DSC00002.sized.jpg
HedgehogSandwich
UK
Re: 1JZ inlet manifold removal Fri, 04 July 2003 13:19 Go to previous message
cheers Very Happy but do the bolts have to be torqued to a specific setting and/or in the correct order when refitting?
Previous Topic:chaser wiring?
Next Topic:American Rollas
Current Time: Fri Nov 20 16:26:10 UTC 2026
Total time taken to generate the page: 0.010393857955933 seconds
