Toymods » Tech & Conversions » Flywheel Balancing
Liam
icon5.gif  Flywheel Balancing Sun, 13 July 2003 14:11 Go to next message
I'm currently putting a 4A-GZE (with LSD gearbox) into my AE92 Corolla.
I've been looking at getting my clutch and pressure plate upgraded, and will get the flywheel surface machined whilst i'm at it, but i was wondering what the benefits of balancing the flywheel/clutch unit would be and if it is worthwhile doing.
What exactly does this 'do', and for the sake of 110 dollars, is it something that should be done whilst everything is apart ... "do it once and do it right", so to say?
I have heard some people say it's not really necessary other than for high speed racing and so forth (which i don't intend to be doing), and other people say it's good to avoid engine shudder at speed, so it would be good to hear a few more opinions.
Thanks,
Liam.
earlyrolla
Re: Flywheel Balancing Sun, 13 July 2003 16:57 Go to previous messageGo to next message
Depends on how good the clutch, pressure plate and flywheel are already balanced. Balancing everything is always good if you want to rev the motor hard. If it is only a stock engine then it would probably not be worth it.
Well thats my two cents, anyway.
IRA11Y
Club Member
Re: Flywheel Balancing Mon, 14 July 2003 09:54 Go to previous message
generally the clutch isnt balanced as its a floating (moving) part so balancing it is a waste of time.
IMHO it would be a waste of money to only balance the flywheel, youll only get a true benefit by balancing the whole bottom end together
Previous Topic:4AGE with W50 Transmission, can it be done?
Next Topic:Rims for my rolla
Current Time: Sat Nov 21 01:19:58 UTC 2026
Total time taken to generate the page: 0.0057621002197266 seconds
