Toymods » The Outhouse » Run Linux on XBox with NO Modchip
Toobs
Run Linux on XBox with NO Modchip Fri, 04 July 2003 07:32
Slashdot.org just had a topic on this one... They said they'd do it and they certainly have... (below is a copy of the article)
XBOX Security
-= Security Advisory =-
Advisory: XBOX Dashboard local vulnerability
Release Date: 2003/07/04
Last Modified: 2003/07/04
Author: Stefan Esser [se@nopiracy.de]
Application: Microsoft XBOX Dashboard (up to today)
Severity: A vulnerability within the XBOX Dashboard allows to
totally compromise the security features of the XBOX.
Risk: Critical
Vendor Status: Vendor is not willing to talk about XBOX vulnerabilities.
Overview:
The XBOX Dashboard is what appears when you turn the XBOX on without a
disc in the DVD drive. It will let you adjust system settings, manage
your save games, play and rip audio CDs and configure your XBOX Live
account. It is the heart of the XBOX and its most vulnerable point,
because it lacks several security restrictions which are enforced on
games. This includes the lack of the reboot-on-eject-button "feature",
which is obligatory for all games.
The existance of an exploitable vulnerability within the dashboard could
totally compromises the XBOX security system. It will make the box
independent from Microsoft signed code and therefore this information is
released to the public now on the 4th of July 2003, the day of the XBOX
Independence.
Details:
Microsoft knows that a vulnerability within the XBOX dashboard could
have serious impact. This is underlined by the fact that the dashboard
checks most of its files against an internal stored SHA1 hash value
before it uses them.
For an unknown reason this check is not performed on the audio (.wav)
and font (.xtf) files. Unfourtunately for Microsoft there exists an
exploitable integer underflow vulnerabilitiy within the font file loader
which can be exploited with a malformed font file. When the XTF header
is processed the dashboards reads a 4 byte blocksize field from the font
file. This is expected to represent the size of some datablock including
the 4 bytes of the size field itself. The blocksize is then allocated
and the sizefield is copied into the beginning of the buffer. This is
already a possible overflow bug when the field contains the values 0..3.
Due to memory alignment this is not exploitable. But then the blocksize
is decreased by 4 because the dashboard wants to read the rest of the
block into memory. Obviously values of 0..3 will underflow when
decreased by 4 and this results in the dashboard wanting to read up to
~4 gigabytes of data from the font file in a f.e. 3 bytes buffer.
Because the XBOX malloc()/free() implementation is also storing control
information inbound and is similiar to the Windows 2000/XP heap
allocators this bug is exploitable and allows execution of arbitrary
code. The attached proof of concept code shows that exploiting is
possible with offsets that are equal on all dashboards and XBOX versions
known.
BTW: the dashboard loads its font files directly after the XBOX start
animation. This means the exploit does not need any user
interaction and when the code is executed only part of the
dashboard background is on screen.
Proof of Concept:
Attached you will find a proof of concept exploit which will start
linux. To install it you have to rename the 2 XBOX font files within the
font directory of the dashboard partition and then copy ernie.xtf and
bert.xtf into this directory. (If you have an XBOX with an older
dashboard the font directory does not exist and you must do the renaming
and file adding work in the main directory). Once the new fonts are in
place you copy the default.xbe (which is a copy of xbeboot) into the
main directory and add your favourite linux to it.
Trustworthy Computing:
Trustworthy Computing at its best. Nearly 2 Years ago I reported an SSL
vulnerability within IE to Microsoft. 1 month later I released
information about this bug to the public because MS did absolutely
nothing. The vulnerability was nearly forgotten, it only exists on the
list of 19 unpatched IE vulnerabilities anymore. But this is wrong, the
vulnerability was indeed fixed with one of the many IE patches in the
middle of last year. Well is secretly fixing bugs without an official
advisory trustworthy?
Anticipated Questions:
Q1: How do I get the files onto the harddisk?
A1: There are several ways. You could f.e. install the files with the
Mechassault or 007 hacks. This requires one of the games and the
files on a memorycard. The other way is to open the box and do the
harddisk swap trick which is described all over the net.
Q2: This vulnerability is in the dashboard, isn't it? So Microsoft can
simply update the dashboard with XBOX Live or with the help of new
games.
A2: Yes Microsoft could try to upgrade the dashboard and fix the
vulnerability with such an update, but keep in mind that this
vulnerability is like a "local root" hole. You can do nearly
everything with it and this includes redirecting reads and writes to
the xboxdash.xbe file. Additionally people who do not play games on
their box will not be reachable with such updates. And groups who
pirate games can always disable the update feature.
Q3: Well but MS can make the kernel block the vulnerable dashboard.
A3: Indeed they can. But until boxes with new kernels reach the market
we will have the end of this year (You can still get 1.0 boxes in
shops over here) and they can only fix the bugs they know about.
Q4: Is it possible to play "backed-up" games with this?
A4: Yes it is possible to play pirated games by using this vulnerability
but my proof of concept code will not allow this. You have to change
the exploit to patch the kernel in memory. This is not very hard and
I am not going to help you with this.
Q5: Can I go "Live" with this hack?
A5: You have full control over the box with this vulnerability. You can
modify the exploit to allow XBOX Live playing but this will only
start a cat & mouse game with Microsoft.
Q6: I have read that I can solder my mainboard with this hack...
A6: This exploit has nothing to do with soldering, It will just run
everything you want on unmodded (and even unopened) XBOXes. Infact
when this hack is installed you do not need to solder anything to
get your homebrew or whatever applications to run.
