Toymods » Tech & Conversions » 3T-GZE Vs 3T-GTEU
Classique71
Colac, Victoria
3T-GZE Vs 3T-GTEU Wed, 03 July 2002 12:31 Go to next message
just looking for some info on this fellas
theres a good chance im becoming nostaligic and keeping the ta22 for a bit longer so another engine modification mayt be in order
Now having seen a few 3tgteu's in ta22's and seen what they go like - i was wondering what a hybrid 3tgze would go like - aka 4sfed but stroked as well
Im not totally up to speed with EFI, turbo and supercharging so any ideas on performance would be appreciated -
Ie i believe suprerchargings better if you want a torquey motor , whereas turbo means higher top speeds, accelleration etc ??
Also has anyone here Stroked a 2tgeu with a set of 3t pistons/cranks/overbore before - and what was required to do so
If i chose the supercharging option - id find a 2tgeu and build it up from there.
Also would both conversions fall under the $4000 mark , not including diff swap , and would i need a W50 or similar setup behind the hybrid 3tgze
Stuart
Classique71
Colac, Victoria
Re: 3T-GZE Vs 3T-GTEU Wed, 03 July 2002 12:33 Go to previous messageGo to next message
Another thought - would it just be easier to buy a car that already has a 3tgteu modification in it and work from there??
inferno
Re: 3T-GZE Vs 3T-GTEU Wed, 03 July 2002 13:48 Go to previous messageGo to next message
hmm interesting ideas, but chances are if it hasn't been done then it ain't worth doing.
firstly, haven't done anything like it so i don't know from experience, but i believe that it is VERY difficult to supercharge and turbocharge (twincharge) because of piping and pressure issues etc.
stroking a 2TG would be more difficult than using a 3T block and whacking a 2TG head onto it (quite common), still gives you 1800cc, then you could always bore and stroke with an 18RG crank etc (giving 2L), but this is considered not a great move because of reducing revability (could even go to 2.2L with a 3Y crank, but thats just crazy). Theres not much involved with the 3T/2TG hybrid, just cam bearing changes, new pistons (or flycut old ones), a bit of mucking around with them.
A mate has done the worked 3T/2TG hybrid engine, bored, cams etc, cost him so far over three grand because he had to get everything top notch and re-worked otherwise it would be unreliable (whats the point of working an engine if you can't rev it passed 8000rpm Rolling)
W series gearbox strongly advisable for any more horsepower than over stock 2TG power (around 130hp, but heard T50s have taken a lot more). W55/57/58 the goer.
The last option would be the best. Considering you have a TA22, any engine above 1600cc would need engineering/inspection for registration, especially a 3TGTE (brake, seatbelt upgrades, inspections etc) . Best option would be to buy an already converted/engineered/registered TA22 with a 3TGTE sitting in it.
Once you go turbo you can do upgrades for horsepower increases, where as working an engine to the max eventually comes to a dead end, and you can't get another power fix.
This is just my opinion, mainly goss i've heard or read, hope it helps ya.
Rob
YOTA22
Classique71
Colac, Victoria
Re: 3T-GZE Vs 3T-GTEU Wed, 03 July 2002 15:35 Go to previous messageGo to next message
Re twin charging this wasnt my idea - i guess i didnt make it clear - Idea was a supercharger OR a turbo charger
tim frosts celica 4sfed had a supercharged 2tgeu - my idea would be using his engine idea as a basis - then stroke it , though in that case i would be stuck with a t50
the other gives me the stronger box and probably a better basis - though superchargings an interesting idea since not many do it ..
Anyway id look into it in detail before hand .. I could probably pick up a converted Ta or RA with a 3tgteu setup already done for 4-5 grand then build on that ..
Stuart
inferno
Re: 3T-GZE Vs 3T-GTEU Thu, 04 July 2002 03:52 Go to previous messageGo to next message
ok i must have been too tired to read it correctly Freak
Tim Frost got around 85% increase in peak horsepower using the 4AGZE blower and stock pulley but taking the turbo off and supercharging a 3TGTE would give you less of a power increase, when you could have spent the money upgrading the turbo.
I like the idea of supercharging a 2TGEU, apart from the mounting and computer issues. A guy in brisbane used to get 13sec quarters by doing a blow-thru 4agze blower on a stock 2TG setup, running around 16psi. The engine didn't last long but he got some good times out of it.
[Updated on: Thu, 04 July 2002 03:53]
Re: 3T-GZE Vs 3T-GTEU Thu, 04 July 2002 08:30 Go to previous messageGo to next message
I'm not a big fan of supercharger setups, because they're often more expensive than a turbo setup (and definitely more expensive if you're starting with a turbo engine), and they're also much less flexible if you want to do mods in future. A well thought-out turbo setup will still have excellent mid-range performance and an acceptable bottom end to go with the screaming top end - the supercharger would only have a significant advantage at very low rpm, which is exactly where you shouldn't be in a T series engine anyway! Smile
And at the end of the day, a turbocharged engine is going to make more power than a supercharged engine, all else being equal. Turbo gets my vote for certain! Smile
If you want to stroke the 2T-GEU, it's a piece of piss if you have a 3T donor engine - just swap the bits over. As for using an 18R-G crank as someone suggested, that's totally not going to happen - R series cranks are not at all compatible with T series blocks!
Classique71
Colac, Victoria
Re: 3T-GZE Vs 3T-GTEU Thu, 04 July 2002 08:38 Go to previous message
Ta norbie - All this info is much appreciated BTW - as i still dont really know what i want to do with my ta22 ..
in a fortnights time we have a dyno day coming up so ill eb able to guage what my ex drag 2tB is doing - For all i know camming that and stroking it out further might be a fun option - but by the sounds of it for money wise - id be on the smart cards to buy a already converted 3tgteu and build around the already installed and engineered motor. Means 2 celicas in the shed though - one old school Carbs and cams ) - one new school ( EFI and turbo )Smile
Ill have to ponder this
While im at it - anyone know of say an ra28 thats already had a 3tgteu converted ?? Id like one of those motors int hat shape - though i hear weight wise its so much more fun in a ta22 Smile
Stuart
Previous Topic:Retractable seat belts
Next Topic:1JZ-GTE in RA65?
Current Time: Sat Nov 21 20:21:47 UTC 2026
Total time taken to generate the page: 0.010671138763428 seconds
