Toymods » Tech & Conversions » rb20 bb turbo - what pipe is what?
Grega
melbourne.victoria.austra...
rb20 bb turbo - what pipe is what? Wed, 09 July 2003 09:55 Go to next message
those of you in the know, so what pipe does what?
i'm guessing this big banjo bolt is oil....turbo drain pipe goes below it...
http://www.vncommodore.com/images/stuff/turbo1.jpg
these are on the other side, and, am kinda guessing they're for the water side of things..
http://www.vncommodore.com/images/stuff/turbo2.jpg
help?
Sprinta
Re: rb20 bb turbo - what pipe is what? Wed, 09 July 2003 10:05 Go to previous messageGo to next message
The oil drain pipe goes on the bottom (1st pic) and must always be facing down so that the oil returns to the sump. The oil feed goes on the very top bolt.
The 2 side bolts are the water lines.
Re: rb20 bb turbo - what pipe is what? Wed, 09 July 2003 10:40 Go to previous messageGo to next message
and MAKE SURE you use the bloody restrictor bolt on the oil feed!
Grega
Re: rb20 bb turbo - what pipe is what? Wed, 09 July 2003 20:59 Go to previous messageGo to next message
yes otherwise the seals shit themselves and things end up smoky.
um, is the restrictor in the banjo bolt or the pipe?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: rb20 bb turbo - what pipe is what? Fri, 11 July 2003 06:57 Go to previous messageGo to next message
The restrictor is actually in the banjo fitting in the engine end of the (top) oil feed pipe. The hole is about 1mm diameter.
Rex_Kelway
Re: rb20 bb turbo - what pipe is what? Sat, 12 July 2003 03:57 Go to previous messageGo to next message
mrshin wrote on Wed, 09 July 2003 20:10
Phew!!!, i would never have known this. Rex would've found out the smokey, rooted seal way..
Thanks muchly
Grega
Re: rb20 bb turbo - what pipe is what? Sat, 12 July 2003 05:51 Go to previous messageGo to next message
thx bigworm.
Re: rb20 bb turbo - what pipe is what? Sat, 12 July 2003 11:27 Go to previous message
I found out the smokey way a while back Evil or Very Mad
Previous Topic:t25/t28 on to a 3tgte ?
Next Topic:How to pull apart a speedo?
Current Time: Thu Nov 19 11:00:59 UTC 2026
Total time taken to generate the page: 0.034886121749878 seconds
