Toymods » Tech & Conversions » 3tgte stroked to 2ltrs.
ta22celica_boy
icon5.gif  3tgte stroked to 2ltrs. Tue, 01 July 2003 00:15 Go to next message
i was wonderin if it was possible get a custom crank to stroke the 3tgte, to try and stop the turbo lag. im lookin at getting a gt30/35 or gt40. im goin be doin the usual things like forgie pistons,etc. also can you get a metal head gasket for the 3tgte and how much?
thanks for the help josh
[Updated on: Tue, 01 July 2003 00:26]
t_temperley
Re: 3tgte stoked to 2ltrs. Tue, 01 July 2003 00:24 Go to previous messageGo to next message
oversized pistons(3.5 mm i think?)gives pretty close 2 litres.
t_temperley
Re: 3tgte stoked to 2ltrs. Tue, 01 July 2003 00:26 Go to previous messageGo to next message
No Message Body
Purple_Beasty
New Zealand
Re: 3tgte stoked to 2ltrs. Tue, 01 July 2003 00:27 Go to previous messageGo to next message
If your going forged pistons anyway I would bore it rather than stroke it. Could also do both, just get the crank offset ground slightly. Would then need undersize bearings, not sure on availability.
Callum
ta22celica_boy
Re: 3tgte stroked to 2ltrs. Tue, 01 July 2003 00:28 Go to previous messageGo to next message
yeah i know you can get oversized pistons but wouldn't that raise the compression?, unless i used a decompression plate
Purple_Beasty
New Zealand
Re: 3tgte stroked to 2ltrs. Tue, 01 July 2003 00:32 Go to previous messageGo to next message
Difference to compression ratio would be minimal, and pin height on pistons could be set to suit whatever compression ratio you want. Shorter stroke to bore ratio also gives more revability.
Callum
shinybluesteel
melbourne
Re: 3tgte stroked to 2ltrs. Tue, 01 July 2003 01:55 Go to previous messageGo to next message
if you dont want lag, i would suggest using something a little bit smaller than a gt40. Rolling Eyes
generally the way to avoid lag is to use a correctly sized turbo.
earlyrolla
Re: 3tgte stroked to 2ltrs. Tue, 01 July 2003 03:07 Go to previous messageGo to next message
If you really want such a big turbo, why not go twin charged?
Eg SC14 to provide low down boost and help spool up turbo, and turbo only for high boost. OR you could run anti-lag.
Anti-lag is really only suitable for race cars, and I tend to agree with shinybluesteel. Just use a correctly sized turbo to begin with. The giant turbo thing is a bit of a wank factor for street cars.
If you are getting forged pistons, just get ones with a deeper dish to lower compression. Once you start playing with decomp plates and changing gudgeon heights, it completly stuffs squish height. Squish height is important to preventing detonation. I.e. you may have lowered the compression but the increased squish height also increased the likelihood of detonation anyway.
Custom cranks aren't cheap (probablt 3G plus). And you are better off with a shorter stroke at higher revs.
ta22celica_boy
Re: 3tgte stroked to 2ltrs. Tue, 01 July 2003 23:55 Go to previous messageGo to next message
so would be better just to get the forgies that are over size and have a deeper dish and look at getting a gt28, gt30 how much kw would you think the 3tgte would be able push? it has an ems, want to get a custom plenum and exhaust manifold and properly tuned of course
thanks for the advice fellas, josh
inferno
Re: 3tgte stroked to 2ltrs. Wed, 02 July 2003 00:03 Go to previous message
just a suggestion, i mate has bored his 3TGTE to around 2L and used hepatite gemini 2L pistons, i would think this would be a cheap mod for extra power, also reduced the compression down to around 7:1, perfect for any high boost application. i don't have many details, just knew he used standard rods, and left the HG the stock bore size otherwise they apparently blew all the time.
Previous Topic:3sge to t50 bellhousing?
Next Topic:1UZ bits
Current Time: Sun Oct 25 08:58:19 UTC 2026
Total time taken to generate the page: 0.0045809745788574 seconds
