Toymods » Tech & Conversions » AE86 internal fuel pump
86racer
AE86 internal fuel pump Thu, 03 July 2003 08:37 Go to next message
Just want to know which fuel pump would directly bolt onto the Aus-spec ae86 fuel tank(mind you I'm putting 100Kw 4age) I heard series 4 RX-7 is direct bolt on... Is that the best choice ?
Cheers !! Very Happy
Re: AE86 internal fuel pump Thu, 03 July 2003 09:58 Go to previous messageGo to next message
Hmmm, when it comes to 'direct bolt in' I'd think you'd really be wanting to build some kind of swirl pot in the tank first...
IRA11Y
Club Member
Re: AE86 internal fuel pump Thu, 03 July 2003 10:46 Go to previous messageGo to next message
rx7 is not a bolt in,you can use the pump itself but will still need the bracket for the efi pump, an AE82 pump and bracket will bolt on to the tank but the bracket will need to be made a little longer to reach the bottom of the tank, it is rumoured that a AW11 will bolt in perfectly but i havent seen it done yet
Dodgy_Haro
Re: AE86 internal fuel pump Fri, 04 July 2003 02:36 Go to previous messageGo to next message
Even then, the Oz spec AE86 tank being made for the 4AC carb will not have an internal baffle unlike the EFI ones so you might starve of fuel when cornering hard ...
IRA11Y
Club Member
Re: AE86 internal fuel pump Tue, 08 July 2003 10:09 Go to previous message
if youre tank is over 1/4 full you wont get surge, and as an added bonus you wont get crap up your lines and into your filter by running low Smile
Previous Topic:Just got another RA23, help needed for engine restarting and transmission swap
Next Topic:21RC - goal - 220 hp believeble? what can be done?
Current Time: Tue Sep 15 13:57:39 UTC 2026
Total time taken to generate the page: 0.029821872711182 seconds
