Toymods » Tech & Conversions » 1J Spark Plugs / Gap ?
Manny
1J Spark Plugs / Gap ? Mon, 01 July 2002 11:07 Go to next message
All
As the subject says, what spark plugs do you recommend for a mildly worked over 1J and what gap do you recommend from experience.
Needs to reliably handle 12 to 18 psi boost and 200+ rwkw.
Seems to be a common problem on 1Js - someone should have it sussed by now.
Thanks in advance
lumpy
Adelaide, SA
Re: 1J Spark Plugs / Gap ? Mon, 01 July 2002 11:34 Go to previous messageGo to next message
The guy at Toyota recommended 0.8 mm, he said any longer and they can flame out. I've got them at 0.8 mm and they work OK but my 1jz is stock as a rock.
thunderbird1
Sydney Australia
Re: 1J Spark Plugs / Gap ? Mon, 01 July 2002 14:15 Go to previous messageGo to next message
0.028 i gap mine to.
KING_J
Re: 1J Spark Plugs / Gap ? Tue, 02 July 2002 00:33 Go to previous messageGo to next message
NGK BKR6E gapped at 0.028" and you will have no problems.
Do NOT WASTE your money on Platinum plugs.
Manny
Re: 1J Spark Plugs / Gap ? Tue, 02 July 2002 08:22 Go to previous messageGo to next message
Thanks guys.
Recommendations so far are:-
Nippon Denso PK20R 8 gapped to 0.9mm
Halo H-9A's gapped to 0.9mm
NGK BKR6EP-8 gap to 0.9mm
NGK BKR6E gapped at 0.028"/~0.71mm
Unknown gapped to 0.028"/~0.71mm
Standard gapped to 0.8mm
I hope my calculation of 0.028" to ~0.71mm is about right.
Advice against Platinum plugs seems to be pretty universal. Would this mean that normal plugs would need to be changed more regularly than platinum ones and if so at what frequency?
There seems to be two distinct trains of thought on gapping (assuming my imperial to metric calcs are accurate), 0.9 mm or 0.7mm as well as the standard 0.8mm. Can anyone explain the theory/experience behind the gap differences? Will fuel RON impact the recommended gap?
Anyone else with input? The Halo's come very highly recommended with apparent considerable performance gains and fuel economy improvement.
Soarer
Wollongong
Re: 1J Spark Plugs / Gap ? Wed, 03 July 2002 00:58 Go to previous message
The sticker on my Soarer says 1.1mm gap ... just to throw another number into your confusion.
There are varying specs from 0.8mm to 1.1mm that I've seen. I'm currently running BKR6E plugs at 0.8mm gap without a problem.
The issue with spark plugs is that if they are open too wide, you will get misfiring. If the gap is smaller, it will prevent misfire, but at a cost to performance/power. Running a smaller gap than factory spec is usually a case of trying to hide a problem that is there without actually fixing the problem.
Our problem in Australia is the rarity of decent high octane fuel (Soarers require 100RON), so I would suggest around 0.8-0.9mm gap due to the lower octane rating of our fuel.
Previous Topic:Ignition Coil??
Next Topic:turbo help
Current Time: Tue Oct 27 05:19:45 UTC 2026
Total time taken to generate the page: 0.021732091903687 seconds
