Toymods » General Car Talk » Engineering problems...
Henn
Rosanna, Melb
Engineering problems... Sun, 06 July 2003 14:14 Go to next message
I'm putting a 4AGZE into a Sprinter and would like to get it engineered and (semi)legit. But I just found out that it can only be engineered if it is running the stock computer (NB I am in Vic). Unforch I don't have one (I have a loom cut at firewall) and have a V4 Wolf instead. So my options seem to be:
- Find/borrow and fit a stock computer to get it running, even if somewhat dodgy, then fit the Wolf once engineered.
- Gut wolf and put it in a factory looking computer box and rely on stupid engineer
- Put dummy factory computer in footwell and hide the Wolf, which is actually running the car, elsewhere.
- get the Wolf working then splice off enough wires so I can plug in a factory computer to get it through engineering.
- Dump the whole engine and fit a 3SGTE with stock computer instead.
Anyone got any idea of the easiest path? Please put your 2 cents in.
Hen
Re: Engineering problems... Sun, 06 July 2003 16:09 Go to previous messageGo to next message
if you can find a lenient engineer (ask around the melb car clubs, they're bound to know one), then chances are he wont look too carefully at the ecu, as long as you make the wiring look professional.
*not* like my engine bay, everyone at the dyno day will tell you Smile
Grega
melbourne.victoria.austra...
Re: Engineering problems... Sun, 06 July 2003 22:17 Go to previous messageGo to next message
henn, its coz your car is post 76 - it seems that most things after that date have to have the stock computer OR have to be emission tested (at significant cost)
run it on gas. no emissions required. but not ideal for everyone (except for me and mrshin)
borrow a 4AGZE computer
ditch the SC when engineering, borrow a 100kw or 86kw ecu - rig that up get it going and running nice, get it engineered then do what you want...
OR
get a stock ecu case, put the wolf INSIDE that and make it look like its the stock ECU?
just my thoughts here...
SupraPete
Re: Engineering problems... Mon, 07 July 2003 00:12 Go to previous messageGo to next message
Tune it properly and you'll pass emissions test.
Henn
Rosanna, Melb
Re: Engineering problems... Tue, 08 July 2003 09:34 Go to previous messageGo to next message
thanks guys,
the problem with emissions is that the test is long and complicated and costs many thousands. It's not just a sensor in the exhaust.
And as for pretending its just a 4AGE, I may as well pretend its a 4AC in that case and not engineer at all.
I have a long lineup of problems before this one really becomes critical, but I thought it may need some serious work. Any other ideas??
Re: Engineering problems... Tue, 08 July 2003 09:45 Go to previous messageGo to next message
Just hide the ECU and put an old standard ECU in plain sight under the dash.
I had a conversation about this exact thing with an engineer the other week. The guy I spoke to said he just needs to see the standard ECU to save his arse. What you do with it after the engineering is your problem.
Simple as that.
Re: Engineering problems... Tue, 08 July 2003 11:36 Go to previous messageGo to next message
emissions costs how much>?!?!?!
jeez, if it's that much in melb, drive to sydney and have it done
Grega
Re: Engineering problems... Tue, 08 July 2003 20:21 Go to previous message
draven, yer...last emissions test i was told about said that coz the EPA testing plant was closed down in altona the car needed to be shipped to WA and a cost of about $15k was involved...
easy way around this. buy a pre 76 car......(which doesn't help henn much) or go LPG....
[Updated on: Tue, 08 July 2003 20:21]
Previous Topic:legalities of metal pedals
Next Topic:mates dad bought a twinky....
Current Time: Mon Nov 2 08:13:31 UTC 2026
Total time taken to generate the page: 0.094247102737427 seconds
