Toymods » Tech & Conversions » Hilux diff info
RYSO
Curacao; N. Antilles.
Hilux diff info Fri, 04 July 2003 13:35 Go to next message
Hello, I'm new on the forum.
I live in Curacao, Netherlands Antilles, in the caribbean just a few miles off the coast of Venezuela, Aruba, etc etc.
I've noticed that allot of the guys here on the forum like to use Hilux diffs.
I would like to receive more info about these ,like model,year,engine, etc etc.
On the Island we also have allot of hilux pick-ups and Hiace vans but none (to my knowledge) are LSD!
Thank's for your time.
rob_RA40
c'town, NSW
Re: Hilux diff info Fri, 04 July 2003 13:39 Go to previous messageGo to next message
welcome to the forums Very Happy
check out this tech article
http://www4.tpgi.com.au/users/loats/technical/mx23 /hiluxdiff.html
the LSD center is taken from a MA71/JZA70 supra or MZ20 soarer and fitted to the hilux housing.
hope this helps
RYSO
Re: Hilux diff info Sat, 05 July 2003 13:02 Go to previous messageGo to next message
From what year should I look for?
[Updated on: Sat, 05 July 2003 13:06]
cambelt
melb
Re: Hilux diff info Sun, 06 July 2003 10:15 Go to previous messageGo to next message
A lot of hiluxes had factory lsd and i was led to beleve that
the 4WD ones had greater spring tension and more plates
Re: Hilux diff info Sun, 06 July 2003 10:33 Go to previous messageGo to next message
Ryso, depends what car you want to put the diff into. The RN27 Hilux (late 70's or early 80's) has a 1370 mm hubface to hubface width. Most others are 1410 mm across. Hiaces are generally 1570 mm across.
Check the build plate as this will have a diff code - it will be G followed by 3 numbers. If the third number is a 3 or a 5, then the diff centre is an LSD. The first 2 numbers will indicate the diff ratio. It can be deciphered here.
If LSDs are tricky to find on the island, with the 4WD capital of the world only a few hundred kilometres to your north, surely LSD centres would be easy enough to get from there?
RYSO
Re: Hilux diff info Sun, 06 July 2003 14:40 Go to previous message
I have a 1984 KP61 starlet, 2 door that I'm going to turbocharge now, so I don't want a numerically high gearratio. I prefer somewhere between 3.90 and 4.30, if available from factory.
I can get my hands on older hilux pickups easier that the newer models (mid 70's to early 80's).
Do you guys shorten the axles and housing to fit under a KP starlet or swap it "as is"?
P.s. What do you guys mean by "hubface"? face of the axle?
[Updated on: Sun, 06 July 2003 14:47]
Previous Topic:will these wheels fit?
Next Topic:brake master cylinder for ae-86 sprinter
Current Time: Sat Nov 21 07:36:59 UTC 2026
Total time taken to generate the page: 0.004619836807251 seconds
