Toymods » Tech & Conversions » 1jz TPS question
thunderbird1
Sydney Australia
1jz TPS question Wed, 03 July 2002 19:07 Go to next message
Guys...
Trying to sort out my hassles ...
This is what it does.
Foot 90% to the floor... goes damn hard.
Foot hard into the floor... Coughs and doesn't go as hard.
Could this be the TPS?? Just an idea? Are they adjustable?
Luke
HedgehogSandwich
UK
Re: 1jz TPS question Wed, 03 July 2002 21:47 Go to previous messageGo to next message
i had the same problem, the cause was fouled plugs. Ran fine up until full thorttle then missed like crazy. Sounds obvious but worth a check.
Guest
Re: 1jz TPS question Thu, 04 July 2002 00:12 Go to previous messageGo to next message
Luke I know you changed your plugs last week , but have you done it since that 200 k's of limp mode the other night ??
That could be your prob.
Could also be an over richness problem too, just like joeys cressida on a smaller scale.
have you experimented with your fcd ??
Matt
1jwunder
Re: 1jz TPS question Thu, 04 July 2002 01:06 Go to previous messageGo to next message
Try cleaning and re-gapping your plugs to 0.8mm, dis connect your battery to re-set your ECU, then see what happens. How may k's have the injectors done?
Also check that you are getting signal from you O2 sensor as it will run too ruch if it is stuffed. (ie safe mode.)
Guest
Re: 1jz TPS question Thu, 04 July 2002 01:13 Go to previous messageGo to next message
Luke did you reconnect trhe o2 sensor ??
we had it undone remember.
thunderbird1
Sydney Australia
Re: 1jz TPS question Thu, 04 July 2002 04:13 Go to previous messageGo to next message
yeah i did the o2 sensor back up ... i'll put new plugs in and get back to you guys. Thanks for the help Smile
Luke
jza70-mel
Perth WA
Re: 1jz TPS question Thu, 04 July 2002 13:14 Go to previous messageGo to next message
Is it because the engine management is going full rich with wide open throttle? My JZ didn't feel as powerful with foot flat to the floor compared to at about 80%, until I changed the fueling curve. It may be a problem with the ECU on Auto models - the other guys seem to mostly have manuals.
Manny
Re: 1jz TPS question Thu, 04 July 2002 13:48 Go to previous message
Mine's a factory manual and had the same hesitation with the stock fuel mapping. With the S-AFC tuned and cutting 5-15% fuel between 4000 and 8000 rpm, I can go WOT without any resistance and response is instantaneous.
May be related to factory ECU tuning to 100 RON fuel in Japan and factory map overfuelling to avoid knock and to keep valve temps down.
Previous Topic:JZA70 Mounts needed
Next Topic:Need some input on engines...
Current Time: Sun Nov 22 14:10:35 UTC 2026
Total time taken to generate the page: 0.0064959526062012 seconds
