Toymods » Tech & Conversions » RA40 brake and strut help
Simon-AE86
Banned user
ADELAIDE - The Drift City
RA40 brake and strut help Thu, 10 July 2003 05:13 Go to next message
Hey all
I have RA40 struts in the front of my AE86 with custom coil overs and so on.
im looking for a simple brake upgrade that uses the same strut but has vented disk.
i was thinking about 2000GT RA40 brakes as these are vented but DBA dont even list them.. makes me think parts would be too hard!
anyway... i want to do away with the solid disk and go vented.
IDEAS most greatful people Smile
celicaboy
Re: RA40 brake and strut help Thu, 10 July 2003 09:27 Go to previous messageGo to next message
ra60/65 should fit all you need is the rotor you botl them onto the ra40 hub essey etc the wheel stud hub part all that comes apart you just godda replace the solid discs with the ra60/65 vented ones
Simon-AE86
Banned user
Re: RA40 brake and strut help Thu, 10 July 2003 10:23 Go to previous messageGo to next message
and the calipers? i use RA60/65 there too?
because the RA40 calipers will not accept vented disks
Re: RA40 brake and strut help Thu, 10 July 2003 12:23 Go to previous messageGo to next message
Dude, come and check out my Celica some time. RA23 struts are the same as RA40 so what I did applies to you. Smile I have MA61 rotors and calipers, and it stops like nothing else. Cheap upgrade too!
Simon-AE86
Banned user
Re: RA40 brake and strut help Thu, 10 July 2003 22:27 Go to previous messageGo to next message
sweet norbie!
whats a set of MA61 gear cost?
so your telling me that the hub, rotor and calipers bolt straight onto the RA40?
if so let me at it!
Re: RA40 brake and strut help Thu, 10 July 2003 23:44 Go to previous messageGo to next message
I paid $2-300 for a pair of MA61 struts from memory, but you could probably pick up RA6x brakes for less at a wreckers. The hubs and rotors bolt on but you need to fabricate a backing plate for the calipers. Note you'll also end up with a slightly wider front track; from memory the hubs are about 9mm wider.
I have a complete write-up here:
http://www.norbie.net/BrakeMods.htm
Simon-AE86
Banned user
Re: RA40 brake and strut help Fri, 11 July 2003 00:46 Go to previous messageGo to next message
thanks norbs
did u have to modify steering arms or change anything else at all?
Re: RA40 brake and strut help Fri, 11 July 2003 01:47 Go to previous messageGo to next message
Norbie's setup is the right idea. The only quibble would be the drill holes to fold the plate - they make it a bit weaker just where you actually want some extra strength. You could get it folded with a folding machine - wouldn't cost much extra.
Simon-AE86
Banned user
Re: RA40 brake and strut help Fri, 11 July 2003 03:33 Go to previous messageGo to next message
the brackets wont be an issue at all... have a mate who can machine them up for next to nix for me. just needed to find the right hub, rotor, caliper set up!
Re: RA40 brake and strut help Fri, 11 July 2003 04:21 Go to previous messageGo to next message
Nup, no mods to steering arms or any other suspension components. All you're replacing is the hub, rotor and caliper.
If you like I can pull one of the backing plates off my Celica (easy job) and you can have it copied. Smile
Simon-AE86
Banned user
Re: RA40 brake and strut help Fri, 11 July 2003 05:11 Go to previous messageGo to next message
kewl that would be GREAT norbie!
Razz
discuss it over a few beers sat night Wink
Re: RA40 brake and strut help Fri, 11 July 2003 08:13 Go to previous messageGo to next message
Done! Smile
Undertow
NZ
Re: RA40 brake and strut help Fri, 11 July 2003 10:54 Go to previous message
I've heard a bit about using Cressida struts but keeping the 86 tops and steering arms.
Ask the guy who makes this site, Phil Bradshaw. When Phil talks, you listen.
http://home.clear.net.nz/pages/phil.bradshaw/Index .htm
Previous Topic:2jzgte sumps
Next Topic:what turbo's will fit on a gt4?
Current Time: Thu Nov 19 22:33:02 UTC 2026
Total time taken to generate the page: 0.015339851379395 seconds
