Toymods » Tech & Conversions » Toyota 'M' Series History Tech Article
ed_ma61
Lost in the K hole
Toyota 'M' Series History Tech Article Tue, 01 July 2003 12:08 Go to next message
check this out:
beautifully written by the talented mr rob_ra40. very interesting, well compiled and, definitely worth a read...
http://www4.tpgi.com.au/users/loats/technical/7mge /mhistory.html
thanks rob!
ed
turbovan
Kenthurst, Sydney
Re: Toyota 'M' Series History Tech Article Tue, 01 July 2003 12:31 Go to previous messageGo to next message
not a bad read Cool
STR8 2.8
Re: Toyota 'M' Series History Tech Article Tue, 01 July 2003 12:39 Go to previous messageGo to next message
check out the pics...
turbo 5me Shocked
Re: Toyota 'M' Series History Tech Article Tue, 01 July 2003 12:41 Go to previous messageGo to next message
Yes. More interesting was being in the car powered by that engine. I had never been perpendicular to the road at 100 kph uphill before.
Re: Toyota 'M' Series History Tech Article Wed, 02 July 2003 00:29 Go to previous messageGo to next message
Well done dude, told you it was awesome. Nice choice of title image too Wink
rob_RA40
c'town, NSW
Re: Toyota 'M' Series History Tech Article Wed, 02 July 2003 03:00 Go to previous messageGo to next message
YAY Cool
TheStitt
Membership Secretary
Re: Toyota 'M' Series History Tech Article Wed, 02 July 2003 09:13 Go to previous messageGo to next message
Great article Rob. Loved the GT2000 pics thanks for doing that.
hydro
Re: Toyota 'M' Series History Tech Article Thu, 03 July 2003 06:44 Go to previous messageGo to next message
Great article, thanks for the effort putting it together.
A lot of people seem to bag the 7M, or dismiss it cause it blows head gaskets, or spun big ends, etc. I haven't played with the JZ motors, but I realize they seem to have a good reputation.
But having worked on lots of motors before (admittedly lots of push-rod shit), I reckon people don't know how good they've got it. Its got a great 4 valve head, nearly bulletproof bottom end, AND unlike a lot of motors is very easy to work on.
Obviously there are better motors out there, but the M series is pretty good nonetheless.
Dave
rob_RA40
c'town, NSW
Re: Toyota 'M' Series History Tech Article Thu, 03 July 2003 07:57 Go to previous messageGo to next message
thanks for the kind words guys, it may perhaps spur me on to do another history article. Any suggestions?
coronamark2
Re: Toyota 'M' Series History Tech Article Thu, 03 July 2003 08:27 Go to previous messageGo to next message
As some of you may know i have a 4m, the pictures in that article show the 4m but my rocker cover is completly diferent
its flat on the top and has TOYOTA raised on the top with Lines going around it (looks good)
does anyone know why?
ie Giant Tomato
Re: Toyota 'M' Series History Tech Article Thu, 03 July 2003 09:00 Go to previous messageGo to next message
Yep, you have a post July 1976 4M (known as a 4MU). The MX13/23 was available till Sept 1976 here in Australia, so they had to fit a motor that would comply with ADR27a, hence the square rocker covered 4M. It's basically a Gen 3 4M. Corona Mk2's and Crown MS85's built from July 1976 have this motor.
The Gen1 4M had a 41030 head (with 9.2:1 CR, and slightly high topped pistons), gen 2 had 41032 head (with 'nipply' pistons -sounds XXX rated doesn't it - and 9.4:1 CR and more power). The Gen1 and 2 4Ms had a head that was bolted down by 14 large and 3 small head bolts, and the rocker assembly was bolted down to the head using 14 separate bolts. They also had a curved rocker cover. There are subtle port differences.
The Gen 3 4Ms (4MU and 4MEU - 4MEU not released in Australia) had flat top pistons, ultra low compression, and a square rocker cover. The head and rocker assembly are bolted together with the same 14 large head bolts (so to get the rocker assembly off, you have to undo the head bolts), and 4 smaller head bolts at the front. Again the ports slightly different. There was a significant power drop from the early to late motors.
coronamark2
Re: Toyota 'M' Series History Tech Article Thu, 03 July 2003 09:15 Go to previous messageGo to next message
Well the heads all nicely ported + the manifold and the extractors for nice air flow.
When i got it rebuilt they put in dish pistons or something anyway it made the compression go through the roof and they said we can leave it like that but you'll have to run it on AVGAS.
i said just get the same ones that where in it.
