Toymods » General Car Talk » cressida update
thunderbird1
Sydney Australia
icon11.gif  cressida update Tue, 02 July 2002 04:01 Go to next message
Got the HKS FCD in now and running 14psi to start with. I have to say, look out 7m boys who i wasted on 10psi....
Its good though... pulls so strong up high on 14psi.. 17 soon as soon as i change filters.
Luke
Les
Re: cressida update Tue, 02 July 2002 04:06 Go to previous messageGo to next message
HKS fuel cut defender ? How much ??
is it safe to boost it up to 17 psi without internal mods or larger intercooler ??
I wouldnt mind boostin up the 1g!
thunderbird1
Sydney Australia
Re: cressida update Tue, 02 July 2002 04:14 Go to previous messageGo to next message
i have big arse intercooler... the newcastle boys run 17psi all day and don't have many hassles.
Standard 1g... not a good idea.
Luke
TOY77
Re: cressida update Tue, 02 July 2002 05:55 Go to previous messageGo to next message
Luke,
So you got it sorted?
What was mucking you round the other night?
Stew
Les
Re: cressida update Tue, 02 July 2002 06:15 Go to previous messageGo to next message
so before boosting it - u suggest i get a large front intercooler ?
TOY77
Re: cressida update Tue, 02 July 2002 07:29 Go to previous messageGo to next message
les,
What size exhaust you got?
Got a cooler at all?
My 1ggte runs 14psi... stock cooler, 3in exhaust.
Stew
Les
Re: cressida update Tue, 02 July 2002 07:35 Go to previous messageGo to next message
exactly the same as yours !!
3 " mandrel xhaust
supra intercooler (got it with the engine fr SSS Automotive)
stock boost..
how do you increase your boost anywho ?? Question
Guest
Re: cressida update Tue, 02 July 2002 07:36 Go to previous messageGo to next message
Luke You gunna do the frontpipes before you run 17 ??
TOY77
Re: cressida update Tue, 02 July 2002 08:06 Go to previous messageGo to next message
Les,
Just using a bleed valve.
turn it up - just don't go over 15psi
Stew
thunderbird1
Sydney Australia
Re: cressida update Tue, 02 July 2002 17:37 Go to previous messageGo to next message
funny enough.. when andrew put the FCD in he stuffed up a wire and the map sensor wire wasn't touching inside the plug. So i was basically running without a map sensor... ie.. in limp home mode.
Thats why i was bucketing out smoke!! DAMN!
Alll sorted now... yeah pipes before 17psi.. having fun on 15 though Smile)
Luke
TOY77
Re: cressida update Tue, 02 July 2002 21:41 Go to previous messageGo to next message
Sounds sweet mate - it's always happy times when you find a big prob was caused by something simple (and cheap!), though you wish it could have just run right first time....
Les i think when Luke said "not on a standard 1g" he was talking bout 17 psi and fcd, not just turning up the boost....
Stew
Esteban
Brisbane - Chapel Hill
Re: cressida update Tue, 02 July 2002 22:49 Go to previous messageGo to next message
I remember one zoom article where they ran well over 20psi on a std 1G with an intercooler ... i also remember some quote along the lines "wound the boost up to a ball-tearing 35psi!". They did manage to blow up 4 1Gs during testing, but eventually they got it right IIRC. The old 1Gs seem pretty solid if you ask me.
Les
Re: cressida update Tue, 02 July 2002 22:53 Go to previous messageGo to next message
15 psi is ok to run on the car ?
I wont be able to change from 15 psi to stock psi just using a bleed valve right ? Question
TOY77
Re: cressida update Wed, 03 July 2002 01:16 Go to previous messageGo to next message
Les,
Yes you can. Turbo smart make two dual stage bleed valves.
There is an in cabin switch to change it.
One of them has stock boost and high boost - where only the
high boost is adjustable. Or a high/ low boost, where both
are adjustable.
I'd set it to 14psi to be safe... you will hit the boost cut over 15psi - ask Phill, he'll be able to tell you bout that!
Stew
dcving
newcastle nsw
Re: cressida update Wed, 03 July 2002 22:36 Go to previous message
if u do try this wear a seat belt or youll need a new windscreen Nod Nod Nod
Previous Topic:Radio Controlled Cars
Next Topic:New Zoom ae86 20v conversion
Current Time: Mon Aug 3 19:20:43 UTC 2026
Total time taken to generate the page: 0.0046250820159912 seconds