Copyright 2003 Stefan Esser. All rights reserved.
begin-base64 644 dayX.tgz
H4sIAOKcBD8AA+w6bXRTVbbn5iZtWgq5kAp1rBgIoChoQ/iqlm VpvMigxdC8
gE+misZ2Ygc/HkkKKmFCL1n05nqx2uebeSo8O1EHHzIylnGgKE 1pTfxgjVWc
tSqgdCzOBFORMWkbNZC397lpadFhfqjLNetxFvfec/bZ33uffc 4JvfvOB2+9
hvywrahodtG8OXPgS9u5X6U/b16RyWSaay6aR4pMRbPnziOGOT +wXrR5XO47
1xgMZM3997vPh/fP5v9F290Y/7urqu/0rHZfve6uqh9CBsSzaO 7s2f8g/nPn
meeejf+suZAnpllzZ0H8i34IZc5t/8/jf2sZv/gV80/bL1HfUl s6cc2Gtz4Y
bXtI/zIzu/ePtb+Tdv2l4/mS5B2v+57//OWDv5jyjmVOS9XERc //+0Htgdfu
Kayccdtn4YPM6OMP/eG23qVtY6YtuXf+lmsPtC1WZW3eMmbinu 0vLN+5LPRR
OPth3v+7yUze/KbV49+Pvd2b9fDTH/5+/dU//+Rk2bGBy1cdy6 tu/SheMK7i
rSdrjQ923NDN7LS1XHLy2g2XHzFXrHt30j3xz8LXH/hNZMnHM5 76VWvnXRM3
By3Tn93/5866J1zr79j8s09HHXygfuvSrD8FOi8KvbuuetOx2d uaXz5pvtn7
lnPnmjsPFt/7aNkjD/wtYam9ftaHDYtnaYpe3Hb/vp0Ge+vWSx /LNsZYQhgy
I5uQU/cRso5R/LKOYQh2F7MKYMei09uJjzmvL58EGnw2wfOKdf XKb8N5BPg9
AxI7h7G6mdxD7iMesu57ieh3bxpCQuAOXxraj63Lv0rLxhfHkM 7b8Uvod1Mm
d3zwrYPnsYcDatvz9ts+fbf6husO/S3r9PYvvsD5q91V69xE7K 8geldzvK/n
UI+DhZbNsnqLWc/+F3mSQNfcHI/HGy1GPcvmsKyrUYCpx+kUa3 T09bhGzkBP
kzNKw7IaTTY7SkPR9Aoay44CbjYbYmnov+FNk3nhV6Gy9R1yAa 4GQUaz2WyE
Nod2NKx+jtmon2qEl95shj6A9Rk6NkNHWdkE1M/ReCje09wc7A la9MbGeE9c
sAgAagTbBpotwXiPTX+W1kFlsqxDsIFFRr3xUDx+yGZujx+ymG 2N8XjQYnT1
tYPIYJ9gcR1yGM+hBbl6weJoFMBQoIrDNxiPu8xGS0+82WYW+t pt0AeFhEPI
/lzBLrPF7KLExmZKDCIBzxJH4kYk1oP8HmQyzFGKYDZoM9oaFe J2EGAxIrHF
aOkL2swuSku5Bm3f4i222WF2NDa6MsSukcTxOKXWQ6fHNYJaEW 3ucYBPBZfL
htTIEqhdCrVREc2yArij3UL1xtj0UU4aIe5CpV0gC72sCM6QKu 7Ss44eV3Mf
5heldPTFkdIIyrhAZUEA70KYUBUgdWS8ZQkiLWtshmiAu21G/T aid4AOfUHQ
s31AsAnUVzahrydoA5R40GFE2c2N4KMeweYKxtsdILfdYURKj4 CSHC6XIDQ6
LBaHA+PocAHU5gBQIwgwu4JBl0UINrosLper0WaD2UaHUQmT0W yxYMJCFmMu
m7Gvp/mceSujObyCRFGgu/THKy4X2oV2oV1oF9qFdqFdaN9jex 6uJzvh2QPP
JIb49sP3EDz74DkCzw54XoZnNzyLYH4hPBZ4roSnFJ5ZAP+xbf gu7cQxLSFy
7dDYLn6yYrnN1C+VayVvnlTJ+Y94HtiXCzO+4iJP9cJ9Wtpd51 kZWMbIZZ0l
ObVj5LL/KdHUZstlrSWatZaF++D6R2LXya8gv8BYirRWq9vPyN bO2AREvnht
rlzWPRUv1zGWTrxZfNhlELt0L4UXyrNVGaLatxXO+yjn2t3+tF sl6sRTK2+/
Q+ytbG8AXYVercRrpfI8yc755s90c0JHqmKZNToHru6xsWAXHZ dao1MAMNCF
ZGI/0NmkSq2kN70ZGyOrRd3+cfLNZZ1pVtIHVGoU/Kn4xsohXK F3PbgEHeIB
h+RL9sIIv3vVnQzpP1Dqzob+M7TPuVnh4zMSzwmhM0Jycm22KX RiFVyAw/w+
Q/8Bxq2GTlGYbwFUlXuyv9+rhcHMgY9iF/UfULuzYXBVLLeh/4 DWrYG+4SbR
/qJQ9aLBnS94Oc6TLbSfieWI/TDQepibTGl/v6cgzL9a1Ip3bN H+rFD1LCd8
PFa0PxObOWIo86+K/C7xlOm9AQ8nhiV+d0Ctkuy76tUTbgQmf7 3OW7CBFb0F
kr3gqsqCJfLatOjZLnifIZ4xMU1DmDEsFLtu8od+2efzthB3Vo BvqWcWCt4X
iXsiVUYTZopi46iSo6EreXYvDCyaRHGeJR5dDCj2wUhhEpf4At FeILvSxREv
xgcp+IKF6fKC4sj6L8Sk5N3uD20YL9tfzeSPegISJ29BYrFLjM PsqGFKQaCU
bABeNFaFGCsPJ/EQK61vPtFt+khFCAwDpGSqzn8/DCJ8ElkDTL Yyoj0vUMqo
u3X7Q0KSW3tNeor/IMTTV57kYh+K/fBVx/4Mb23sHdk9DeGG2O vwZmKtOIbU
a8XfiQbzXC90JGQ+zxr91el0WowIHVzsYt9XV3ryFwphtQh5ui HlT3uzBo6h
ANBAPBDhE8jAd+3VnsXyEgZwAksYeSEyyx9ktgSZ8Qnklu/78k qPTjigQn72
