Toymods » Tech & Conversions » 2wd v 4wd hilux diff
ke20 4agze
2wd v 4wd hilux diff Fri, 04 July 2003 13:01 Go to next message
I am putting a hilux diff in and can pick up a very low k's 4wd turbo diesel lsd one for $250. Is there any difference except for the 6 studs? Are the centres the same?
hiaaa
Re: 2wd v 4wd hilux diff Fri, 04 July 2003 23:09 Go to previous messageGo to next message
yes it will bolt on, the new Hilux turbo diesel has 3.72 ratio ring gear.
ke20 4agze
Re: 2wd v 4wd hilux diff Sat, 05 July 2003 04:59 Go to previous messageGo to next message
I was told the 4wd had bigger bearings and housing. Is this true? I looked on the toyota site and it said the ratio was 4.55.
hiaaa
Re: 2wd v 4wd hilux diff Sat, 05 July 2003 06:21 Go to previous message
The 4WD Hilux LSD center carrier is little different to the 2WD one, stronger & heavier, but it still can bolt on to the 2WD diff housing. For the ratio you can count the gears and find out.
Previous Topic:anyone with an AFM
Next Topic:DRIVE SHAFT MODS Please Advice !!
Current Time: Fri Nov 20 13:22:56 UTC 2026
Total time taken to generate the page: 0.0076260566711426 seconds
