Toymods » Tech & Conversions » 4agze throttle body hose connections??
xpimp
melbourne
icon1.gif  4agze throttle body hose connections?? Wed, 09 July 2003 11:28 Go to next message
Howdy,
I am wondering if any1 can tell me where the following hoses connect? I have attached a pic... My idle is real bad unless one is blocked (more story below, pics first)
http://seven.bf.rmit.edu.au/~s2108249/corolla/IdleProblems.jpg
I brought my halfcut and marked all the vacuum hoses the day it came with different coloured paint spots so i wouldnt have this problem
But... Either i missed two or im missing something
I noticed my idle was real rough, and also that there is always a constant hissing noise... so i investigated it and theres two hoses off the throttle body that go nowhere Sad
When I cover one up (one that sucks) the car runs/idles godly, but without it been blocked the car splutters and sounds like its on its last legs
I have attached some pics and I was wondering if any1 knew what they attach too?
Thanks in advance,
Stuart
feral4mr2
Bundaberg, Qld.
Re: 4agze throttle body hose connections?? Wed, 09 July 2003 11:48 Go to previous messageGo to next message
Freak i would say the a/c idle-up control valve they belong to.
sideshow
Re: 4agze throttle body hose connections?? Wed, 09 July 2003 11:58 Go to previous messageGo to next message
theres 2 pairs of hoses on backl there
one pair goes to the idle up for steering which is a small valve on the steering rack where the column joins it
the outlets for these hoses are about and inch or so apart
all i do is put a ball bearing in the hose then look it from one pipe to the other if u aint got the valve
the other pair of hoses goes from side of throttle body to the a/c idle up then back to the hose right at the front of the pic u have
so im sure the ones u are talkin bout r the steering idle up
so just plug them both
xpimp
melbourne
Re: 4agze throttle body hose connections?? Wed, 09 July 2003 17:06 Go to previous message
Ok thank you both for your replies
I will block it up good cause the car runs real bad without it
Yer it would most likely be the power steering one, cause I didnt fit it in the AE82 cause the mounts didnt match Sad
Thanks heaps,
Stuart
Previous Topic:4agze vacume hoses
Next Topic:7mgte oil question
Current Time: Wed Oct 14 19:03:14 UTC 2026
Total time taken to generate the page: 0.088253974914551 seconds
