Toymods » Tech & Conversions » remote shifter for T50 gearbox
w3stie
remote shifter for T50 gearbox Sun, 13 July 2003 02:12 Go to next message
Does anyone know whether either Toyota or other made a remote shifter for the T50 gearbox? I am building a Westfield clubbie and need to have the gearstick about 300mm back towards the rear. If there isn't a part that fits, can anyone suggest a workable arrangement?
Bob
Re: remote shifter for T50 gearbox Sun, 13 July 2003 02:43 Go to previous messageGo to next message
I sure as hell can't think of anything toyota made that put the gearshift back a foot from the end of the box Evil or Very Mad
BUT, if you were to cut the stick off just above the box, and weld a suitable stiff piece of flat bar onto it, then weld a gearstick onto the end of that, it might just work, so long as you're careful to make sure there's no slop in the arrangement. On my car I've done the same thing to move the gearstick on a 45 degree angle to the box (bloody dellows bellhousing!!), although admittedly mine's only about 2 inches long, not 12 Evil or Very Mad
Have a go at least, you don't have anything to lose I don't suppose...
baddog
Sunshine Coast
icon10.gif  Re: remote shifter for T50 gearbox Sun, 13 July 2003 04:25 Go to previous messageGo to next message
Here is a real quick drawing of a shifter we built at work for a clubman racer, works like a charm and if you play with the position of the spools you can make it a short shift action.
http://stevepowell.d2.net.au\shifter.jpg
[Updated on: Sun, 13 July 2003 04:25]
EMP-2TG
Carlingford, Sydney
Re: remote shifter for T50 gearbox Sun, 13 July 2003 06:41 Go to previous messageGo to next message
thats how most ppl do it Smile
shinybluesteel
melbourne
Re: remote shifter for T50 gearbox Sun, 13 July 2003 12:53 Go to previous message
having looked at my t-50 a while back, id say it should be possible to lengthen the rod with the cube of steel wit hthe "hole" for the bottom of the gear stick buy however mych you need, then setting up a good mount for it as per origional, then id would feel basically the same.
might take a little special welding to lengthen the rod though
Previous Topic:W57 Speedo Driven Gear Change
Next Topic:Engine Mount Help: 1G+RA23
Current Time: Sat Oct 17 20:27:29 UTC 2026
Total time taken to generate the page: 0.0095629692077637 seconds
