Toymods » Tech & Conversions » Calipers and rotor sizes
Calipers and rotor sizes Fri, 04 July 2003 07:24 Go to next message
I'm looking at using some calipers that were originally used on 324x30mm rotors together with some 320x32mm rotors.
Can anyone see any problem with this? I just want to know if the calipers will work with the rotors that are 2mm thicker Confused
Any thoughts?
munki
Gold Coast
Re: Calipers and rotor sizes Fri, 04 July 2003 07:40 Go to previous messageGo to next message
wouldnt the pad rub on the disk for sure??? i always thought that there was little space between the pad and the rotor.
Re: Calipers and rotor sizes Fri, 04 July 2003 07:56 Go to previous messageGo to next message
Thats what I was thinking and is the reason I'm asking Sad
Re: Calipers and rotor sizes Fri, 04 July 2003 09:31 Go to previous messageGo to next message
You probably could but you will have excessive pad rub. Judging by your other posts, I presume you are investigating using those R33 Brembos.
What you could do is machine a spacer plate to go between the two caliper halves. The spacer of course would be 2 mm thick, have to be ground to a perfectly flat finish and be made from a similar alloy as the calipers (so it has a similar thermal expansion coefficient). There may be some other minor issues (like pad return springs or pad holding pins) but these can be easily overcome.
Re: Calipers and rotor sizes Fri, 04 July 2003 09:38 Go to previous message
Thanks for that. I might look at using something different.
I want to make things easy to replace/repair in the future if need me.
Previous Topic:4agze diagnostic codes
Next Topic:Hilux calipers on AE86???
Current Time: Sat Oct 31 08:03:48 UTC 2026
Total time taken to generate the page: 0.14633297920227 seconds
