Classifieds » Parts Wanted » 1G GZE Overdrive Pulley
1UZ FTE
1G GZE Overdrive Pulley Sun, 06 July 2003 22:53 Go to next message
Has anybody an Overdrive Crank/Blower Pulley for a 1G-GZE or know who may make them
jamie
rob_RA40
c'town, NSW
Re: 1G GZE Overdrive Pulley Mon, 07 July 2003 00:05 Go to previous messageGo to next message
ive heard Nevo do pulley kits for 4A-GZE and custom sizes, you might wanna look them up.
Grant
Newcastle, NSW, Australia
Re: 1G GZE Overdrive Pulley Mon, 07 July 2003 22:30 Go to previous messageGo to next message
Anything for the 1GGZE will have to be custom made. The 4AGZE has a different offset to the 1GGZE so a 4AGZE blower kit won't be of use. A quick and simple (but not the best) method is to machine off the existing blower pulley and weld a 4AGE water pump pulley in it's place. This will give you 14 psi but you no longer have the use of the clutch.
The better option is machining up a larger crank pulley. I can send you a picture of mine if your interested.
Grant
1UZ FTE
Re: 1G GZE Overdrive Pulley Mon, 07 July 2003 22:41 Go to previous message
Hi Grant
Ok sounds like some custom machining is required and by the look of it if i enlarge the Overdrive pulley on the crank the idle pulley will have to be reduced in dia
Pictures would be great and what approx dia's on the carnk pulley will give what boost,.....also do they have a fuel cut on the standard computer
j@yackandandah.com
thanks again
jamie
Previous Topic:wtb: MAP sensor for EL44 (paseo)
Next Topic:wtb Camry mags
Current Time: Sat Oct 24 01:38:59 UTC 2026
Total time taken to generate the page: 0.0051159858703613 seconds
