Toymods » Tech & Conversions » 1JZ-GTE 2 RA40
zombrax
icon5.gif  1JZ-GTE 2 RA40 Tue, 02 July 2002 11:01 Go to next message
Hiya all
I am planning to put a 1JZ-GTE engine into a RA40 that had a 18R-C engine in it. Is this possible? Has anyone done this from here?
Also where can i find the engine weight for all makes/models etc.
like how much does an 18R-C weigh and 1JZ-GTE weigh?
thanx in advance,
Zombrax
1jwunder
Re: 1JZ-GTE 2 RA40 Wed, 03 July 2002 05:02 Go to previous messageGo to next message
Whoo, hope you dont like traction much........!
I also doubt that the 1J will fit, the 18rc is longish, but not that long, you may be able to mount a radiator in front of the main strut bar though...that would be my suggestion....
Also, how is this legal??
Finally, why a RA40 , I had one with cam, twin carbs, exhaust and they are buckets of shit.
If you are going to do a mod this serious, at least put it into a RA60 coupe that will give you much better handling. I would also say the brakes on both of these cars are not even half up to the task. Do not expect change from $5000 and you will definitely need a front cut.
I would look at other options, perhaps a turbo sprinter engine.
Pete
Re: 1JZ-GTE 2 RA40 Wed, 03 July 2002 07:15 Go to previous messageGo to next message
A 1JZ-GTE will fit in an RA23 without mods to the firewall, so it can be done in an RA40 as well (engine bay is about the same size). Definitely not an easy project though - I reckon you're better off with the 1G conversion which is a piece of piss by comparison and will probably cost half as much (or less).
Malicia
Re: 1JZ-GTE 2 RA40 Fri, 06 June 2003 17:40 Go to previous message
There's a guy here in canberra with a 1jz-gte in an ra40 coupe.
Notr saure if he uses these forums or not, ask in the canberra section see if you can get his e-mail. I cant remember his name but someone there should.
Previous Topic:Magna injectors
Next Topic:7AFE extractor?
Current Time: Mon Nov 2 03:35:07 UTC 2026
Total time taken to generate the page: 0.004349946975708 seconds