PGlRCiYke57gTRAvZGMCTdtLVVKVON3aktVudcnNnlyQpduvLR XBL3xeCy7o
AFEfoVbbdJtvgiwCy7m7GCLZk/IiNeSzJw/jzxost/jTvxwQw+ Jhyy2BRal6
lT+t21ILBGj/0PyJuwEC+RlWS0tT/jc9mr2vgxslPhnhU6iS0M 35iol7fCwv
zacke8pXkkvcWsmeKLan1vT6Q56xsWzMB+AH0S7mU+sT8o1g9C nBmyIbxgJF
A8oLMPXsQssSzwCmyilA08kx4D6c7MRhFJdOe3JaabGCWIFNQk eyQipPLFsB
GtZw4LYTv4XJBuHL1Z5x6MrDALrKrhW5E08hOUA+QEi5VtSeEA Ei755GqKCp
ltj6FmQcM4O+wL20hRa8qQ2Z/FDFfgJYEBJLQLUp5NbUs5bYki UQq9gN4J8v
V8O6+dLpGS+VJ0GKKVQNYvrbVO4xv46NEvvBYejCRSmc7kguoy pXWG1R19eQ
Au1Ch2EobX3rGKLzT4bUCLPkqkqtXNUldp1TG6Fo2fNkHsuitW JZ9HAKmJyt
a7hWAry2JFe3qQ5MMKUhHdq61SKfkm9kMK34lKmfSZreCzSsWs ZAlUk2SJXJ
vWj89L8f+lroYdyafZhqTaH7INYXFd7PEKBnkm0fs7La19adzR xougKAzBdi
YcMi4Uz2hlbJmxDSug3bmhAZDaFUYqeQvGXDdMonokEINjqNIJ y+dENuRIMD
bBkzM3bkmUK46r3aanCO6Uhxu/dSMazUD1hBuv3q66zRUaAmrB 9LcXx9TK6K
mkIj6sbG3nwoDLDWbJJdS50lbyVn0mlb9LdfI11yKv4UDGF4BN hIW6OnR/ix
BKSDoBp1DXGm062sE38ChZeKNOFvoulOke8SOvL8Id0mPy08IC JplSt7bU15
dB7WSCmW8cpkZgGDCjWrapia7BpSQ+TK4zaZT1idPsL5ZL7b2s RluL6vcH0E
d1LYAUEHSQULNTJSk+VUi7b0ZUhylJJ48iL8+xMICZ3oUJzkXO VgSPQLMFni
j4o8aHRQ0YPzp9fmejz+/tr/wPzeh1bVEHBTV4XMH7eifjVgES hVeFapFJ2X
+E5r1DVW4e9E/o+fQWcaBO/7ZP3kjShCBXof3Mh3Yk98VzzU9v VlxcfW/rdH
XfyntY0SapuyAkaFswbpK1A/+0HYZEVa4e1HRQ4MoblStUfi3x +eF3Q9xs7Q
/sbeGbBIIUwR//HPlV/1I/7uTG9fN8267kxuRTS9Su90RBOlvR ALFtii3DXg
5QVEu+r0xghAT4kLMLclyjG1l+xSk/gO+bXk5zRhUntVagKAs9 l8NnudAhjj
DKBFvtOKRzqSzt8gMITAX1BgwtmNg9sHMRLOcVBjo0uVSdmPgq zRR0GKGAYE
OFFoohpIz4hmNpVowCxyYl/2JxBX9qfiSLIYszcsUSBwsjapae SCRYAqdBRS
Rq+Cp32vpQbAQ+6VEf8pxVUMcJTpAJj1ZngOIM8EVpYwpgtSb8 A4UYRh/LF6
JWzOfDRCTFGjYnlDrInpiLKEOMhZosIX48T/ScgsoeAUqh2sgh nIYDEwaFJA
huE2zABQxB9FnkBbU+okRZAbFAC56sTpJi1FlRYg+Z5HJkJ5CU P4MFrPSQsQ
Aw3JGwLxKX/InS0kWXdB7Eolf3yqwfzpBk/H8hWogR2E3kqPHK mgkliD6RTW
HMeeRFGwAkgyki0DH0KRsUqKY21KYKzR39P1RwOPfKKPzSCZZN O9lGGREum4
rVsFxtFKa40eHk3JnOhUWJvaGkNTKTUYygmBgjI4jGgMNE1Cce kianTnTPSF
Rn0Z5PSl6JuNMQRsbD+DLmKlBYgvzcQskaZiWn2V/lh+7g2QP1 hKYb3R+wPU
UKmck+CAWseBJ9LVkbop+E2H68bCd2OkDqstlqbqSJmK9PrfdF +MZ6G6AgCL
gUL0bt0MihJiw2U6Y1hFwmUMYNd9BSqPYwP0W1+WFS7LtobLxk wEPnCkgTdH
eY43kGpxzTiJL6wWy/KbcMmOpiu2rCBSVoiltu2vKsCYArizkG /Z1ZQaciVc
dqU2XHYVfK+A73R4psFzORcumwHfmQWgwxmQbf9f6GSBiqyqaR UkpFingoEp
FKj7O8y2deeA4MmSJx+YGq4PyiVcpO4KlXLFSu31EUys8CYujQ EY2od0hhBs
M+lf6iaHTCHd5C54kc4gIbkkqMaXFl958KpeHOTgE9Hkw5s8+Q 4JFtBhIQ4f
fwcs0Riwi7daIJkMLx1TsMdAv1z1ngKypWtLaEvnp0oQ9qF/JL OYVGrYcyIL
dvjRjjNwHMgR29pOqMSTrYTk4ORJJiz+ZTrCWpE4/pzpyH6c+h RHHBk8h/+D
PZEZWtBi+Dxz/NFzJ7lhk13igCmU2otxjO+QvF203NLVugNyGZ CqJZVVKlNb
l0eP52QWUbLmZ8ujL8MoXMrQwojilsMOY42GBnEUoLMK4imVw9 aTWBZN0DnO
Gn0qB5f00e9l48YiG1q/pEYxSyrvWmb7xj4KCNPpQQH2P74LLJ nF0o10eZNB
KV/lR5dluqYQbH6ZNaich76b71Pn8X37cNeLx87j+RrtcM/P13 7D8ylrdJH2
2zyfop5/SJvx/CToNP0nhwfMX8M7wqKfNfhHC3i5hzMZl5M5Uy Ejq215NFt1
jqtSg64afvJryPzekTkHl2sDfF49n376qxYSSqcz5/3qz14gIN 8zsB/FyoU5
vrcZeuHLzCt3SW19V4saiE4G+LRwQH1STFIe1Z/vyoWb2skw5I Zwb5JZc/Fe
