Toymods » Tech & Conversions » lexus v8 in hilux
sideshow
lexus v8 in hilux Sun, 13 July 2003 10:46 Go to next message
hi to all
i recently picked up a neat 1992 hilux 2wd for my mobile wiring business
im contemplating fittin a lexus v8 to it so i have better fuel economy and power than the shitty 22r carby engine
i need to know on a factory v8 with traction control where r the speed sensors since i might try get the traction control workin
ill make the job very neat n hide most of the wiring too
i know one on each wheel at front but the sensor for the rear is it on the back of the auto gbox or has it got sensors on each of the rear wheels
i know a 1j has a sensor on back of auto just wondering if 1uz is similar
plus also need advice on what bigger brakes are easy to fit
im hopin hilux bigger discs and 4 spots will bolt straight on
and if anyone knows of any things that might help make the conversion easier i would be thankful
sideshow Very Happy
[Updated on: Sun, 13 July 2003 10:48]
need_boost
Re: lexus v8 in hilux Sun, 13 July 2003 11:11 Go to previous messageGo to next message
http://www.rodshop.com.au/
check here, if you cant find anything, you can get them made
sideshow
Re: lexus v8 in hilux Sun, 13 July 2003 11:29 Go to previous messageGo to next message
ive done many conversions in the past so ill be doin
everything myself
since im not too cluey on hiluxes im not sure what upgrades
i can do to brakes and other stuff which will be simple and just bolt on
im goin to measure the auto box and hopefully its same length as the auto box in my hilux
so ill bolt the auto in place and just make new engine mounts
and modify the sump
BansheeBuzz
Gold Coast
Re: lexus v8 in hilux Mon, 14 July 2003 11:30 Go to previous messageGo to next message
your gona need new diff ratios. we wired up this exact same engine and auto to a hilux and the customer was complaining about not having o/d. It was actually that it would shift into 2nd at about 5kph and was overreving in top.
sideshow
Re: lexus v8 in hilux Mon, 14 July 2003 11:31 Go to previous messageGo to next message
ok thanks
ill research everything b4 i decide what to do
might just keep it standard if i use it for my business
[Updated on: Mon, 14 July 2003 11:32]
BansheeBuzz
Gold Coast
Re: lexus v8 in hilux Mon, 14 July 2003 11:33 Go to previous messageGo to next message
if your hilux was auto thou you may find ratios may be ok???
Have you got the engine yet? make sure you do the starter up before you fit it - there in an inaccessable spot once there in(under the intake manifoldfrom memory)
sideshow
Re: lexus v8 in hilux Mon, 14 July 2003 12:03 Go to previous message
yer its 4 speed auto with 22r carby
no engine yet
[Updated on: Mon, 14 July 2003 12:04]
Previous Topic:4age - 4agze crank strength differences..
Next Topic:18RGU help needed urgently
Current Time: Sun Nov 1 00:20:20 UTC 2026
Total time taken to generate the page: 0.032450914382935 seconds
