Toymods » Tech & Conversions » high reving gze
tim123c
high reving gze Fri, 11 July 2003 05:38 Go to next message
guys i got a problem with an ae92 4agze air flow type.
Just had the conversion done a week ago.
when i start the car it idles ok, bit high, but ok. As soon as i rev it in neutral or when driving, the revs dont go back down when i release the throttle.
i tried turning the idle screw but its in as far as it can go.
Any ideas??
Also when starting the car, it fires, but the revs are heaps low, sounds like its gonna stall, then the revs pick up.
Sounds like air flow meter needs ajusting or something.
Hope someone can offer a solution.
Thanks.
waynewatson
Re: high reving gze Fri, 11 July 2003 05:43 Go to previous messageGo to next message
I had a problem like that in my mazda, all that happened was the spring on the throttle broke. I doubt it's the same in your case though, your car is 20 years older.
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: high reving gze Fri, 11 July 2003 05:54 Go to previous messageGo to next message
could be AFM
could be sticky throttle body
Could be TPS
could be sticky throttle cable
check all these.. if its AFM or TPS it should show error codes on the ecu
tim123c
Re: high reving gze Fri, 11 July 2003 06:14 Go to previous messageGo to next message
i have checked the throttle cable and thats fine, i'll try get the error codes but i cant find the pins to short out on the diagnostic terminal, there is no lable.
Thanks for your advice.
M.W.P.
Rocky Mountains, Canada
Re: high reving gze Fri, 11 July 2003 14:20 Go to previous message
Also check the idle control solenoid/servo and check for vaccum leaks.
Previous Topic:disc brakes on a 22 diff?
Next Topic:2jzgte sumps
Current Time: Thu Nov 19 19:25:37 UTC 2026
Total time taken to generate the page: 0.0066719055175781 seconds