BItv9dbziRLOnbt9micLJ1y9gjdJPNqte8ALvlhxgE+8gNXCY9 g+xVP4At4v
3BdtbckC4l7lZ5PxGfnCSUYnrAV9tu4BAt/IczG9C8N9slKbMU rsH2kPOVJf
mRbfqG6Lauv5ZP3brSpAUjIZvJEetCmJNoGJKP/kHrR+0LyfiF +d3AW2JZg1
4wdtO2tYgnF9jvdST07GMGODYhYHZuUpZmm2mkKxUWCGa/MIEw brCKgOKQQF
idf6DmqVY3gNFy2kx/mkk8mGXY6LjkYPmEKUUHGM/OrlQ/GdQX 8T0Eb4XiVk
0czN4Nw8Vw9bBMnzTZ6X8hSeZODSBRfz4w2go2y5lcbMWvNvUf k0HmCP16v1
eBcRvmY3fCR5OVNo2IGxBq/q1ujP8VwXgZNuhP4dDl0iarpuOC GkhvuMZvB0
sCI6QU0RrCvgnlsRZbLOzpymRYNbkIav7lHcbgAPTxQ+PEQdA6 iVdldEjQo/
uBr8FJRZgffO6HXq4YIruY3taujZ6JlzcNmqce0lrPSAHFFnlu x9SicjazPK
clFZm6msP6pHyrInKqLvsN+QpUVZxnNkgV5U1spBWaoRsragrG wqawuVddOQ
rGyIf8aViPkEYn6oQswnKOak4ZjRYZhPI2YzxXyaYg6wg5geqj /YH9WxQ/hB
xBcoPnapeR10ughOknMyWDsQq5JiYZcy2TbEWAfXuUidGpYIrt PYaDhPRTbi
kJzVqxk5XEI5NFO97hgin6ToxWnUeTAdXUMLIhfLbaAJpfBI1u TWkCjmBP2d
ync90fl34uXC28t4YNNJLSBMKXGPri1aQFgfcU+IXS72S95T+0 MgLLV3DD3E
PBubhiBSdRYUy5f447hPOucDNLrtFL14C94oo/M30utvhvOoWp fC+dpYDd5e
W6i5Hj0yXEAZZmdk3IGg20aAblbu97gc9ih0+Yi0dhhS7ApF38 bhsJHKMYpy
kv2U71riLqgYcpnzpSo8TP/hpDKPP8YkBjcRDNVg136qYmiX4e SqNyTmnPqV
jz810yqgtjp3o0xZOf3LAi4mq7MVYQ9+PngNBLAWwQcRfJeCKg loodX5AcKW
DqHCEgFVbc5PEDwPwFJllIqmnpFbM/UPTuP+9zxZUGY5sd8UQk OzS30lHPF8
Oez3cDtuf/733Fni/7F37+FRlfeixydXIh3ItEQbW6qjOzmGVm nwgtEdIQEn
UAUNYqLWnRqQTEN2AhQSjDbAxABmGNNyutWHWu3mtPVsd0+tnF 6prd0TYnOB
lKbW6oyZCSGycWgohksxVZo5v/dda9bMBC/t7nPOH+f5ro9h1r ve63rX7V1r
VuKF32lQdwDq3x0ztr7cWFi0rymrO802epmsk2+aWt6xLMVItm NZiqSYLimO
dpdKL2Sohd7AvbFnUOqrhDmD6lZ9qXoY21iww+F5x9l0wS/V4T Vq955tm0hp
yvi5PtjeTWlKa/9oaYmkawp0p9ju/UK8H+e8LBf4HUvtqgx7UV ZTqnefTnfG
O5D8TF/V5NCVNF7teWdq41Wed6Y1Fkgb89qOpay/dGf7jJKFRv QMFT1dRV8g
0RkSvWFE1jL+3F9qVNVl6oreibelUlfUpCtK2+pv/OyOi6SAWa r8vJ1FA432
7F/OyP5l5qx93oHRCxeW6TQf0Wl0JWE1AIn1z3LjCZ33gNoq06 X8HantKQtK
JdT0p26rJ9WNVfx6VimXMmM9y+9a5n3b6/f2yWD89P+65767vW MJfSb3YZvM
dlZKwrPeqLdvmUr5zD1th9NOf+ee+77gHY+NF2zmJPmCJ8KurM BvDw17jrjC
wcbU4HC8THVnJ6Okh1+ZUW3Tl9sdD/9eZvW6qC9iKlRt7TtVdH u7irHGpOoY
qPu8XAJ3nI1Gi0uyH/fri2KKP2G8otOky+XcLWl0dNt45gNXRv O2Vdem2PTz
HNmLL9urT4mf0GE1ZLCNTt+r96cp3rN709VwPOH4c6hLvxoCqd GC5wUZLbgi
h84ag4e9Nh0c/5P1DGbGbr3kl2aC52br4PNnrQSLr9ZLnjYTeI p18CvxBJ55
eklLLEGJDjbEE5TV6yX3mglsT+ngkngC2zf1khuNBN6Ap393fn S3Gj+4Ivnx
ZAXGuswwy0l5SQfT4wl2deslp/5kJDh8UAffiK+s/VW95LeypG d7YWatdV2o
V+nOxNJN80iL86P1Rgu+LallFG3swuZ2W2I8ffXdnuXtzX5+kV 1uIXyLZnbk
eDpydobTH7/ZnWIL+kO35wy6zg2dDGV4ZGMGN73j9lW94249YL O75fYp2DB+
aNOYzzUmV8tgwztyAzi4KH2oz7v0nGQKdQYjQ38Y+rPOtFQy9a lMSydnku2s
OqyrdspeY7ueSdrMHz0zeTO/ZiYoMDZqbzzBV4wsQ6dlRLvPt0 iV2zme1TY8
xdP/ldYRNeS/YMAci7oiO618MkxdZPf077CimswathvlfcUoT9 1GquQy7G4b
zm4dGZNYz8HtCUXedEY/iJU0nv6N+dGNxtIrrIrqiiRYYrYuS7 fugrbhVE9/
UevIX5Jbd+q0tVZPGK3ISsonTUjz9D/ROnIuOd8LpxPXSgbfO6 2of5Uo2cDq
qi7HZ7Ycn4HY8blwNK2tKzVhlb9xSlWmd+TfRvLVk4+2kS3JK1 tu1eT5zdbW
N6Jb5aImi284ndR3d+iCfFOMlG3+jM7x9LbhdZ7+7a0jX01uel SSulVKlczT
