Toymods » Tech & Conversions » Fuel Pump For a 2tgu
BOGking
icon5.gif  Fuel Pump For a 2tgu Sat, 12 July 2003 04:30 Go to next message
I have Finally transplated a 2tgu into my ta22! Very Happy
we did it in 1 day and it all went great! Very Happy
...Accept for the Fuel Pump. Sad
The 2tgeu engine which is running on twin solexs was using an electric fuel pump, But i want to run a mechanical fuel pump. I was running a Stocko 2t engine and so we thought that the 2t mechanical fuel pump will work on the 2tgu. But it didnt Crying or Very Sad
Is there a Specific Fuel Pump i need? a 2tg pump? or do i just hav to modify the 2t fuel pump?
any leads will be great. and if i need a 2tg fuel pump, any1 got a spare 1 to sell mee?
Thanks.
Jonny2TG
Tasmania
Re: Fuel Pump For a 2tgu Sat, 12 July 2003 04:41 Go to previous messageGo to next message
You can run a standard 2T singlecam fuel pump. Make sure you use the insulator spacer between the pump and the block, 5mm thick, maybe thats what you forgot. Any pump from a 2T or 3T-C should work. Originaly, the 2T-G fuel pump did have a different part number to the 2T pump. I think the dimensions are the same, the difference must have been in the spring stiffness.
I have a spare 2T/2T-G pump I can sell you, and I also have a newish electric pump that will also work great.
BOGking
Re: Fuel Pump For a 2tgu Sat, 12 July 2003 08:13 Go to previous messageGo to next message
Confused That is funny. Maybe my pump is faulty, cause we put spacer back on like it was, and it didnt work. Maybe it is bad luck and the pump decided to die rite when we pulled it out. Sad
Johny how much are u looking for the 2tg pump?
With the electric pump, will that be betta then the mech. pump? and how do your hook the electric ones up? what do you relay it to?? How much u sellin the electric one for? wat brand?
thanks! Very Happy
Jonny2TG
Tasmania
Re: Fuel Pump For a 2tgu Sat, 12 July 2003 09:29 Go to previous messageGo to next message
Maybe you got the fuel flow wrong. Check the pump in a bucket of fuel, pumping with your hand. Note which is intake and outlet.
You can have one of my old 2T/2T-G fuel pumps for $20 or something. The electric one would be about $60. The elcectric one is "Fuel-Flow" brand I think. Its for "8 and 6 cylinder engines". I have used it and it works great, out flows the 2T-G's needs easily. But the standard mechanical one also works for my 1600cc 2T-G. Maybe with my 1800cc engine with big cams I will have to upgrade to electric, not sure.
Electric one is just 2 wires. Can hook it up to anything, I used a relay from the ignition. A relay may not even be needed.
inferno
Re: Fuel Pump For a 2tgu Mon, 14 July 2003 01:26 Go to previous messageGo to next message
I thought the 2T fuel pump wouldn't work on the 2TG because the lever was too short. I tried my 2T fuel pump on my #220 2TG and it wouldn't pump. I think the 2TG fuel pumps are extremely rare as every 2TG i've seen has the electrical fuel pumps, which i feel are the best way to go anyway, at least u get fuel pumping into the carbies without relying on the engine cranking.
BOGking
Re: Fuel Pump For a 2tgu Mon, 14 July 2003 04:11 Go to previous messageGo to next message
hmm yeah i think i will hav to go with a electrical pump too.
inferno do you know which pump is suitable or you recommend?
And how do i wire it up to the ignition?? do i have to use the little black box that is next to the battery?
thanks.
Mr DOHC
Re: Fuel Pump For a 2tgu Mon, 14 July 2003 07:23 Go to previous messageGo to next message
definately use a relay and run it off the wipers or something, just make sure th source doesn't run when the key is on ignition, or it'll pump when u r sitting there pumping beats
inferno
Re: Fuel Pump For a 2tgu Mon, 14 July 2003 07:46 Go to previous messageGo to next message
I bought a universal fuel pump from repco, its suitable for anything up to a carbie V8. The twin carbies do need a fair bit of fuel so make sure the fuel pump is sufficient and its probably best to buy them new to avoid problems (mine was $80).
its also good to put a "kill switch" on the fuel pump for added security, just an insulated, hidden switch on the positive wire.
BOGking
Re: Fuel Pump For a 2tgu Tue, 15 July 2003 09:13 Go to previous messageGo to next message
Hey Thanks all for the info.
i got my hands on a 2tg fuel pump, he says that the arm things are a little longer than the 2t ones. he will be giving it to mee free of charge so i can wack it on and hope it does the job well. yeah he says that 2tgs drink alot of fuel soo sometimes the general electric ones r not sufficient to do the work.
i think that is wat is happening now with this Electric fuel pump! cause 2day i got the Choke hooked up, and when i run the engine with Full or even half Choke i dont get any coughin or poping from the Carbies!even after been warmed up and once i turn choke off, and after 10 secs or so, the Carbies start to pop and cough at about 2k-3.5k
I dont think Running the engine with choke on will be very effienct haha but i think i might hav to do it all the way to the my Mechanic!
Thanks heaps ppl! Very Happy
update ya soon.
Jayem
Finland
Re: Fuel Pump For a 2tgu Tue, 15 July 2003 12:28 Go to previous message
Hey! quick question about T-series fuel pumps. Does anyone know what kind of volumes can 2T/3T fuel pump pump Rolling Eyes ? I'm thinking of using 3T pump as a surge tank pump and yes(!) I need to make fill cap to surge tank.
Previous Topic:last model to use the 16v 4age
Next Topic:will it fit???
Current Time: Wed Nov 18 07:37:42 UTC 2026
Total time taken to generate the page: 0.01202917098999 seconds
