Toymods » Tech & Conversions » replacing trailing arm bushes
TE72_Turbo
replacing trailing arm bushes Mon, 14 July 2003 12:27 Go to next message
After replacing the 8 trailing arm bushes on a TA22 rear end, should the bolts be retigtened with the weight of the car on the wheels (normal ride height), or is there a specific suspension height that you need to set it at before tightening?
Thanks in advance Smile
Phil
SRacin
Christchurch, New Zealand
Re: replacing trailing arm bushes Wed, 05 January 2005 08:04 Go to previous message
Ok reviving another old thread.
As an answer to the above question.
Yes there is a specic way to adjust wheel height
Adjustment of Rear suspension wheel height
Before commecing this adjustment, the rear coil spings must be removed as previoously described, blah, watch out for brake hoses stetching...
Fit height gauges (09742-14010) between axle housing and rear chassis member. Ensure guagues on both sides. Jack up axle housing untill guages touch housing and chassis. While in this poisiton tightening all removed control rods or lateral rod....blah blah blah....if you dont do this bad stuff will happen.....
Anyho, time for my question
The upper trailing arm bushes on my ke70 (ae86 diff) unlike the lower arms have an outter sleeve also, is this supposed to come out also? same with the panhard rod. If so my little press just doesnt cut it...
The bushes without the outer sleeve( but have a flange) on the lower arms came out fine...
Logan
Previous Topic:Pull type BOV design?
Next Topic:ta22 and ra28 doors
Current Time: Sat Oct 31 21:51:04 UTC 2026
Total time taken to generate the page: 0.0043578147888184 seconds
