Toymods » Tech & Conversions » If my speedo is wrong, will odometer be wrong too ?
Les
If my speedo is wrong, will odometer be wrong too ? Tue, 02 July 2002 07:37 Go to next message
If my speedo is wrong, will the odometer readung be wrong too ?
Question Question
Sam
Sydney, Australia
Re: If my speedo is wrong, will odometer be wrong too ? Tue, 02 July 2002 08:30 Go to previous messageGo to next message
I'd hazard a guess and say yes... actually I'm pretty sure it would be...
Re: If my speedo is wrong, will odometer be wrong too ? Tue, 02 July 2002 08:38 Go to previous messageGo to next message
It most certianly will be!
TCHOON
Sydney- Sutho Shire &...
Re: If my speedo is wrong, will odometer be wrong too ? Tue, 02 July 2002 11:44 Go to previous messageGo to next message
A lot of speedos have a built in error , although Toyota ones seem to be very accurate when I have measured it. You know those 5km measured sections on the freeway... well 5km at 100km/h should take exactly 3 minutes.
If there is something wrong internally with your speedo, that won't always affect your odo, but usually would.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon1.gif  Re: If my speedo is wrong, will odometer be wrong too ? Tue, 02 July 2002 12:30 Go to previous messageGo to next message
Chances are that it's off too... They both take their input from the same source...
Les
Re: If my speedo is wrong, will odometer be wrong too ? Tue, 02 July 2002 22:46 Go to previous messageGo to next message
No wonder my calcs for fuel consumption look a bit off... like 13-14 l/100 km !!!
no worries
Re: If my speedo is wrong, will odometer be wrong too ? Tue, 02 July 2002 23:36 Go to previous messageGo to next message
hey, dont knock it.
that's about what my celica uses
Les
Re: If my speedo is wrong, will odometer be wrong too ? Tue, 02 July 2002 23:37 Go to previous messageGo to next message
HEHEHEHE Exclamation
Re: If my speedo is wrong, will odometer be wrong too ? Wed, 03 July 2002 01:31 Go to previous messageGo to next message
Thats almost what mine uses, and urs has about 100kW on mine Razz
Averages between 11.5-13l/100km...and I guarantee you'll be putting the boot into your car a lot more than me...at least your car goes fast when you do it!!!
Les
Re: If my speedo is wrong, will odometer be wrong too ? Wed, 03 July 2002 01:48 Go to previous messageGo to next message
hahha
but the thing is im am sure it uses LESS than that !!
cuz at the rta... when i did the emissions test, it said 9.7l/100km
(presumedly highway driving)
Re: If my speedo is wrong, will odometer be wrong too ? Wed, 03 July 2002 01:55 Go to previous messageGo to next message
Yeah, yours will surely use mroe than mine, when your caning it...just normal driving should make it return heaps less than me.
And as for highway...even the Celica can return 8.9l/100km on the highway when I'm not even driving it that nicely...I'm sure the 1G could get low 8's or like Nark, into the 7's! Smile
Nark
Cabramatta, NSW
Re: If my speedo is wrong, will odometer be wrong too ? Wed, 03 July 2002 02:27 Go to previous messageGo to next message
I get 7's on the freeway and 11's around town.
Although if I stay on boost, the fuel consumption skyrockets.
Les
Re: If my speedo is wrong, will odometer be wrong too ? Fri, 05 July 2002 14:15 Go to previous messageGo to next message
MAX
I dont see why ur speedo would be right and mine wrong ??!!
both originally 4 cyl, now 6 cyl... and im sure u had to get a new manual transmission when u got ur conversion done...
ive been told that its because of the transmission, that the reading is wrong... so i need a ratio converter... WHY WHY WHY !?!?
why is this so !!
Nark
Cabramatta, NSW
Re: If my speedo is wrong, will odometer be wrong too ? Fri, 05 July 2002 14:34 Go to previous messageGo to next message
My speedo is off by 10%. But this is mainly due to the larger rear tyres.
I don't see why your speedo would be wrong if you have a different gearbox.... The gearbox will spin the input line at the same rate no matter what.... It would only be affected if you changed wheels or diff ratio...
Maybe I'm wrong in this, can anyone verify?
RA23_Sean
Western Sydney
Re: If my speedo is wrong, will odometer be wrong too ? Sat, 06 July 2002 05:26 Go to previous message
Possibly a different number of teeth on the speedo drive inside the new box?
Previous Topic:were to get new or used ae92 4agze cv from?
Next Topic:Brake upgrade : AE71
Current Time: Wed Nov 4 07:56:09 UTC 2026
Total time taken to generate the page: 0.085813045501709 seconds
