Toymods » Tech & Conversions » 4point Harness in AE86
KOPDIS
4point Harness in AE86 Thu, 03 July 2003 12:57 Go to next message
hey guys l've just got another AE86 (number 2 for me) and l'm going to put in my 4point harness, in the T18 l had the top 2 point attached to the roll cage and the bottom 2 to the original seat belt mounts, where on earth do l attached the top 2 in a AE86? and is it possible? cheers
l'll post this in twincam16 aswell Smile
[Updated on: Thu, 03 July 2003 12:58]
ae86slaver
Re: 4point Harness in AE86 Fri, 04 July 2003 05:57 Go to previous messageGo to next message
you could either strip the back seats out for a better working position, or you could feed them through the gap.
They mount perfectly on the cross-frame just where the back support is. There are already existing holes and many to choose from on where to bolt the harness belts in. A couple of bolts and a bit of hole enlarging and your set.
Just make sure you don't mount them on an acute angle to the seat as it is a defect and will probably end up saving your life.
KOPDIS
Re: 4point Harness in AE86 Fri, 04 July 2003 07:52 Go to previous message
sweets thanks for the advice, got afew others giving me advice too, l'll get it all sorted now, the cars still getting engine freshen up ATM so when l get it back harness will go in, cheers!
Previous Topic:Oil pressure, water temp gauges
Next Topic:New stepless throttless valvetrain
Current Time: Fri Oct 30 15:17:48 UTC 2026
Total time taken to generate the page: 0.0042331218719482 seconds
