Toymods » Tech & Conversions » 1JZ-GTE boost sensor?
SkiDMaN
Gold Coast
1JZ-GTE boost sensor? Wed, 02 July 2003 12:40 Go to next message
just a query... someone i talked to said there was a boost sensor for the 1jz... i dont see how it would make sence cause if there was air getten to the motor it would automatically boost and lean out "if" there was a boost sensor and it couldnt retard the timing and drop more fuel...
could the malpassi fuel reg have any thing to do with it if its not tuned properly?
still cant get my motor to boost... ne thoughts... will try any thing?
Pete
HedgehogSandwich
UK
Re: 1JZ-GTE boost sensor? Wed, 02 July 2003 22:37 Go to previous messageGo to next message
nope no boost sensor, just the map sensor.
E30-323ti
Re: 1JZ-GTE boost sensor? Thu, 03 July 2003 02:11 Go to previous messageGo to next message
What does the little thing that sits under the intake manifold do??
Look's same as the boost cut solenoid on my EVO.
But as Norbie said below the ECU knows via the map sensor.
[Updated on: Thu, 03 July 2003 05:01]
Re: 1JZ-GTE boost sensor? Thu, 03 July 2003 02:39 Go to previous messageGo to next message
As mentioned above, the 1JZ uses a MAP sensor. That means the ECU always knows exactly what the manifold pressure is, so there's no need for a separate "boost sensor".
HedgehogSandwich
UK
Re: 1JZ-GTE boost sensor? Thu, 03 July 2003 08:32 Go to previous messageGo to next message
edit..
[Updated on: Thu, 03 July 2003 08:34]
SkiDMaN
Gold Coast
Re: 1JZ-GTE boost sensor? Thu, 03 July 2003 08:56 Go to previous messageGo to next message
could this map sensor be faulty? and if it is... would it cause it not to boost? or any thing else for that matter
HedgehogSandwich
UK
Re: 1JZ-GTE boost sensor? Thu, 03 July 2003 09:42 Go to previous messageGo to next message
nope... it wouldnt directly cause lack of boost, but it would cause the engine to run badly (if it would run at all) preventing boost from building effectively i guess.. chicken and egg stuff.
The map sensor measures the amount of pressure in the inlet manifold, and tells the engine to fuel and time accordingly.. so yes in theory it could prevent your engine from building boost.. but for it to be this bad you would notice the engine performing badly way before you hit boost.
Does it run fine but just doesnt boost? Have you checked your turbos are okay? Have you checked *all* the intercooler piping for leaks?
[Updated on: Thu, 03 July 2003 09:51]
SkiDMaN
Gold Coast
Re: 1JZ-GTE boost sensor? Thu, 03 July 2003 10:06 Go to previous messageGo to next message
the turbos are of the car atm... one seems to be fine and the other one has slight chips on the exhaust wheel... and when the bov goes of there is alot of air comin out so its making "boost" but its not working...
if i was to "t" in the boost guage just before the plenum that would give me the most correct reading right?
HedgehogSandwich
UK
Re: 1JZ-GTE boost sensor? Thu, 03 July 2003 10:41 Go to previous messageGo to next message
yuo mean tee into one of the vacuum pipes on the inlet manifold? yep this would give you the pressure reading.
Chris Davey
sunny coast, qld
Re: 1JZ-GTE boost sensor? Thu, 03 July 2003 11:53 Go to previous messageGo to next message
sorry OT: but hedgehog snadwich: If the 'decat' you have in your signature is referring to the hollowing out of the cat, i don't think it is a good idea to be telling everyone on a public forum that you have it as the police can look at these forums too. There is a BIG ASS fine for having a hollowed or no cat!!!!!
just letting you know man.
anyway, carry on Smile
HedgehogSandwich
UK
Re: 1JZ-GTE boost sensor? Thu, 03 July 2003 12:03 Go to previous messageGo to next message
not in the UK there isnt Very Happy but no its a replacement pipe as opposed to a hollow out, being replaced soon for a full stainless anyway (without cat of course Laughing )
[Updated on: Thu, 03 July 2003 12:05]
SkiDMaN
Gold Coast
Re: 1JZ-GTE boost sensor? Sun, 06 July 2003 06:34 Go to previous messageGo to next message
i know im a pain in da ass but i checked the toyota catalouge and it says there is a boost sensor for a 1jz
opionons?
confused Pete
wastegate
Gold Coast
Re: 1JZ-GTE boost sensor? Sun, 06 July 2003 08:15 Go to previous messageGo to next message
There is the MAP Sensor for the engine, sits on the firewall and has a vac line to the plenum. There is a Boost Sensor for the Stock Boost Gauge near the shock tower behind the fuse box.
HedgehogSandwich
UK
Re: 1JZ-GTE boost sensor? Sun, 06 July 2003 12:02 Go to previous messageGo to next message
you mean this one is seperate from the MAP sensor?
SkiDMaN
Gold Coast
Re: 1JZ-GTE boost sensor? Mon, 07 July 2003 09:01 Go to previous messageGo to next message
do any of u guys have a picture that u could upload showing where this stuff is in the engine bay or what it looks like.... preferably what it looks like cause i have things in different places cause of the conversion
Pete
wastegate
Gold Coast
Re: 1JZ-GTE boost sensor? Mon, 07 July 2003 10:21 Go to previous messageGo to next message
Here you go.
http://www.jzgte.com/~nickc/albums/frontcut2/DSC00012_sf.jpg
SkiDMaN
Gold Coast
Re: 1JZ-GTE boost sensor? Mon, 07 July 2003 10:27 Go to previous messageGo to next message
muchly appreciated Smile
Pete
HedgehogSandwich
UK
Re: 1JZ-GTE boost sensor? Mon, 07 July 2003 13:52 Go to previous message
wastegate, i think you need a new strut bar Very Happy
I always wondered what that sensor was for.. cheers for the info..
Previous Topic:1G-GTE Sump
Next Topic:GZ20 Soarer Brakes
Current Time: Sat Nov 21 08:07:14 UTC 2026
Total time taken to generate the page: 0.0068600177764893 seconds
