Toymods » Tech & Conversions » 4AGZE g/box oil grade
djb23_20v
Wollongong
4AGZE g/box oil grade Mon, 01 July 2002 13:23 Go to next message
Guys,
What grade of g/box oil should I be using for a 4AGZE g/box?
Dan
birdofprey
North Parramatta
Re: 4AGZE g/box oil grade Tue, 02 July 2002 09:06 Go to previous messageGo to next message
Dexron 3 is the way to go (ATF).
I used it for 3 years without an issue and it always provided silky smooth changes.
I should mention dont use any additives as they are good in the short term but after 20,000 k's they cause probs in your bearings Freak .
4RS_FED
Re: 4AGZE g/box oil grade Tue, 02 July 2002 11:27 Go to previous messageGo to next message
Haynes manual for 16V na 4AGE recommends either 75W/90 or 80W/90. I have used 80W/90 with no problems for some years now.
It seems a bit strange to use ATF in a manual gearbox? I thought it would be too thin? Can anybody else back up this suggestion?
celica_freak
newcastle
Re: 4AGZE g/box oil grade Tue, 02 July 2002 15:38 Go to previous message
not sure if i have the same box but it is a w series box witch i have had for several years,when i run w80/90 i had trouble getting second when it was cold so i dicided to try the w75/90 from an ourtown oils newcastle as it was a lot cheeper then penrite.since changing to this grade of oil i have never looked back and fully recomend it in both t50 boxes and w series boxes as second is obtainable no mater wether its cold or not all gear changes are smooth with no wines or howles over the past 5years or so,also the 2 boxes have no noticeable metal flakes or signs of bad wear in any of the oil changes i have done this w series boxs was behind a 140 bhp holden 6 that coped a beating and the t50 was behind a 2tg that travelled 120 km daily for 2.5 years and also coped a beating.
so again i recomend the w75/90 to anybody, but in the end its your joice
ps
w75/90 is not atf w70/90 is. the w75/90 is a slightly heaver grade or thats what im told. also dont mix w80/90 with w70/90 as this willnot work as it causes a cemical imbalance and will altimatle destroy your box or lsd diff
[Updated on: Tue, 02 July 2002 15:46]
Previous Topic:Bits for a Sprinter
Next Topic:3vz-fe's
Current Time: Mon Oct 26 13:47:21 UTC 2026
Total time taken to generate the page: 0.023900985717773 seconds
