Toymods » Tech & Conversions » Altezza Motors
Gryphon Power!
Perth, WA
Altezza Motors Mon, 14 July 2003 11:52 Go to next message
Does anyone have any specs or information on the motors in Altezza's? I cant seem to find anything but pictures.. i need a wiring harness and ecu, and by the time i stuff about, i might as well get an altezza front cut Smile
Soarer
Wollongong
Re: Altezza Motors Tue, 15 July 2003 09:23 Go to previous messageGo to next message
Depends what model Altezza... some are 1G-GE some are BEAMS 3S-G(T?)E (I think).
NuGeN
Re: Altezza Motors Tue, 15 July 2003 09:28 Go to previous messageGo to next message
Well the Aus delivered "Altezza" comes with the 1G-FE for the IS200 and a 2JZ-GE for the IS300. In Japan the Toyota Altezza RS200 comes with the BEAMS 3S-GE while the AS200 comes with the 1G-FE.
CelicaRA45
nth ringwood, Victoria
Re: Altezza Motors Tue, 15 July 2003 10:45 Go to previous messageGo to next message
i have a 3sge ecu and complete loom for a altezza beams 3sge
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon1.gif  Re: Altezza Motors Tue, 15 July 2003 23:27 Go to previous messageGo to next message
AFAIK, Altezza/RS200 refers to the 3S-GE model only.
IS200 has the 1G.
IS300 has the 1JZ.
People do call these cars Altezzas (prolly 'coz it sounds better and looks the same), but they'd just be tugging.
Re: Altezza Motors Wed, 16 July 2003 00:37 Go to previous messageGo to next message
Nark wrote on Wed, 16 July 2003 09:27
IS300 has the 1JZ.
Actually, it's a 2JZGE. Otherwise it'd just be an IS250! Razz
Nark
Cabramatta, NSW
icon9.gif  Re: Altezza Motors Wed, 16 July 2003 00:57 Go to previous messageGo to next message
Oops! Brain fart... I hadn't had my coffee yet. Sad
Gryphon Power!
Perth, WA
Re: Altezza Motors Wed, 16 July 2003 11:48 Go to previous messageGo to next message
CelicaRA45 wrote on Tue, 15 July 2003 20:45
Cool, thanks alot... i take it half cuts for these are hard to come by? Because all i need is the motor. And id rather a 1G-GTE motor, but i heard that the "f" series injection system is alot better or something the rather, does anyone know what the 1G's put out stock? I mean, the 1G-F's..
btw, what is a 3sge? Is that a four cylinder? The motors going into a 1300kg car.. with the 1G-GTE it should only weigh about 1200ish Smile
Nark
Cabramatta, NSW
icon1.gif  Re: Altezza Motors Wed, 16 July 2003 23:27 Go to previous messageGo to next message
1G-FE puts out 114kW.
1G-GTE puts out 157kW.
BEAMS II 3S-GE from the Altezza/RS200 puts out 157kW also. It's a naturally aspirated 2.0L 4 cylinder with variable valve timing on both intake and exhaust camshafts.
In NSW, you won't be able to legally put a 1G-GTE into an IS200 since the engine is older than the car.
On a side note. If anyone knows of any Altezzas landing on our shores, I'd be very interested in buying it....
NuGeN
Re: Altezza Motors Sat, 19 July 2003 07:51 Go to previous messageGo to next message
hm... a total noob question here but... what does AFAIK stand for??
Mx73_LuXoBarge
Bris-vague-us
icon10.gif  Re: Noob Q Sat, 19 July 2003 08:42 Go to previous messageGo to next message
Re: Altezza Motors Sat, 19 July 2003 17:51
As
Far
As
I
Know
Soarer
Wollongong
Re: Altezza Motors Sat, 19 July 2003 13:18 Go to previous messageGo to next message
IS200 has the 1G.
IS300 has the 1JZ.
Not quite Nark... check out the specs on the Toyota Japan website: http://www.toyota.co.jp/Showroom/All_toyota_lineup /Altezza/index.html
Altezza refers to all models (3S and 1G), whereas RS200 refers to the 3S model only.
Nark
Cabramatta, NSW
Re: Altezza Motors Sat, 19 July 2003 13:24 Go to previous messageGo to next message
Intersting. Looks like I'm wrong. Bugger. Sad
They seem to call the 1G one the Altezza AS200.
wilbo666
Re: Altezza Motors Sat, 19 July 2003 13:25 Go to previous messageGo to next message
IS200 has the 1G.
IS300 has the 1JZ
Pretty sure its a 2JZ-GE (as was said above) in the IS300 Nark!
NuGeN
Re: Altezza Motors Sun, 20 July 2003 15:30 Go to previous messageGo to next message
Yeh... I only found out about the Altezza AS200 through Gran Turismo 3.
Also lets not forget the Altezza Gita (the wagon one) which comes with a 2JZ-GE.
boudan
Re: Altezza Motors Tue, 22 July 2003 05:55 Go to previous message
Nark ? wrong ?
thats got to be a first of some sort....
Previous Topic:simple question about compression testing.
Next Topic:Cleaning engine bay
Current Time: Wed Nov 18 19:25:35 UTC 2026
Total time taken to generate the page: 0.007220983505249 seconds