35wfbTYijp6a3BfnThp9ka77IrNt2K774nRygd8/ldgX6Z7+x6 yof9FRxgZ5
3igs09y6apOk6E0ykVzcfUae2F7WPClbRttwlt7P3k7OVmBkky ZkevoftRZ/
NL5STxoFXmEUWGasVGq+X+1f/U+2jcxPKO31kwnrVCbr5LGi/u Ok0T6zuMCY
UZwj1kDZZeZLea0j/uQGPnIy1sAyh6d/l7V8bVJV0sMPW1F3xr PIOn/NWl58
Uh8Ac172uiLeiuOHGiLhil7rpBK69nGnnFRC09plv5MTS2jaTj UzbZf61zy/
HHX7XEfd09SZwnUk2HBksGrYVzUcbDhqtMQ71HnC4R3rHHbM6q rdbazoW8Zw
y3tKesrstN0X7GsdUY26Q+L/bSy2Ht6AHLue/m/mR79ptPfRMe ts/VR+9Clj
4QOq48YS1sEbMGbDVQMSCk3brdrrGpBgeJGsxLMquGnAqEIW6p 3q89KocMYe
iWrv9Bw+JAdd6L4cfXH2nJMRk6dPt6dX9rP8aJG5/7+lj0/zBO waCNkfz3In
9czSo7GTqOqaQ5siPlfEV3Fc946cQXXFh08YR25sfeXgSG8deV efq4oStvp/
N3rN85sWOXZbjGN30/ktcCS3oOpo7Nx/fguc3q62d7c8kPFzj3 lBUs25w2yO
jKQ9nRF1jBgHSHJj0uMD6YUeT//m/OhmI2L0xHktyv2b+sTzm4 dk/R4y1u9p
VdpdMzvSv9aR/nA4fZtNFWXfpnfKpt7QtL21f/3KGqX3fz8/+n 2jqSUnzH1J
72N78qN7zOP/RGzdOmUoL3vaD/KjPzCiphlZOkezPL/5kWrguT /q1VWPIuR+
sOW2tvGULR9Rqz3NL40anS4n7i036PCAhMMVA6Gbemv/yu5QX+ ToPd2dH3Ub
9Xf8MVa/Wl6bH601r39/jDdZmlbX+kZ2ndGD9xo5ar9lHHqNx3 WHql28VGV4
R4/7Hj8jrfH0TR11evqyRj+pvm/vyxud4embPTrduMvx9H16VI 6BAvMY+FZ+
9FtGze8e13duerwiK99YsCVHff/6C8lz7FSK9X1+23ha9tZF6r nIeHr2tqB+
QGKN0X563ByjfV4Hnz1unWj/8zt6yRNmgsb/qYOPxBPkGaOzJj PBU8ZYzB1P
cLExHLszVoUxFnOpbqhy9LSp4Zga2va0LcmqtXkcHtuxG1LU+w qS9jajdReb
WaNG66bGy37TaN34qJHgAaN1x0atBE6jda+ZCcyRYm88gTlY/I mZwBwp/tuo
Oik7ejyxwWKPR7VOTfqtCf2+ldV7D44m9V7d6OTeu3s0qfc+d1 77rh9N6r2C
eILLjPZdZCbIMto3RbVPPSixeq811ntmPnOUPPQH46KtBrrvHH vvge4Lf1AD
3WcnP1c37qnaXpIRbvpi73anlC/jQ+/2PDUzRZYUyEzP9mvNfp FRlnf7lTpR
Vpvf6d1eGEtXpGbus7d1DasDPc18RJheGfnf+np+TrUvozLyiI Ta93lGhjsW
OiTZRG/epVkDZmKJ3npKHefSnkLJss2/Ka3NP6VzPC39XTOJrT KyQidJT4qf
6DXjUysjpbHxg64yrTKSo6uUUqXWxCxS8745/vaBcpXoI0m5pC VDJ61cW5Jy
Of3DqbGMku7lk4kZP14ZeUYtGN5SruZ/fNJsq/O9m5tSGfnayQ 9enfWTy3fJ
ArvHTCDhZaqAKWZmb1fnu2nZz9+XF89ycWXkYyeNTr9Ub5q8Ya vHzTgjsaxS
oLxuRmUkOqaa5JCNatNbWjZzup5Ri7L0/pBj7Q853u12HZnT5k /zbndYCXNl
TtU/RdZRCmzv9C3K9Rz+slGXDONUgzxZ+2XYm5duNUgSt+qhxz k1Ms0tr3NU
RtZZwxQVXWaWNdNzeEgXlK4KchoFpSQWVDQWX7Mdi2aW12VWRv KMcU3dRZWR
v7xldIrHSCMp8rZY2SX+z8Y4QJX08ltGnQ7P4ReN1ItlK6nMJU a9qYn1+o3v
sncscljb8WOVke9aV/K6CyojnreMvcvhGTlkFJee57QKkQRffi txpZfFk79t
JM/Iy0qsc0kseVK1F1ZGromvhd1KY3fEc37MTCB1jp6wEpTEW3 JSLz1nfAGf
W6nHUZKqdX403WbL/qa/I2eb+RDXOCY+URn5pR6c2OM7dEf5u9 L4tpGSzndS
F+erB9+d41Paf5vVueOuiz0j6aoT5ZiSjWrGTc3aZ5WXXxlZI+ XtuEvt0553
Ujem/iDNs99jxRdURm4zhgt1V1VGrjjxXgf7Ysl6k/r1zc2SNc XKKulnnDDv
/633zFqPq4uqeWqUEZbd02Fv7zycGm5VN/7hir2++7K8Veo+Pu gfOhXsC1ft
kePX6xofdI0baUJ9wb7APrnHP6big5vOun1NZ92tB9Xoo0nu7M 8c2nTc5zru
qxgLNpz1ur4nx6vdWzWunyiMD50MZzhWSyGdZtaqs7HB1uSs4V Y1QAv4Qz8r
dKu3PNTI/Ii3InKo4chQX6AzuGnE7asYcbfuV7kr5F5heLDqnE /a3TDiq7Kn
+D8zpc2f7V2YLmspY6orZFixeaoaSH2qbTyjJdfn+l5CgYG+0F W50qxRZziQ
HGM2V9Y5dJVT5oY+rGLvQnvYtSc0rUASJ67r+2cKRiTD0GGvS/ d6n5FVfRbq
z6F9H5xd1+nwNu3scT2mdtVQxZ7YDUf2NvXlWdAfqtkTWro31L THpx/36I0b
