Toymods » Tech & Conversions » 4AC water pump question
cri_ag
northern beaches
4AC water pump question Fri, 04 July 2003 09:47 Go to next message
im doing the head gasket in my 4ac sprinter, and i wnt to pull the thermostat housing off but there is a pipe that runs down into the water pump housing. how do i get this pipe out? just pull it? i cant see any thing fixing it in place wasent game to just yoink it but. also whats the best way to mark the position of the cam gear etc?
Rolla Boy
Club Member
Sydney, NSW
Re: 4AC water pump question Fri, 04 July 2003 10:32 Go to previous messageGo to next message
Is the pipe your talking about the one that runs behind the cylinder block (well in a Rolla anyway Very Happy Very Happy Very Happy)???
Line the cam gears up with the dots that are already marked on the metal plate behind them... They are the timing marks... So when you put it all back together, if you set the cam gears to those marks, the timing will still be correct...
cri_ag
northern beaches
Re: 4AC water pump question Fri, 04 July 2003 22:40 Go to previous messageGo to next message
nah the pipe is like 100mm long and it goes straight from the thermostat housing to the water pump.
cam gears? i only have one! Sad
haggis
Re: 4AC water pump question Fri, 04 July 2003 23:11 Go to previous messageGo to next message
the Max Ellery manual discribes the way to get the cam and distriutor timing lined up right.
I have manual for the 4AC in a FWD corolla, but its the same engine as in the AE86.
The manuals are pricey, but worth their weight in gold!
Craig.
cri_ag
northern beaches
Re: 4AC water pump question Fri, 04 July 2003 23:36 Go to previous messageGo to next message
its all good i gave it a yoink and it poped out, ive been trying to get my hands on a manual
[Updated on: Fri, 04 July 2003 23:38]
Re: 4AC water pump question Sat, 05 July 2003 08:50 Go to previous message
Yeah, these pipes pull out, but getting them back is fun Very Happy Make sure you get a new O ring for it, and smear a little bit of sealant on it as well after giving everything a good clean, otherwise these little mongrels will leak, leak, leak Surprised
Previous Topic:strutbrase?
Next Topic:Join the Dots on brake fluid???
Current Time: Fri Nov 20 14:37:19 UTC 2026
Total time taken to generate the page: 0.0064589977264404 seconds
