Toymods » Tech & Conversions » Adjusting Coilovers
freakysoarer
Adjusting Coilovers Thu, 10 July 2003 01:20 Go to next message
Where can I go to lower my JIC coilovers?
Can I just go to any tyre shop?
Thanks in advance...
shinybluesteel
melbourne
Re: Adjusting Coilovers Thu, 10 July 2003 02:09 Go to previous messageGo to next message
do it yourself, isnt that what coilovers are designed for? don't you have the spanner type tool for doing it? you could go to a tyre shop, but it would be cheaper to do it yourself.
freakysoarer
Re: Adjusting Coilovers Thu, 10 July 2003 02:16 Go to previous messageGo to next message
The problem is that I don't have the necessary tools and equipment...
and no way to lift the car up...
what do you reckoned the ppl at the shop would charge me?
E30-323ti
Re: Adjusting Coilovers Thu, 10 July 2003 02:18 Go to previous messageGo to next message
You just have to bear in mind that when you go from "monster truck mode" to the ground hugging "monorail look" something in the wheel alignment is bound to change and start eating tyres.
Fine to DIY if you are only changing small amounts and a happy with not getting a wheel alignment.
freakysoarer
Re: Adjusting Coilovers Wed, 16 July 2003 15:53 Go to previous messageGo to next message
just had my coilovers adjusted but im confused...
when lowering, does it compress or decompress the springs?
the guy @ pedders told me after adjusting, my front coilovers are lowered to the max... but comparing to when my car 1st landed in OZ, its still slightly higher.
(the coilovers were lifted during compliance when fitting new tyres)
he said that if the spring supports were to go any further apart, the spring would be loose...
earlyrolla
Re: Adjusting Coilovers Thu, 17 July 2003 10:42 Go to previous message
Lowering the car will neither compress or decompress the springs. What happens when you lower using the coilover adjustment is you are lowering the bottom contact point of the spring. When the weight is placed back on the spring, it will still decompress by the same amount as it did before (give or take a mm). The reason that the springs become loose is because either the shock absorber has reached the bottom of the stroke or because the bumpstops on the car have started to hit. (Don't think that macpherson struts normally have bump stops though.)
It is possible to get longer springs with softer compressions to further lower the car but there will be a limit. And besides whenever you go over a speed hump or hit a pothole it is going to stuff the underside of the car. Well at least all the sparks will look cool Very Happy
Previous Topic:Fuel Level Sender - AE86
Next Topic:Urgent... need help
Current Time: Thu Nov 19 00:59:22 UTC 2026
Total time taken to generate the page: 0.0064988136291504 seconds
