Toymods » Tech & Conversions » KE55 with 2TG
7mgtema71
icon3.gif  KE55 with 2TG Thu, 10 July 2003 02:11 Go to next message
Hi Guys,
I have a KE55 at home and i was wondering what modifications are necessary to get a 2TG running carbies in a KE55.
frank
EMP-2TG
Carlingford, Sydney
Re: KE55 with 2TG Thu, 10 July 2003 08:56 Go to previous messageGo to next message
not much Smile
just engine mounts
tho u can use the stock 2t mounts if you want to
just dont line up 100%
7mgtema71
Re: KE55 with 2TG Thu, 10 July 2003 22:37 Go to previous messageGo to next message
Thanks EMP-2tg!
Would i need to make custom engine mounts or is there another factory type that'll suit?
With the 2T mounts not lining up perfectly, will this put the gear box and tailshaft out of wack?
EMP-2TG
Carlingford, Sydney
Re: KE55 with 2TG Fri, 11 July 2003 09:33 Go to previous messageGo to next message
u can get anway with the stock mounts if you want to
the angle is just abit steaper than what u need
but the rubber will take up the space
if you use the t50 you just have to move the stock gearbox mount to the other holes farther back
its all simple Smile
Jonny2TG
Tasmania
Re: KE55 with 2TG Sat, 12 July 2003 04:45 Go to previous messageGo to next message
www.tassie.net.au/~jar
EMP-2TG
Carlingford, Sydney
Re: KE55 with 2TG Sat, 12 July 2003 04:54 Go to previous messageGo to next message
i should just start sending ppl there Smile
7mgtema71
Re: KE55 with 2TG Sun, 13 July 2003 22:57 Go to previous messageGo to next message
Thanks guys. It seems straight forward enough!
rolleye
January 2005
Re: KE55 with 2TG Sun, 16 January 2005 05:05 Go to previous messageGo to next message
sorry to dig up an old thread but I didn't think my questions warranted a new thread.
With the conversion will the engine bolt up to the stock gearbox or is a t50 needed? and if so will it attach to the tailshaft with no problems?
and how someone said you can get away with the stock mounts only the angle is a bit steeper then needed, what exactly will this cause to be out of wack?
also that link no longer works, anyone have a copy of it somewhere?
one more question what are the stock clutches in 2tgs like? will they take much abuse or should I invest in something slightly heavier?
Jonny2TG
Tasmania
Re: KE55 with 2TG Sun, 16 January 2005 06:04 Go to previous messageGo to next message
My site has moved to:
www.geocities.com/jonnyr_1973
If you had a K, 3K or 4K motor, then the gearbox was probably a K40. This will only fit a K series motor.
When you go to a T series motor (2T, 3T, 2T-G etc) you will need a T50 gearbox. AE71 and AE86 Corollas also use a T50 but the bellhousing is wrong. You need a gearbox from a TA22 or TA23 Celica. Or a T50 gearbox from a TE72 (T18 SE) can be used but the shifter is further back.
If you KE35-KE55 was originaly manual, then you can keep the same tailshaft when going to the 2T-G/T50 driveline, as long as the engine is mounted within the ballpark of where its ment to be. Exact engine mounting position does not matter really. Either way, you will probably have to go back to the early KE30/KE35 brake master cylinder and booster. The Australian spec KE55 item comes too close to the 2T-G carbs and trumpets.
rolleye
January 2005
Re: KE55 with 2TG Sun, 16 January 2005 08:05 Go to previous message
ok thanks heaps for the info, Im pretty much set now just need to locate a cheap 2tg/gearbox as its gonna cost heaps to get one sent from interstate
Previous Topic:screws ><
Next Topic:AE86 Digital Dash conversion
Current Time: Fri Nov 20 06:15:01 UTC 2026
Total time taken to generate the page: 0.02037501335144 seconds