WrondFOR1ODL9o59ZmF6x8wLZgXmvHyoYaex7qEDob69an+d1Z vil0zSFyrf
r4PDsvl/Jc3qCrweqyccbGoxHv4E9w0dVruF1BXsCmXoNYhXH9 w/ayhwILh/
6IB3LL4xX9LruH8oqIrLaJobDgb9avcyO+JDV300MxxQ1NPTMv tiYwUDH9hn
3rIs3+1238e9vbMGjPThikBoWonaZq5AKH+xmqnYLe3Ybz5bNd YyPRwcTQ0H
QheqjrNu67Kk9gy1xOgDb8U5KSQworemvnncKV3mD3YOHQ6c9L nsgyXpgVNG
15qVB/xDp4O/NrpJ+m7pHgnIP/vVP33SYb9WnSY/fUMHgp2Bwz KvBvVtx7PC
GeWqpVV+VVFvuGpX8EA4Jy/YN7jJI/+8uC4ajQ6+WK3/LZd/Iw f08Mkx2OCR
Fg7tG3xOxz2n4oIHQlW79CpN9HvOlWS3zZcTSjgYDpo1zcyLdE hule9w2LVL
ihh8TpUvG+6NpHL6Qxfendg7V4WmOT5kO5qboMqvOjd4QI6xE8 HOUI0/2B/v
fdX3sj0OSCcOGk+7X2+aGzxhJpDYgJyw5FCRbO+3eUINAdkcUk cw7OpVxZ8I
vJxQfCDYKfdYQ53GjujK3qYeVFk1mGlU7lBDr3oIIPdjNf5wxm J9lMpNWSBo
Jbxb1VOxM3jCLKvpCrWDqgNddq4i4/Bu6E3M1ZSvslw+pB6eHg u7diesl1Gl
2fSAVPtBXdnxTJF66bXC7k2d9M6semI4p0+d+avyOtK/0ZHe1j mcKnusb2eJ
W78ufKhhPJxRq/engbBHnXzl5B/2FKlzvqdABdVpKuxyhDPWqd 48pr57yJX/
ggfDVXtleaBL9tY3ggeHunpcw/qOw3gvtcflNz5kPD82P+zRj5 hlh302eCC5
c2X7/nrS8RYInvBVFKgvXlx27+dneqd6F6T7XE7vAkfY5R86LA fMoMtuXKrk
ANl0Sm6FT8VuheUqMnZo07jPNe6rkL45pXKMqONr79CfA31e1/ EPSa8uA+Ny
NOuOaZZVnrRR5ABt2qMKPRLc/yFFySErFcpdeZY6mZ4ZdJ0x2v zhLQ7VPBvY
P/Rnryv0YWmfbo6qXzwIzJGz5zZ/o97tPeoEX3HctzTirThS4n V5btif/UiF
3G1JrwX2h6t2+5Ye8bmOzBn0Lh2Xy76s6eLEtXbtlsPhpK644l Rsf1MVD1ad
8ck6NJwyVibUtNe3KeRd2i7FBSPeqkdLvUu3Dh3+x02B7EdeSV G1ZYWrdo6m
BvsONbQHu4ZOescTqgn6A/1D+2XDZLTrE4XU5jplPgw01nKX7g u5YFWr9ana
pR7NmZmH+kKunR/W+13S+92yntnPdwUOSM0V5yS/ynzYOrsNvl iizl5y1izU
50un/tehzpqPHzHOms+V6LOcjn9Oxz/nMM54n9qZcMLJ3nZA9v YbTmc/3CWf
re9Gp8hI8pGfyry+TgVD09r1dWbn0MnQj9U2k0P+cKjGYTYlJ8 88WV9yJFZP
qCY3IdI4n6u2RN59I3baDfQazYud1IP75IrTF+hV14yhThkgGu 1Wl9qkth8I
VQxYh+AnfBVHfEt3yfGvTk1+ObV4l/aPZoVfH1UHYt8itT23F0 3IVUBfBn2u
rb6KiFzIbxjI3v7Dv8hiWeSRgVb2Vx7SIfN04hp4/ZhZR0njTF /FsM9V4C3P
8i3t9y6WwZI/fHeO8ZVg6hx/xzPjE9Y7qvo+vt54H0g9JNx0/K 7KyPV/Mr7l
/0K6rzLLd5vdl+l1vdTmz/K6er29n3Edb/PLwdL/Oe/SAW/VK9 6Bz7jOlKg3
+ruc3qpQxwKn1zV8ixwLvkpHx4IUNYbuWJAlY2h9cNr1ezmVkV eOqEcn6nuk
8g7XS+WR772lhtHtye9rLTF+z2zOy77SXK9rwFvxyqGGgdC0Xe rUeN1u9W/G
s3p3PigHz8HYwdMfbOgfrOr1uXqDDQelAt8cb4+3KeArlfYP+0 pleHbEV5qu
WnOPw1t13LcsR87MvtKZJXJrq76pc9lb31T3Kt6mkLdqzFtxpv yuSOeIPuNL
aXd0uALlkb+cSHwYkvx9dOvxp8zxf1NWxCEZvdsajbez9He5Tw bkBqPM2VNm
t6l3oMvSU7rLivR9mvo2uCWgb46KSxovlKFtvWzaLxSEM3JlZn SGqiac4Ywt
LNAzheGMQjVTVhA4Kcf35sJgnwzR1Kas2qWSfaGwfLn5/tF4nW 155N4p6lcj
dvnKsrwPqzffXvidJxrdkyF1nvC5nurxeLKML751YGtioD0x8K gKOGwOHdhp
xBiBxxIDuxIDTyUGlpil1dnqctSbobuWR3al2Wy1b6hlH1ct9R pv79Q56i5W
wYckWJdR90k1vyYt4Z3uy9WSf1KxH627Rs2XG7GRvcPS94faxl ObHuwpc+i3
0cty1KvoPWW5OepqWTZTf7gec6qPbepEoVO5PFv1x1b1RkrPtp ao8QZ7j6vd
rT8e3ag/dtqW5acanV3eoXOXR26Wo/LYp+LPU32Z6kHqI+q3Sq J524pkS0lT
9OvyZTnqXXlpis1oin5q+JSe1wlGP6K2twQGjNQlRsMLjNTqY/ RL3rMftGKj
y3S8GgbH8yfEqweAPdX6AWD4VfPZ5EodPPhq/Nv3VXrJL1413l p66UxH1fBy
n96jy9W3VEXl4bJC4/wu+6Ax4yvLKfeVOcojR/W37+otL4fZT8 sjO941S5Ld
8a7ItdKqurS6m9X8rpT4i3qPpupdQy/3xJbrHJtldV8IqJ02XY o58cKrev89