It's still high i HAVE to run it on ultimate98.
i dont mind its powerade for my engine Smile
Re: Toyota 'M' Series History Tech Article Thu, 03 July 2003 09:32 Go to previous messageGo to next message
Sure. I just meant standard from the factory. Everything can be improved!
BlackSupra
Re: Toyota 'M' Series History Tech Article Thu, 03 July 2003 12:37 Go to previous messageGo to next message
From what i have learnt/read the 6mge shares the same block as the 5mge with the 7mge crankshaft.
The pistons and rings are early 5mge spec and the head is identical.
The intake plenum runners have a different shape and are supposedly larger in diameter. Ran no emissions due to being JDM.
The crank pulley is a combination of a 7mge and 5mge and is a prick to find a replacement (read: impossible). (7m center with 5mge outer)
Thats about it though.
Extra .2L is the main difference
[Updated on: Thu, 03 July 2003 12:38]
ed_ma61
Lost in the K hole
Re: Toyota 'M' Series History Tech Article Thu, 03 July 2003 12:51 Go to previous messageGo to next message
7m/6m crank will NOT fit in a 5mge block Smile well, not without a bit of grinding.
oddly enough, the crank in the 6m is stamped 6m (der), whilst the 6m crank pulley nut is stmped 7m. then, on top of this, the early 7m's had a crank stamped 6m....
7M-Brisbane
Re: Toyota 'M' Series History Tech Article Fri, 04 July 2003 07:54 Go to previous messageGo to next message
1940's: Toyota develops tractor engine
1980's: Toyota passes off revised tractor engine as performance engine
Very Happy
Re: Toyota 'M' Series History Tech Article Fri, 04 July 2003 08:42 Go to previous messageGo to next message
Smartarse! Razz
FreaK
Canada
Re: Toyota 'M' Series History Tech Article Sat, 05 July 2003 07:18 Go to previous messageGo to next message
Heyaz Rob! Nice one man!
BTW - I'll get toyotatuner back up soon... promise! I might have to goto an outside server if the power keeps dropping out here damnit.
Anyway - owning a 5ME I can say that 115 HP is *severely* conservative. Havent had it on the rollers, but pushing a 2800 pound chassis through an auto trans (with over 300K on it) down the 1/4 in 17.2 is not 115 hp.
Also BTW - if *ANYONE* has info relating to 5MTE parts (manifold esp.) I'd like - I'm in process of designing the manifold for my 5M to hang the (T3?) turbo from a 300ZXT on there!
FINALLY!! w00t!
So Stef sent me this article, and I'm verrah glad to see a well-written history!
Tx d00d!
-;)_
FreaK
Canada
Re: Toyota 'M' Series History Tech Article Sat, 05 July 2003 07:33 Go to previous messageGo to next message
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?Vi ewItem&item=2421885757&category=33582
This stuff keeps popping up for cheap like you doods have BOVs to spare over there.
anyone feel like shipping me a Saard/HKS/ApeXi/Blitz unit for cheap?
damn.
ed_ma61
Lost in the K hole
Re: Toyota 'M' Series History Tech Article Sat, 05 July 2003 07:55 Go to previous messageGo to next message
if you find an item you want on ebay, im happy to buy it and ship it for you Smile
thats if the seller wont ship it to you themselves of course...
ed
Re: Toyota 'M' Series History Tech Article Sat, 05 July 2003 10:16 Go to previous messageGo to next message
I want something from ebay dude Razz Can you buy it for me and send it? Very Happy
Alchemist
Re: Toyota 'M' Series History Tech Article Sat, 05 July 2003 14:47 Go to previous messageGo to next message
Thats great reading mate! Its a comprehensive history of the M series of engines! Nicely done
sillyca
Jimboomba, Qld
Re: Toyota 'M' Series History Tech Article Fri, 18 July 2003 00:32 Go to previous messageGo to next message
i want to read this article but i keep getting 404 not found - is it still up?
rob_RA40
c'town, NSW
Re: Toyota 'M' Series History Tech Article Fri, 18 July 2003 02:02 Go to previous message
seems ed moved the link...
clickety click
http://www4.tpgi.com.au/users/loats/technical/mhis tory/mhistory.html
Previous Topic:Help needed for lowering a *Z1* Soarer
Next Topic:Drop tank ???????????????????
Current Time: Thu Nov 19 06:08:11 UTC 2026
Total time taken to generate the page: 0.0076241493225098 seconds
