Toymods » Tech & Conversions » 4agze overfueling
ke20 4agze
4agze overfueling Mon, 14 July 2003 01:17 Go to next message
Hi Since I put the engine back in my car it is overfueling to the point where it is undrivable, dies after half throttle, choofs out black smoke and misses at any constant rev.
I tried to check the self dignostic but the light is not hooked up and in there is no wire to where the light plug is under the bonnet in the diagnostic plug.
It is a series 2 MAP sensor motor and I cant find any diagrams of the ecu pins to plug a light in there. I have found plenty for the AFM model but none for the MAP.
Also does anybody know where I can find specs about where the TPS should be set. It has been moved from before I got it and I want to set it back right.
SW20R
Re: 4agze overfueling Mon, 14 July 2003 06:21 Go to previous messageGo to next message
have you put in the 02 sensor? check if its working or has been cut off
ke20 4agze
Re: 4agze overfueling Mon, 14 July 2003 07:36 Go to previous messageGo to next message
Yeah, checked everything except MAP sensor because I don't know where it is or how to test it.
SW20R
Re: 4agze overfueling Mon, 14 July 2003 07:44 Go to previous messageGo to next message
its labled as a vaccum sensor. a small black box that should connect to the throttle body
http://club4ag.com/images/20V%20AE86%20Process/DSC00587.JPG
well for n/a it should look like that.
as for testing it, could be simple as it not being plugged in.. which it sounds like. if i disconnect mine, it would stall or just die out later. sounds like a rotary, but would puff off blacksmoke sometimes.
try this url as it might have the information.. thats where i got the pic from
http://club4ag.com/faq%20and%20tech_pages/ae86_pro ject%2020V.htm
ke20 4agze
Re: 4agze overfueling Mon, 14 July 2003 07:49 Go to previous messageGo to next message
Thats exactly what mine does, sounds like a rotor (how embarrasing). I'll check it out. Thanks.
SW20R
Re: 4agze overfueling Mon, 14 July 2003 07:52 Go to previous messageGo to next message
yeah then im pretty sure its not connected, has a leak or isnt plugged in. sounds cool sometimes.. Wink but yeah doesnt make the motor happy. and it is a good idea to have them on without it you'll notice your brakes arent too good becuase no vacuum for the brake booster
rollaboy
Coffs
Re: 4agze overfueling Mon, 14 July 2003 08:09 Go to previous messageGo to next message
If the TPS has been removed and not set back up again it will not run basically at all.
Have a look that these.
http://www.mypage.tsn.cc/rollaboy/toymods&twincam16/book1_2.jpg
http://www.mypage.tsn.cc/rollaboy/toymods&twincam16/book2_1(4)_2.jpg
ke20 4agze
Re: 4agze overfueling Mon, 14 July 2003 10:05 Go to previous messageGo to next message
This stuff is gold, thanks.
I couldn't find any small black box though.
Could anybody tell me what these sensors are?
Wait... can somebody tell me how to post pics? Confused
sideshow
Re: 4agze overfueling Mon, 14 July 2003 10:27 Go to previous messageGo to next message
if its a series 2 map type 4agze then i think the map sensor is under the right hand side of the intercooler as u r lookin at the intercooler from the front of the car
the first 4agze map have the seonsor on the firewall slightly to the drivers side of the centre of the car
ke20 4agze
Re: 4agze overfueling Mon, 14 July 2003 10:55 Go to previous message
Hooray, I found the MAP sensor hiding at the bottom of the engine bay behind a couple of relays and it had a little naked tube waiting for a vacume hose.
Thanks heaps everybody.
Previous Topic:struts
Next Topic:KE70 specifications
Current Time: Sat Nov 21 02:21:39 UTC 2026
Total time taken to generate the page: 0.0053339004516602 seconds
