Toymods » Tech & Conversions » 3 out of 4 plugs firing
3 out of 4 plugs firing Sat, 12 July 2003 08:32 Go to next message
Hi all, in need of some help!
I'm trying to get an old 4AC running at the moment. For some reason that beats me its only firing plugs 2, 3 & 4. No.1 is not firing.
I've changed the dizzy cap, rotor, points, hi-tension leads but still no go!
I can't work it out.. It's such a simple system and if all the other plugs are firing should be no reason for number 1 not to.
Sometimes there is a very weak spark, but most the time none at all. I've put the timing light on the hi-tension leads and it flashes for all of them apart from the no.1 lead.
Any ideas?
Joel
Will_AW11
Sydney, Australia
Re: 3 out of 4 plugs firing Sat, 12 July 2003 09:01 Go to previous messageGo to next message
Try swapping the spark plugs around. Sometimes spark plugs can have a hair line crack in the insulator which you can't see, but sparks jump the gap very easily resulting in very little spark energy.
Re: 3 out of 4 plugs firing Sun, 13 July 2003 06:50 Go to previous messageGo to next message
you're a legend mate.. thats exactly what it was!
Joel
EVOSTi
cambo
      no
Re: 3 out of 4 plugs firing Sun, 13 July 2003 11:08 Go to previous messageGo to next message
i cant believe you didnt try just swapping the plugs hehehe. but i spose you wouldnt really think that would be it hey? its always something simple, which i spose is a good thing in a way.
gtman
Re: 3 out of 4 plugs firing Sun, 13 July 2003 13:50 Go to previous message
unfortunately on mine it wasn't so simple, burnt out valve. Couple of hundred dollars later.. Confused
Previous Topic:Ke10 Electronic ignition
Next Topic:W57 Speedo Driven Gear Change
Current Time: Tue Nov 24 20:41:32 UTC 2026
Total time taken to generate the page: 0.10483312606812 seconds
