Toymods » General Car Talk » Speedo calabrations.
DiZ_
The Eastwood MASSIVE !
Speedo calabrations. Sun, 06 July 2003 08:30 Go to next message
Where can this be done , can your local mechanic do it or does it need someone a little more specialised?
mr spears
sydney blue mountains
Re: Speedo calabrations. Sun, 06 July 2003 17:01 Go to previous messageGo to next message
not 100% but think you need a specialist, i think there is a place in st marys on forrester rd if your anywhere near there
tanman
Re: Speedo calabrations. Mon, 07 July 2003 08:17 Go to previous messageGo to next message
Yes you will need to take it to an instrument shop. The cost will vary depending on whether it is mechanical or electronic. I had the speedo recallibrated and the odometer fixed in my Cordia recently. If it's a mechanical speedo (cable driven) you have two options 1) the speedo needle can be repositioned
2) fitting a ratio box to the cable
If you fit a ratio box the odometer will read correctly as well. To work out what ratio to use or how huch to adjust the needle, the shop has to determine how many revolution the cable is doing at a certain speed or count the number a revolutions over given distance.
This sort of work is not cheap unless you have a mate working in an instrument shop Smile
DiZ_
Re: Speedo calabrations. Mon, 07 July 2003 08:41 Go to previous message
It's mechanical.
Previous Topic:Stolen: 1988 Toyota Corolla sedan (white)
Next Topic:pod filters
Current Time: Sun Nov 1 05:50:00 UTC 2026
Total time taken to generate the page: 0.0049941539764404 seconds
