Toymods » Tech & Conversions » Oil pressure, water temp gauges
SW20R
Oil pressure, water temp gauges Fri, 04 July 2003 06:49 Go to next message
just making sure if these are the right locations..
i've found where the water temp gauge would connect upto theres this small nut on the bluetop block. unscrewed it and water/coolant came out.. its mid left of the block.
to the left of it, it has a singal wire sender to which i assume is the oil light? would the oil pressure gauge replace that?
Grega
melbourne.victoria.austra...
Re: Oil pressure, water temp gauges Fri, 04 July 2003 07:47 Go to previous messageGo to next message
nah the temp gauge connects to the top outlet (that goes into the head dude) - i just searched on the same thing no shit.
http://www.vhtracing.com/pasin_stara/pasinkisa106.jpg
the big pic is here : http://www.vhtracing.com/starlet/tth2misc.htm
look at that pic it sorta shows ya
the oil pressure sender sits next to that thing where the coolant came out of on the passenger side of the block.
[Updated on: Fri, 04 July 2003 07:48]
SW20R
Re: Oil pressure, water temp gauges Fri, 04 July 2003 08:51 Go to previous message
ohhh i see it now the water temp one nw.. im still alittle sketchy on the oil.. im using a mechanical not electric type it uses a hose
Previous Topic:Hilux calipers on AE86???
Next Topic:4point Harness in AE86
Current Time: Sun Nov 22 18:39:51 UTC 2026
Total time taken to generate the page: 0.01449990272522 seconds
