Toymods » Tech & Conversions » ALTERNATORS WIRING
MRG-00F
Wollongong
ALTERNATORS WIRING Tue, 08 July 2003 09:41 Go to next message
I have a Nippon Denso alternator with built in reg on my 3t motor. I want to know what wires go where.
On the back of the alternator theres an S, IG, L.
If anyone knows what these symbols stand for could you let me know.
Thanks.
Re: ALTERNATORS WIRING Tue, 08 July 2003 09:44 Go to previous messageGo to next message
All you need to know:
http://www.autoshop101.com/forms/h8.pdf
juzzo84
Hornsby, N.S.W
Re: ALTERNATORS WIRING Tue, 08 July 2003 10:22 Go to previous messageGo to next message
thats a great link Very Happy
sideshow
Re: ALTERNATORS WIRING Tue, 08 July 2003 10:37 Go to previous messageGo to next message
is yr original wiring an external alternator type
if it is then all u do is find voltage regulator
on the 6 pin plug u will have a wire that goes to yr charge light
that goes to L
the will also be a wire with ignition power on it
that goes to IG
then there is the s wire on the alternator
that goes to battery which the easiest way to run is a small loop wire from S to the B+ terminal or battery terminal on back of alternator
MRG-00F
Wollongong
Re: ALTERNATORS WIRING Tue, 08 July 2003 11:59 Go to previous messageGo to next message
Thanks for ur help i understand that, but the earth wire in the original wiring loom is it needed
sideshow
Re: ALTERNATORS WIRING Tue, 08 July 2003 12:05 Go to previous messageGo to next message
very rarely u need the earth on the alternator
just make sure the bolt holds are clean for a good earth
cambelt
melb
Re: ALTERNATORS WIRING Tue, 08 July 2003 12:20 Go to previous messageGo to next message
with all that info i think a 2j alt would be walk in the park for you Dave
Re: ALTERNATORS WIRING Tue, 08 July 2003 12:32 Go to previous message
Dave it was! It took 10 mins to wire up!
Previous Topic:tank for AE86
Next Topic:2TGUE block question!
Current Time: Sat Nov 21 16:36:54 UTC 2026
Total time taken to generate the page: 0.0067880153656006 seconds