oWP1bnRMdXuZflNY7Q0/sMV2cvUY7UR32WWt3WWXf6677B8e1e v3rF6/0O/N
DviuDv769/EO+J5e8nO95FxdSl1Kh2tXeeTbVqNUL1zm6X82/v 33763v8C73
9H/XWt5sFaqi/sHT/z0rqkqiOp65O5p4XtbvwlQ55LTTOTLNO5 CW4t2lfrc6
bdlM75Nq5l4znfHKjE7jPZ6W0qN+D1u/I6ny9HhsSaGEuNKZ5w VjaaWOnodj
cQnv+RgNasqx2lRa1L7rlTSVocg71v7w79Ns5mtK1rsx3gUzO9 rVqcJ7S5bM
ONRMjlpSbfNOVQvk85YitcAuM8VqplZm0lWUmimRGVlZ7y03Z9 h2yueC3Pjv
8+Uar9hIU9LKi3Y8/LrU3u6Kdj/slxlnwntQuoNUy0uL23eqNw /VzK5fpcX7
cFKag7E0v0lIY727dk52WNmx/kfU2CMuq0tZHnksGnv0VZddl7 o8stWMlJ17
eeSBeGRmXfryyBetSClmczzSpkpaY0VKMSsSI6WkZVakFHNzPL KkLmN55Foz
MqMuc3nkisQGTVke+Xg04Slc1vLIlKj1ftwHbFt/fNv6E7et2R f6V2hkHV6Q
wupSVWh55PtGxdJHqSr4ryoq3eixfzGjMtTrwkYfSYdkqPlmM2 qKLJDgahWV
pX5rYHmkyoy6QBZI8DYVNVVCMr/AjPqIenVzeeQaFWWXkM1a/7 ppskCCuSpq
uoRk3m5GZcsCCf5FRkPS9Gw1f9L4hby6W+SqI8ERFZUt1xWZf9 WMstV9TAV7
VJStboaa//lEYl+q3zPVu37dXXWXlt8R6TR/yVS/D3L+tLn1md bWF7/e2rrZ
DEcHo9GuN6PRzbEU9RMytRQ5YmFHUUtiMLe4+M0338zNLbbCsk ttjoeNJLnG
XFRPb3apCqy/51fsXrDAXRyP7/r6iy9+vcuMv2T6J65u7pfJ/H OExW6ZinOl
AiM8/5r56s92rhsbNsJb7t9yv0xffPOo36w8d7D4zeJBM73HPz w2PjE+Nuz3
6HBq5vRL5k3Mu2R6ZqrV/Nzc3M2xBtvcxiSfZvmDg4Nf/qSadL Clu7qovru7
vsje3ZLQq6rLJpW3OTGspljz9BSvUBbZJ+y5CYUVVk9UJ/3xUb /fP5EQzHNH
3XnxoKOoqKVlIp5ANl5LUXx7TZpk2xSrxpjtkVXNS05QXz9Rr3 +M1rZ07/O3
ZGZu726JrcG+bntuYXX3diNUVF9ftDEk28v4IxayaaqTipO0es q1myuXa9dT
bnwN3cXRYndiE+NbO2FZQgbbZtt5UzxHaqZqn7m9ZYN1Hxw6e7 Q7trlyi5rN
LRCLN5J3T1jhzOLMzMxYevvM4vr+CWnwJUZ4QjbGuYT4omoJd3 db5U9IfmOd
rfq7WxLi1fxmyW+3/tymbnnCCpvh2Orq5kmvZSaufUIH6DiVxi rfnrB9dX1D
Q0Mhv1m/Q+2+E6pBRvic7AEtao8/Z4SL3ftkDf37zAPUNl5vHB D14+b6uVfW
NtdWr3RPJIWrq8cS8g91d7tvNMKqJl2dWV+xeQDEzheX6L0hfr wflaqam6XS
o0Z4rFpPVn3qTDLYpSaz/KNnJ4YOxsvXfZ3Q33r9quPtM+NfHW qxT7fi1Toe
teKri+yZVv7o4NeT2ts9qfwuY3LHjmcdGhyMxs4fOiq32B1rr5 E2Xl60a7va
eJ1d5t86LY79TerY+VTOYOuKZlrnq2K7ORXHtqbt/aaoOhwnH0 gyNdtbrOPV
Nlxd3aw3cfx01tItO0Bs/WZKTfX98fQ6fiIeX1S/qnosoX9l2q iS97fY9SaV
8us3uuP9K/tlUWJ/Zmbapmfqya13OUlv7ABm+qJJ+4tMR6ODar LCIfOUHW9f
wvax4lusJsbaFzukQxvdSe1X53jr9O4oLDyn/070TCteZ0/oj6 Ttb4TVDhAP
S6TsAFbY2H82Z9pjh1S/Op+a+/d0WdV1an2nx/pLH8zW9UPFqT S568yVCdkm
TfoIjxVnHs9yONsz9Rr1J7dfnYcTt6dkTt4/+pP3FznbJIWL6o uS06saZRNK
dbEdNHl/6U7ef1R5SfFuW9L+IR2XFFbpE8Pd8RNarDmJYXVanH BXy7Z3xy+Q
a/7xk5sDoQeMwDzZuSdUfxy01j9p/+lO3p+M9sbDhc39Sf2p4p P2j+6E7d2s
gi1J549u64TSYm7uzV2yvbpiV0Dr8Dpqnp/VzhQVZrycvlpWut fK/n1ah6d/
MldfPmUKrDM7IHH7qO2d1L8Sn7g+KpzUftm/Eo4vCVknXGNj19 fPS7waqeGA
LXFkpP/QulxeE4dL6hrqT0gzoQ5/Y1Z21W51OBz8Rqb90njYff CJeUYS42go
Lk443ubWB+rnJhQnofqAMfvRm5NVfDdZ+IFkue89jU8KWeG5xn TW/Iy1YiIp
PDn92Uwr/eTJ7I7k+LOZ1r5rLrHCsfbYkqfk9ubmXpqUPjd38t /Vjk5OH5uJ
xU/OPym1ld5s3/VJ7b++cH5SbfMLk+PftiW3J2p7e1J+K70Zb6 U381vpzbVL
jp87d3L50cnrN2kzWO2NrV9S/kvP65/5k/Jb5Zm9Nbl/J28vq7 zopCnWvtg0
NmnKnjQlZzOnjaFAIBAyj2d1bxXol8O33wjLmdJvTLHkavivpl iwW85p8euT
TJsDaloXC8aurrECNoaS+mZzbrFxB2eGzdOznCasYLeq7oQRvk SGs/P0PV+8
