Classifieds » Parts Wanted » trd 2tg oil pump
juzzo84
Hornsby, N.S.W
trd 2tg oil pump Sun, 06 July 2003 05:46 Go to next message
just wondering if anybody has one of these they wish to part with
justin
Geoff
HORNSBY
Re: trd 2tg oil pump Sun, 06 July 2003 12:51 Go to previous messageGo to next message
did trd even make one of these ???
-steve ( devil rolla )
juzzo84
Hornsby, N.S.W
Re: trd 2tg oil pump Sun, 06 July 2003 21:33 Go to previous messageGo to next message
yep
Geoff
HORNSBY
Re: trd 2tg oil pump Sun, 06 July 2003 23:58 Go to previous messageGo to next message
well shit a brick aye
-steve( devil rolla )
CelicaRA45
nth ringwood, Victoria
Re: trd 2tg oil pump Mon, 07 July 2003 06:56 Go to previous messageGo to next message
they made that part overr 15 years ago its not on there list anymore and was used with there oil squirters so a stdd pump will be fine
roadrunner
Hornsby, Sydney
Re: trd 2tg oil pump Mon, 07 July 2003 08:33 Go to previous messageGo to next message
I know a guy with one but he paid $550 for it and would want a small fortune for it.
juzzo84
Hornsby, N.S.W
Re: trd 2tg oil pump Mon, 07 July 2003 21:08 Go to previous messageGo to next message
thanks for that ra45, thats good new,
thanks for you help alex but it looks like i dont need one anymore
justin
7mgtema71
Re: trd 2tg oil pump Mon, 07 July 2003 23:25 Go to previous messageGo to next message
I was told that the 2TG oil pumps are better than the std single cam 2t motor. They are suppose to flow better, but i wouldn't mind getting my hands on that trd one your friend has "roadrunner".
Can you send me his contact details to supra7mgte@hotmail.com please?
frank
7mgtema71
Re: trd 2tg oil pump Tue, 08 July 2003 01:13 Go to previous messageGo to next message
Hi Guys,
I was told the std 2TG oil pumps are better than the single 2T ones and that it's not recommended to use it in you twin cam application.
But anyway, "roadrunner" could i have those contact details of your friend who has the TRD oil pump as I'm interested in buying it. If you could send those details to my email supra7mgte@hgotmail.com, that'll be much appreciated. Thanks
Frank
roadrunner
Hornsby, Sydney
Re: trd 2tg oil pump Tue, 08 July 2003 07:39 Go to previous messageGo to next message
i dont really have any contact details. i see him sometimes through work. i will get a phone number and see about how much he wants for it and get back to you. may be a couple of weeks though
CelicaRA45
Re: trd 2tg oil pump Tue, 08 July 2003 10:34 Go to previous messageGo to next message
all it is ,has a spacer like the 18rg 1 so look at a 18r and 18rg and you will see what i mean
7mgtema71
Re: trd 2tg oil pump Tue, 08 July 2003 23:14 Go to previous messageGo to next message
So you're saying the 18R and 18RG oil pumps are the same as the 2T and 2TG one's?
CelicaRA45
Re: trd 2tg oil pump Wed, 09 July 2003 06:19 Go to previous messageGo to next message
no im saying look at a 18r 1 then look at a 18rg 1 it has a spacer of 4mm so it is a high volume pump thats what the trd 2tg is like with a 4mm spacer
7mgtema71
Re: trd 2tg oil pump Wed, 09 July 2003 06:37 Go to previous messageGo to next message
How do you know that the 2TG TRD oil pumps use the same alteration as the 18RG TRD ones? Have you seen this? If that's all it is, i'll just change mine.
I was told it's not a good idea to increase the strength of the spring (or what ever the spacer does) as it does increase the volume of oil, just the pressure. Now i can see this breaking out in a huge argument about "if you increase pressue, you increase the volume" saga, but it's not the case. But a little extra pressure never hurts.
Cheers for the TRD insight.
Frank
CelicaRA45
Re: trd 2tg oil pump Wed, 09 July 2003 06:45 Go to previous messageGo to next message
when we raced 2tg we put a 10mm bolt in where the spring,releave valve also make sure the welsh plugs at the back of the cams dont pop out your pressure drops off fast if that happens
7mgtema71
Re: trd 2tg oil pump Wed, 09 July 2003 06:54 Go to previous messageGo to next message
Hmm, a 10mm spacer. What specs was the motor you were running? Did you change the crank with the 3T crank? What class racing was it?
Do you have any stuff left over or know anyone with stuff left over (like TRD gear or any other goodies)?
You can email me directly if you want as i'll be very interest in spares you might have.
frank
roadrunner
Hornsby, Sydney
Re: trd 2tg oil pump Wed, 09 July 2003 07:57 Go to previous messageGo to next message
You should fuck with your oil pump unless you know what your doing. And even then shit goes wrong. fuck up your oil pump and you have probably less than 30 second before your engine says bye bye
thetoyman75
Club President
icon5.gif  Re: trd 2tg oil pump Sun, 20 July 2003 10:32 Go to previous messageGo to next message
Why do you want a "bigger" oil pump anyway ????
If you actually have a real reason for needing one then look no further than the 3TGTE Wink They have a higher volume pump to maintain oil pressure thru the turbo and turbo lines. They are distinctly different to a 2T or 2TG one when placed side by side.
And yes I do have one but no its not for sale sorry.
juzzo84
Hornsby, N.S.W
Re: trd 2tg oil pump Sun, 20 July 2003 12:45 Go to previous messageGo to next message
man i actually have a 3tgteu oil pump sitting her.
justin
Re: trd 2tg oil pump Sun, 20 July 2003 13:00 Go to previous messageGo to next message
a guy i know (Tims Toys) modifies T series oil pumps by putting R series gears in it. similarly, you can modify K series pumps with T series gears, and also R series pumps by adding the K series gear to it.
since they are all the same outside diameter, and the different series have different thicknesses of gears, if you put a thicker gear in your pump body, and get a spacer made up to increase the depth of the pump body, you have increased oil volume by % increase in thickness (approx)
so, you can get an R series pump, and use those gears in the T body. (BE AWARE: you need to either modify the R shaft, or attach a T shaft to the R gears)
so, does anyone have a good condition T series pump they'd want to part with? TG or TC is fine i think, as long as it's thicker than a K series pump Smile
juzzo84
Hornsby, N.S.W
Re: trd 2tg oil pump Sun, 20 July 2003 21:35 Go to previous messageGo to next message
stewart, its justin here, i have a 2tg pump you can have for $30
justin
Chriph
Re: trd 2tg oil pump Wed, 23 July 2003 10:04 Go to previous messageGo to next message
Hey Justin, how much would you want for the 3tgt pump? I might need one depending on the oil-pressure problem diagnosis I get in the next few days. CHeers, Chris.
juzzo84
Hornsby, N.S.W
Re: trd 2tg oil pump Wed, 23 July 2003 20:20 Go to previous messageGo to next message
probably looking around the $60-70 mark for it
justin
Chriph
Re: trd 2tg oil pump Thu, 24 July 2003 02:57 Go to previous message
Cool, might be in touch soon, we'll see how things go today. Cheers, Chris.
Previous Topic:Want original SX wheels.
Next Topic:WTB: MA61 strut tops
Current Time: Mon Oct 26 04:54:52 UTC 2026
Total time taken to generate the page: 0.078014135360718 seconds
