Classifieds » Miscellaneous » Calipers + Pads (2 sets 4 ST184 + ST162) *REDUCED*
RobST162
Calipers + Pads (2 sets 4 ST184 + ST162) *REDUCED* Wed, 09 July 2003 23:35 Go to next message
As some of you may be aware, I have now got GT4 Twin Spot brakes on my car.
Funnily enough, I had to remove my old brakes to get them on, and hence, my old ones are for sale + some others I bought recently before I found out I could fit the ST165's on.
Here goes.
1) Calipers, Torque Plate, Shims, + (semi metal) Pads only 10% worn max off ST162 celica. Will fit 184 etc. Left caliper should probably get a seal kit ($40) put in it. It doesn't leak, but I don't think the piston retracts the way it should. have worked fine for ages. Also comes with bolt + connector for brake line.
$75 for the lot (Pads cost me $55 alone) ono
The calipers
http://www.goodshopping.com.au/celica/brakepads.jpg
Close up of pads
http://www.goodshopping.com.au/celica/brakes1.jpg
2) Calipers, 2x shims + torque plate for ST184. In good nic, though I never actually drove with them on my car, but out of curiosity I bolted on on to see if it would fit. It does. Paid $110, sell $50
http://www.goodshopping.com.au/celica/brakes185.jpg
thanks for looking... will answer any questions you may have... Smile
cheers - Rob
[Updated on: Thu, 24 July 2003 00:35]
RobST162
Re: Calipers + Pads (2 sets 4 ST184 + ST162) Thu, 24 July 2003 00:34 Go to previous messageGo to next message
Ok, the ST162 Calipers with semi-metal pads (worth $50 alone) are now $75 for the set
the ST184 calipers are now a total bargain at $50
Rob
0412 184 470
Re: Calipers + Pads (2 sets 4 ST184 + ST162) Thu, 24 July 2003 05:39 Go to previous message
Heya,
what are the dimension of the piston (diameter) and pads?
how big are the calipers physically (ie outside dimensions?).
cheap as! but will they fit an old rolla... hmmmmm
Previous Topic:SOLD 32/36 Down Draft Webber and Redline 2t/3t mount SOLD
Next Topic:FS: 4AGZE
Current Time: Fri Nov 20 01:10:47 UTC 2026
Total time taken to generate the page: 0.0071980953216553 seconds