PrnYx08xaZkSPr05Vt3Mwmp1eq8ujF2frQGgtT6x/8zJvL2IdZ I5fLZOYuZw
OxaeLnd+uedNiesvhW1OHL+rk6R1Vdbnw/Om829vYjPZemx3vL 6+2FifQOKm
kGldoLC6N3n3aTGm82tRKzfn6muuvW7u9UU3rFh5/6oa9xdrV9 f9c33DmrXr
vrR+Q2PTxgeaH3zoPTOel790wcKbXWWLFn/ulluXLL3t9vJldy y/s6Lyrrvv
+byt+LaKJUvm2f5bToqtxPwpTJh/rx+n+ZmbsGyuyndRiq3y/5 Ofkr8h7ccu
TLGVv8fy91pmk5+58hO4MCGdOb8uId3N8nNHzYpVq9d80Tbbtm rtmprZzoL8
1c6VDzbWbHCWOPMLi5pnTbVdPbtwVc1G290r1zY7l6xe09TsvH uBa8Htt9/p
dOZvmGq7pane6bzGeXVh4TXvsX/kb3Be5XTWNjauu/Gzn22WIq 6qV0XM3uCe
vaamcaqtYOEsyXm1M6H0O2tWNEimJavvr1mzoWaVs2nNqpr1zs baGuei8iVT
bVNt5bUPbvjcmtWN61eVr93gvMlZ2KxaOtXm2nD/inU1C9euqk le/kHT4lXr
l9t0k1auXds4+373F5Pj/7lm/ZqaettqXZ1t/eqNK9wrbRtrNq iP5gcbpC7b
3GsLm68tklFTYWHzXBnNrFi3rmbNKjO/c+PqVTVrb1IZbzQTXr lmbUPj+vXy
UfvA/U3rN6xdf6V75X0NNQ03Xbv0ysaNN9125/KFTtt/PX956R KnLf9upzOW
WTX3RrN18QoSI2Mlv2dkQk5d9PtkNKrdkL/Btm5FY63z8vwNl0 81u88MGJ1o
BjaqvpP5VTJ//9qGhhVrVjllO9TcaMbHJ8+S228tLSjNi7xy46 vzLprxi6fv
dA/P+9nOb8164ie/mzd1ZdoTn/h3x3wj/Ma8637ycl/eD1Pn33 nE8aUNn/7Z
vNOxUmrXlZx7+vr75t76xrwPK7Pjjz/e/Xb331zmnh8dKy+97+ KaRWdaXpu3
5af/2bt24/ll9vWcSM3PODrvxVefndh4UZpVpjP2/1tp31ASS/ PXlvl+7Uws
M6GdzmvvvNUqM/v0t49lpB7+u9o59bVvjz296NbS1yduDP1weW DeW1/q+fhL
6w//XdvobME/HVLrHttGPU/suNr/3UPnlfl+7XyfbaSn/v9YXX rlazVH7hzZ
MG/PZ1JsP5Ifv/wMyE+P+al+4tOwOd7LLYnlM8JjJebnvH37dl Vu+d3T8578
uppOmunHSr9Wda7loRf3mekLSxc//4snT722Y175Z+WcLD/LE3 5iy759XYrt
WfnZIz8/Nj/98vOr61KS2+NZYdQ/vMpsxx7zMzaevtIM+82www yXmJ/lJSdr
32j/8fhLRvtKvlry5ZzvLzr80GNG+vGvmunG58fqPffvJ19eur Lc6o9Yfya0
i+OV4/X/2vF6+CG1g37a3E+vLNl7ybbRZUWzSy6Vj73fvMrcX+ 8pWXlriq1N
fnbKzx75GbjV6AjzLQ/9RXLhnNmFc1Rg0cKFNzoLFt1WMct59e wbrpt9rRrN
zJmjxiUFN9esXL1ijXPd+pr1NfU1KzbUzKKMSWXQr+/dJ0x//6 T//48yiFxd
M7u50f3h6f8r0wf8/x+vue6666+fe/Vc8///KOHCa4173mv4/z /+v5juvrOs
0Cmf6tbxg9KtiRqPryb/HxBHpwMAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgP/THv 28xlHGARx+
dxMSg2D2oCc9LOJF8Mck1s3BJOx2TUwM1aU2UNv0kDRZTCpu2c 7UiBg7x3XI
0buCV/8EpTlVD4Kn9FARpVYCKyHoIaCQdRJ7UEFFoQHh+TwM7x fmnXcGBgAA
AAAAAAAAAAAAAAAAAACOx0z1xVq1Oludm6lV52br1dlGo3N7uH B/vZ71nT+f
Xe5vZlH3oWY20Jw4dyp+sDlx6lz8QLobSiGk34e9Xq97O5sen+ gNh/DmTudG
YT8bnGhMhZDcyl5Y3xwf2Al5Fzbfn8+X7OVS9u4jm+OTWXHoej z3+Gdb3xSz
/sF8Lhb2OsWTed3vFp5fubp6cWVhZrG9vLx65VK00Fhsx6vxau uN0bC80lxM
Xo+fWl9aCaP5iRcL4ajswqtDt+KZ9LnTr9RGkmr6dqkQCiEZ+3 m4vJV+2+sd
9IYf3bpRL/Xleztff5zuHg4Tnzw891HyY3q1t53dfDL9POSP5N t+6Z7u/FS/
e9T+3aPioXw4fCi585/OzN6Zf+2D/P5aWLtvrdy7uVbIp8GjKZ zJx+Lm1BON
zanZxqel/InpdHL5w3LI374xkF1rFJPddKN0uCu58970wWN745 eTr65t7O8k
2y+lk/PZD71kv7fdPQjH1vLiW2efXlpp538ibt6jd0QjUVQ5cS JEv/XnNRoZ
zeexSqUyFj1TGXs23z86UolCObpH3/OHkivxYrtcDu1WK/67ff 90/3/a2TPT
UflwXWqtl0+2Wpf+Yl/f79daqBXyq5hftdr1UP2i/8vuQe2o4/ hmSZIkSZL0
7/oVB1YC3wCIdwA=
Previous Topic:WMD
Next Topic:It was a sad day
Current Time: Fri Oct 23 17:32:14 UTC 2026
Total time taken to generate the page: 0.004831075668335 seconds
