Toymods » Tech & Conversions » would a JZA70 brake booster and cyln fit AE86?
Simon-AE86
Banned user
ADELAIDE - The Drift City
would a JZA70 brake booster and cyln fit AE86? Tue, 08 July 2003 10:37 Go to next message
what the topic says!
will it fit with minimal fabrication?
Re: would a JZA70 brake booster and cyln fit AE86? Tue, 08 July 2003 12:07 Go to previous messageGo to next message
Interesting idea... I don't know the answer, but I presume the reasoning is to make it easier to fit a bigger master cylinder???
Boosters can be surprisingly easy to swap - f'r instance, on the HZ Holden project we're doing, we swapped a Crown booster in with minimal effort, just had to make a new rod to operate it... simple really!
Re: would a JZA70 brake booster and cyln fit AE86? Tue, 08 July 2003 12:11 Go to previous messageGo to next message
If the space is anything like the TA22 which I think it is, I doubt it will fit. The wheel arch is in the way.
gabe
Re: would a JZA70 brake booster and cyln fit AE86? Tue, 08 July 2003 14:06 Go to previous messageGo to next message
I can say that it definately does. cause i have done it
HOWEVER!!
the ae86 master cylinder is only 2 bolt but two pieces of flat bar with a hole in each is all thats needed. No lengthening or shortening of the shaft was required at all. the play between the master cylinder piston rod and the booser (poor description i know) wat absolutely spot on!!
i realise its not ideal but it is very sturdy and has worked fine on mine until i can find something better.
can provide pictures if you wish
sprinterboy4agze
Re: would a JZA70 brake booster and cyln fit AE86? Tue, 08 July 2003 21:26 Go to previous messageGo to next message
yes pls show us some pics
what is the benefit of installing this into your sprinter?
my brake master cylinder is leaking, what would be the best replacement for it?
so is it the booster you change or the whole round thingy i asume that is the master cylinder right? what is the booster is it the cup you put the fluid in?
purpleminiep
Mentone
Re: would a JZA70 brake booster and cyln fit AE86? Wed, 09 July 2003 02:05 Go to previous messageGo to next message
Sorry to barge in but I want a smaller brake booster. Does anyone know what would fit without changing mounting holes. Someone on cub4ag said a Tercel fits but i had a look at a wreckers and it looked like the same size
Brad
sprinterboy4agze
Re: would a JZA70 brake booster and cyln fit AE86? Wed, 09 July 2003 21:19 Go to previous messageGo to next message
are you saying the Tercel is a straight fit on the sprinters?
gabe
Re: would a JZA70 brake booster and cyln fit AE86? Thu, 10 July 2003 08:07 Go to previous message
sorry ppl have not forgotten about the pics. will post tonight
Previous Topic:twin webber kits for a 22r/21rc? where from?
Next Topic:changing AE82 control arm
Current Time: Fri Oct 23 12:46:10 UTC 2026
Total time taken to generate the page: 0.0053708553314209 seconds
